Old 02-24-2010, 12:55 AM   #1
joe81tx
joe81tx is on a distinguished road
Default Stereo Wiring - 2001 SL1
First and foremost I hope you can forgive me, I already cut off the factory wiring harness so I cannot use an adapter. Next, I bought a Pioneer AVIC-U310BT which is a double DIN unit with a 4.3" nav screen. There are 2 orange/yellow/brown wires and I was quite confused on which to use for battery/ignition/dimming until I found this post: saturnfans.com/forums/showthread.php?t=132618 that told me to use the bigger orange wire and smaller yellow and brown wires. As it stands I have the battery ignition dimming and ground connected. I've only twisted them around each other to make sure everything works before I solder and tape them. I had already soldered some of the other colors which didn't work so I'm just keeping stuff separated and testing until I know everything works. There was a bare copper ground on the back of the OEM unit I don't know what to do with, I just connected the black wire (ground) from the old harness together with the black wire in the new pioneer harness. MY PROBLEM is that when I connect the power and then turn the car on the unit doesn't do anything. I know I know I should've bought the GM stereo adapter. Any suggestions?
Add to joe81tx's Reputation
Rate the quality of this post and help joe81tx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joe81tx is offline   Reply With Quote
Old 02-24-2010, 06:53 AM   #2
Thee_Antic
Thee_Antic is on a distinguished road
Thee_Antic's Avatar
Default Re: Stereo Wiring - 2001 SL1
This might be a stupid reply so in advance I am sorry. But is it possible to just solder on the old wiring harness and still buy the new converter? Might be easier than testing each connection separately...its definitely better than what you have now lol.
Add to Thee_Antic's Reputation
Rate the quality of this post and help Thee_Antic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thee_Antic is offline   Reply With Quote
Old 02-24-2010, 09:11 AM   #3
FearsOfWar
FearsOfWar is on a distinguished road
2002 SL1
Go to any auto parts store & buy a Haynes service manual. They are about $20-25 or so, and they have the full wiring diagram the back, in addition to the service information.
Add to FearsOfWar's Reputation
Rate the quality of this post and help FearsOfWar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FearsOfWar is offline   Reply With Quote
Old 02-24-2010, 09:44 AM   #4
Low Saturn
Low Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to all
Low Saturn's Avatar
2008 AURA XE
And incorrect information and refering to years ranges that have many differences between them, but never mentioning it.
And to the OP, you might have it wired correctly, check the fuses before trouble shooting any further. All those bare wires could of shorted and blew a fuse.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevy Suburban
-2008 Saturn Aura XE V6
Im out of EGR adaptors & ECTS connectors.
Old 02-24-2010, 11:58 AM   #5
SRGW
SRGW is on a distinguished road
Post Re: Stereo Wiring - 2001 SL1
Is this of any help??
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-24-2010, 01:32 PM   #6
joe81tx
Survey says... blown radio battery fuse! The link I originally posted matches the PDF you linked, thank you! Replaced the fuse and voila, the wiring works
Old 02-24-2010, 02:05 PM   #7
Thee_Antic
Thee_Antic's Avatar
I thought my answer was stupid lol.
Old 02-24-2010, 02:31 PM   #8
adventureoflink
adventureoflink's Avatar
If you may be so kind... could you be so kind as to post pictures of your splice job, and/or at least tell us which color wires go to what?
(not convincing future hack-n-splice projects, but just curious... also doesn't the aftermarket factory harness have a diagram on the back to tell you what wires do what job?)
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive & Well
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, prolly needs front driver strut
Old 02-24-2010, 03:20 PM   #9
alordofchaos is a jewel in the roughalordofchaos is a jewel in the roughalordofchaos is a jewel in the rough
Actually, it was a good idea takes the guessing out of the picture
...Wait, what, I actually won that eBay auction?
Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p
And now (7/2010), a Craigslist 1997 SC2 5 spd
Old 02-24-2010, 07:15 PM   #10
joe81tx
Battery: larger orange
Ignition: smaller yellow
Parking lamps (changes radio from day to night): smaller brown
Ground: black
Left front (+): tan
Left front (-): larger gray
Right front (+): light green
Right front (-): dark green
Left rear (+): larger brown
Left rear (-): larger yellow
Right rear (+): dark blue
Right rear (-): light blue
I did not use the the smaller orange wire (cd changer) or the smaller gray wire (dimming level)
Old 02-25-2010, 07:49 AM   #11
FearsOfWar
2002 SL1
Fair enough. I use it in conjuction with this site for anything major.
For the most part, it's a good place to start. And the wiring diagram worked for my sound setup.
Need wiring help for '03 L series stereo paxman356 L-Series Tech 0 07-19-2008 03:22 AM
Help troubleshooting stereo wiring 92 SC & will a 98 stereo work? GmG S-Series Tech 11 11-04-2007 04:35 PM
Wiring Diagram for Stereo on '93 SL2 Leadsled Coupe S-Series General 16 03-01-2007 07:04 AM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 04-30-2005 11:45 PM
Stereo wiring TrustyOne Miscellaneous Tech 7 03-30-2003 12:03 AM
