Old 03-14-2010, 12:18 PM   #1
melissa.bluth13
melissa.bluth13 is on a distinguished road
Dizzy Camshaft sensor - 1999 SL2 - location & how to replace
Can someone let me know where the camshaft sensor is located and how to go about replacing it? Also, is it possible the Check Engine code for Camshaft Sensor could appear due to heavy rain? Thanks!
Add to melissa.bluth13's Reputation
Rate the quality of this post and help melissa.bluth13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
melissa.bluth13 is offline   Reply With Quote
Old 03-14-2010, 12:36 PM   #2
Default Re: Camshaft sensor - 1999 SL2 - location & how to replace
There is NO physical CAMSHAFT sensor. The signal is generated in the coil pack though. If the code occurred in a heavy rain event then it is highly likely that a set of new plug wires and sparkplugs will fix it just fine. Any brand of mid priced direct fit wires will work and use only NGK plugs. NGK BKR5ESA-11 for DOHC, don't let some counter person sell you any platinum plugs. Advance stocks NGK plugs and most NAPA stores also have them.
Once the plugs and wires are replaced you can clear the code by removing the PCM B fuse from the engine compartment fuse box or just drive the car as if its gone the SES will turn of after a couple of trips.
camshaft positioning sensor location akachillywilly S-Series Tech 2 03-07-2008 10:32 PM
Camshaft Position Sensor on a 96 SC2... DJboozeAlot S-Series Tech 15 12-06-2006 07:38 PM
Camshaft Positioning Sensor! clintlight27 S-Series Tech 19 11-22-2006 01:45 PM
camshaft sensor JC2002SILVERSC2 S-Series General 33 01-19-2006 02:42 AM
Need to replace camshaft bearing cap - New or used? Hiddenlites S-Series Tech 4 09-25-2005 11:16 PM
