Old 02-22-2010, 02:30 AM   #1
hholbein
1997 SW2
Default When your SW2 liftgate doesn't latch....
A common problem encountered on SWs is a liftgate that won't latch shut. This problem can happen anytime, but is more likely to happen during cold weather (<=5C/40F).
When this happens, neither the key nor the release lever will reliably get the latch to reset because it is stuck in the "open" or triggered position.
In this first post, I'll describe the problem; in the 2nd post, and how you can get it working in a manual mode (key only); the 3rd post will describe steps you can take to replace or repair the electrical actuator so you can use the driver's side remote release switch lever or the keyfob.
If your car is a 2nd-gen or 3rd gen wagon, the latch comes equipped with an electric-door-lock-style actuator made by Rockwell Controls that's remotely triggered. These stick/hang up after a modest amount of use and aren't available separately, to my knowledge. The most common failure is the actuator sticks or jams in the most extended position, and this prevents the latch from springing back to reset/relatching mode.
The 2nd and 3rd gen latches are similar and fully interchangeable; both use the same bolts, electrical connectors, and cable-to-lock cylinder cable. The 3rd gen latch has a small slider slot meant to support the actuator and prevent it from sticking when fully extended, but the idea was poorly executed by GM/supplier engineering and never corrected the problem.
Here are some pictures of the 2nd and 3rd gen latches for comparison:
The 1st and 4th pics are of the 3rd gen latch assy, the middle 2 pics are of the 2nd gen latch assy, with the actuator removed.
Add to hholbein's Reputation
Old 02-22-2010, 02:48 AM   #2
hholbein
1997 SW2
Default Re: When your SW2 liftgate doesn't latch....
To get at the latch, you'll need:
- a small screwdriver
- a mini prybar or panel puller tool
- a 14mm socket or wrench
- a screwdriver with a small Torx bit
- a needlenose pliers is handy
To get at the latch, you have to remove 4 pieces of interior trim around the liftgate, starting at the top piece surrounding the high/middle stop light; then the two side trim pieces, and then the bottom piece that includes the speaker grille openings. Push in on the center of the pushpins to lessen their grip, then gently pry them out with the prybar.
There's a Torx screw hidden in the handle recess on the right hand side. The screw is held in place with a speed nut, make sure it doesn't get lost. Lifewise, the rubber bumpers on the sides of the liftgate sometimes pop off; make sure to keep track of them as well.
Once the trim is off, you can remove the 2 14mm latch bolted to the plastic resin hatch. Reach inside and disconnect a) the actuator connector (larger, blue tip); b) the small connector to the cargo light and liftgate ajar warning bulb on the dash; c) the cable release from the lock cylinder. The cable release requires gently prying apart and loose the tanged plastic clip that holds the cable ball end in its socket. Then the cable housing pries loose from its V-slot.
Old 02-22-2010, 03:03 AM   #3
hholbein
1997 SW2
Once you have the latch exposed, check it to see if the electrical lock actuator is stuck or sticks in the extended position. If this is the case, the quick fix is to REMOVE THE ACTUATOR and see if that makes the latch reset properly.
To remove the actuator:
1) remove the two Phillips head screws holding the Rockwell actuator in place
2) rotate the actuator up and away from the latch until the white plastic loop unhooks from the black actuator arm
3) remove the black actuator arm itself by rotating it, clearing the two keyways, and then pushing it our of the socket
Make sure the key-to-cable link is properly attached and check the action with a key in the liftgate. If the latch reliably latches, reinstall the 14mm bolts and the trim.
Reattach the small connector to the light switch on the latch, and leave the actuator connector free.
You'll be able to use it reliably in manual mode until you find a replacement latch assembly, actuator, or make repairs and mods to the actuator.
Old 02-22-2010, 08:03 PM   #4
hholbein
1997 SW2
Inspecting/repairing the actuator
The following posts describe how to repair the actuator, since a new latch assembly costs $95+ and the Rockwell actuator isn't available separately (to my knowledge, anyway!)
Attached are two labeled photos of the inside of the Rockwell latch actuator. The unit primarily consists of an electric motor, a clutch, a screwshaft, and a white nylon slider. There's a vent and a sealed rubber bellows to keep dirt out of the interior.
Overall, you're trying to ID and fix things that prevent the mechanism from sliding easily in and out. The most common situation is the actuator binds in the fully-extended position.
There are a few things that go wrong with this component:
1) The vent can clog up with dust, increasing the air pressure inside the unit when it contracts, making it harder to retract. Clean it out with compressed air.
2) The plastic gear on the overrunning clutch breaks off a tooth and makes the mechanism jam. Replace the gear from another salvaged/JY unit. (Don't toss out old actuators, parts can be scrounged from them to fix other units so you end up with 1 or more working ones.)
3) The slider that mates with the screwshaft gets worn in the grooves and the screwshaft area. Clean and lightly lube the moving components with a high-quality silicone lubricant. Try flipping the slider 180 degrees and see if that changes the wear pattern/binding characteristics.
4) The white lithium grease in the journals gums up. Clean and lube with a silicone lube as above.
When you're done cleaning and lubing, reassemble the unit and 4 small Phillips screws. The rubber bellows slips over a collar, and there's a metal sleeve inside the bellows to hold the neck assembly together. Make sure the sleeve is pressed in all the way.
Test out the actuator repairs by quickly moving the white actuator in and out many times by hand, checking closely for any signs of binding. If there is still binding evident, it could mean your white plastic slider is too far worn. Try installing another from a donor JY unit.
Next, try reinstalling the repaired actuator on the metal latch body, attaching it with 2 large Phillips head screws. The black plastic actuator arm should be reattached to the actuator and latch first, however.
Reset and test fire the latch 25 to 35 times checking for any signs of binding. (You reset the latch by moving the catch in the striker groover upward 2 clicks.)
If things still look good, try the ultimate test! Stick the unit in the freezer for a 30-60 minutes until it gets to 0F/-18C. Then take it out and test fire it 15-20 times. If it still doesn't stick, you're probably ready to install the rehabbed unit in your SW. If not, continue on to the next post.....
Old 02-23-2010, 07:17 PM   #5
hholbein
1997 SW2
The last straw, fixing the remote latching mechanism....
If you scrounge one of the later 3rd gen latches from a junkyard SW, and the actuator still occasionally hangs up in the extended position, try this modification.
The 3rd gen latch adds a slider guide to the actuator arm that rides in a metal track. It seems that GM engineering ID'd downward strain on the actuator arm as the source of the binding. HOWEVER, there's a lot of slop in the track-to-slider guideway, so the metal track doesn't adequately support the actuator arm and it continues to hang up.
Try narrowing the gap 2mm or so by bending in the L-shaped guide. I did this by hitting it on a flat metal surface with a hammer. I then smoothed out the metal raceway with a Dremel motor tool cutting disk. The Finished up with a light coating of synthetic grease to the track and slider pin/guide.
Reassemble the latch with the actuator and retest several times to see if there's any binding. Try the freezer test (above) to make sure it's working well. Then reinstall.
Old 09-02-2013, 03:32 PM   #6
1996SW2
1996SW2 is on a distinguished road
Removing the actuator was a nice, easy, redneck fix for a very annoying problem. I can actually use the back hatch area now. Im perfectly content with using the key but i may just open up the actuator and tinker with it. Thank you for taking the time on this post. My only word of caution is, with all clipped interior panels, be patient and don't force it or you will break something.
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 09-04-2013, 01:01 AM   #7
hholbein
1997 SW2
Glad you found this old post of use. I've got several years now on the modded Gen3 latch I installed in my SW2, with no problems -- except dirty keyfob contacts, in which case the key works just fine.
Old 12-17-2015, 12:38 AM   #8
Carl26
Carl26 is on a distinguished road
Carl26's Avatar
Thanks for the write up hholbein. I just fixed latch on my 2000 Saturn SW2 this evening. The problem I was having was that the liftgate wouldn't latch. It turned out that my actuator wasn't retracting.
I took the actuator apart, cleaned the old grease off the ends of the screw shaft and re-greased. The culprit on my latch was that the plastic sleeve under the rubber bellows came off of the housing of the actuator. It was "floating" around inside the rubber bellows which interfered with the retract movement of the shaft.
Very simple fix. The hardest part was pulling off the large lower plastic trim piece that has the speaker grilles on it. With the liftgate open, that trim piece pulls straight down for removal.
Add to Carl26's Reputation
Rate the quality of this post and help Carl26 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Carl26 is offline   Reply With Quote
Old 12-17-2015, 12:49 PM   #9
hholbein
1997 SW2
Awesome. Glad none of your gear teeth got chewed up when it hung up.
The Gen-3 latches aren't great, but the extra support for the actuator makes them more robust than the Gen-2 latches.
Old 01-28-2017, 01:43 PM   #10
DBL
DBL is on a distinguished road
1997 SW2
1997 SW2
The latch on my 1997 SW2 was also not locking and it ended up being the electric actuator sticking so I replaced it with the one from my parts car. Works great now. Thanks for the info!
Add to DBL's Reputation
Rate the quality of this post and help DBL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DBL is offline   Reply With Quote
Old 02-03-2017, 05:43 PM   #11
hholbein
1997 SW2
You're welcome. Happy motoring!
Old 02-10-2017, 10:43 PM   #12
TomM96
TomM96 will become famous soon enough
thankyou , h holbein !
Add to TomM96's Reputation
Rear liftgate james Outlook General 6 09-27-2009 08:17 PM
97 SW2 liftgate latch source? postmortal1 S-Series Tech 3 08-15-2009 07:17 PM
Rear liftgate latch on a Gen 2 SW2 hholbein S-Series Tech 0 04-24-2009 01:20 AM
liftgate latch adjustment 95 SW2 cognomen62 S-Series Tech 10 03-07-2009 12:57 AM
Liftgate repo_man62 Vue Tech 1 10-31-2007 11:56 PM
