Old 03-05-2010, 01:04 PM   #1
xybaby
xybaby is on a distinguished road
2002 SL
Default Clutch gear shifter suddenly feels some resistance
Hi all,
I have a 2002 Saturn SL SOHC manual transmission.
Yesterday, maybe because I did not put shifter properly into gear, the shifter pop out from 2nd gear to neutral during driving. After that, I feels that the gear shifter has more resistance than before, in and out for all 5 gears and back. The car still drives as normal. And the clutch pedal also feels the same as normal.
I had this feeling of resistance one year ago. But it disappeared after two weeks driving.
Can you tell me what may cause such issue? Is it related to clutch fluid, or hydaulics or clutch itself? How can I diagnose it?
Thanks so much for your help!
Add to xybaby's Reputation
Rate the quality of this post and help xybaby reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xybaby is offline   Reply With Quote
Old 03-16-2010, 07:47 PM   #2
lg540
lg540 is on a distinguished road
1996 SL
Default Re: Clutch gear shifter suddenly feels some resistance
When my 96 started popping out of 2nd it ended up being the shifter cables which had become all frayed at the ends. I also started having a getting hard to get in to reverse before they went completly. If that ends up being your problem, go with the Saturn part, the dormands don't work, they bend and won't go in to gear. I had to jam some rocks in next to the cable under the console to keep them from bending until I could swap them for the saturn part, no prblems since then.
Add to lg540's Reputation
Rate the quality of this post and help lg540 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lg540 is offline   Reply With Quote
5 speed shifter resistance changes on it's own Cortana S-Series Tech 1 01-17-2007 08:10 PM
shifter feels grindy? popped out of gear while driving spiffious S-Series Tech 13 11-10-2006 03:11 PM
Shifter feels loose when its in gear turbobuick33 S-Series General 5 05-17-2006 04:17 PM
suddenly feels like a skoda... andrewtwice S-Series General 12 02-25-2006 12:53 AM
Shifter still feels sticky, even after new shifter and cables! 98greenSC2 S-Series Tech 6 11-22-2005 08:15 PM
