Old 02-25-2010, 09:57 PM   #1
Wingmn
Wingmn is on a distinguished road
Wingmn's Avatar
1993 SL2
2009 Outlook XR
Default Torque Specs for Wheel Lugs
I'm going to rotate my tires in the morning - can anyone give me the Torque specs for the lug nuts?
93 SL2a (My work shuttle) 225k
09 FWD Outlook (Wife's vehicle) 82k
13 Ford Fusion Hybrid (New family shuttle) 31k
Add to Wingmn's Reputation
Rate the quality of this post and help Wingmn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wingmn is offline   Reply With Quote
Old 02-25-2010, 10:28 PM   #2
page2171
page2171 will become famous soon enough
page2171's Avatar
Default Re: Torque Specs for Wheel Lugs
The wheel nuts are torqued to 140 lb ft
Add to page2171's Reputation
Rate the quality of this post and help page2171 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
page2171 is offline   Reply With Quote
Old 02-25-2010, 10:59 PM   #3
Wingmn
Wingmn's Avatar
1993 SL2
2009 Outlook XR
Thanks Page!
Old 02-26-2010, 01:31 PM   #4
Doug C
Doug C's Avatar
2008 Outlook XE
I'm sure it is mentioned in the manual somewheres too (and thought closer to 100) !??
Wow that is going to be a 'growner' when i start flipping out the seasonals next yr ! Used to 80 on the '86accord
doug c
Add to Doug C's Reputation
Rate the quality of this post and help Doug C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-26-2010, 02:06 PM   #5
Wingmn
Wingmn's Avatar
1993 SL2
2009 Outlook XR
Yes - it IS mentioned in the Owners Manual.... I feel sheepish.....
I just finished rotating the tires and when I looked up the Tire Pressure Monitor relearn I ran across the Torque specs....
140 ft lbs.
Old 02-26-2010, 06:52 PM   #6
page2171
page2171's Avatar
140 ft lbs.
That is where I found it...I had an electronic copy saved on my computer. I just couldn't think of a witty way to say I had found it there without making you look stupid.
Old 02-28-2010, 08:20 AM   #7
T-boneSW1
T-boneSW1 is on a distinguished road
T-boneSW1's Avatar
1995 SW1
wow that seems awful high? most folks would not be able to break those loose with the OEM wrench.
Add to T-boneSW1's Reputation
Rate the quality of this post and help T-boneSW1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
T-boneSW1 is offline   Reply With Quote
Old 03-01-2010, 11:07 AM   #8
outlookowner
outlookowner is on a distinguished road
2007 Outlook XR
alldatadiy.com says torque the lug nuts to 140n.M(100ft-lb).
Add to outlookowner's Reputation
Rate the quality of this post and help outlookowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
outlookowner is offline   Reply With Quote
Old 03-01-2010, 01:47 PM   #9
VUESBROTHERS
VUESBROTHERS is on a distinguished road
VUESBROTHERS's Avatar
2009 Outlook XR
Per my '09 Owner's Manual (and I realize they DO make running engineering changes not reflected at the time of printing), wheel nut torque specs are: 140 lb ft lbs or Metric 190 N*m.
Here's the page in my book.
Regards,
Jim
In God We Trust!
'09 XR FWD, Bluetooth, Nav, O/H DVD, 8 Pass, Leather, Htd Seats, Tow Pkg, Moon, Sky Light, Conv Pkg, Bose Surround Audio Pkg, Enhanced Conv Pkg, HID, 2-Way Advanced Remote
Add to VUESBROTHERS's Reputation
Rate the quality of this post and help VUESBROTHERS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUESBROTHERS is offline   Reply With Quote
Old 03-02-2010, 11:43 AM   #10
outlookowner
2007 Outlook XR
Sorry about that. The data I gave from alldatadiy.com was for a 2007 Outlook.
Old 03-02-2010, 02:16 PM   #11
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
140 is correct for all 4 year outlooks 07,08,09,10
Add to onefunkar's Reputation
Old 03-02-2010, 04:37 PM   #12
outlookowner
2007 Outlook XR
Alldatadiy.com is incorrect. My owner's manual also states 140ftlb. Thanks for the info.
Old 03-02-2010, 05:55 PM   #13
Doug C
Doug C's Avatar
2008 Outlook XE
Attention Re: Torque Specs for Wheel Lugs
will be tough nut(s) to crack, and i had two hernias nip/tucked last june . . . . .
Old 10-13-2012, 08:30 PM   #14
JDSullivan
JDSullivan is on a distinguished road
This thread has become confusing. To clarify the torque for the S-Series, I did my own research, The index of the owners manual in my 1994 SL2 refers the reader to page 234 to find the "Wheel Nut Torque" value. Page 234 says "The torque wrench setting should be 140Newton-meters
(103 ft-lbs)." That makes sense; else, how would anyone but a wieght-lifter change a flat tire on the road.
Add to JDSullivan's Reputation
Rate the quality of this post and help JDSullivan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JDSullivan is offline   Reply With Quote
Old 10-13-2012, 10:45 PM   #15
You should realize that you are looking at a 2 1/2 year old thread for the Saturn OUTLOOK. Not the Saturn S-series.
So the 140 FT LB is correct for the Outlook and the 103 FT LB is correct for the S-series.
Add to ssicarman's Reputation
Old 11-13-2012, 03:33 PM   #16
saturnions
saturnions is on a distinguished road
Add to saturnions's Reputation
Rate the quality of this post and help saturnions reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnions is offline   Reply With Quote
Old 01-18-2013, 04:30 PM   #17
Doug C
Doug C's Avatar
2008 Outlook XE
Idea Re: Torque Specs for Wheel Lugs
'...That makes sense; else, how would anyone but a wieght-lifter change a flat tire on the road...."
CAA membership and let them crack them !
Or as I carry in my vehicle torque wrench to chk torque if any repairs done requiring the techs to remove tires and also a cheater bar (?) in back to use over the star wrench that the Saturn dealer had inserted into the floor tray upon sale !
btw I really detest (sp?) the oem wrench that GM installed as part of the jack package. It would take forever raising or lowering the vehicle using it !! So also have a 3/4" drive socket wrench and applicable sockets in the side storage (well) compartment, to do any requisite jobs on the wheel lugs at home or while on a road trip.
imho
Wheel Lugs... how tight? eric02SC2 S-Series Tech 21 04-21-2006 01:05 AM
torque specs gmelton S-Series Tech 2 04-05-2006 04:42 PM
Front wheel lugs wlhawk Vue Tech 2 06-05-2005 05:57 PM
Nut Torque Specs for 1999 SL2 Torque Axis Mount todd8 S-Series General 3 05-01-2005 12:34 AM
Wheel Lugs & Locks s123 Vue General 1 07-18-2004 03:44 PM
