Old 02-19-2010, 01:41 PM   #1
kim_lombard
kim_lombard will become famous soon enough
Default P0300 Random Misfire detected - What to do???
I have a 2005 ION Quad Coupe. It ran GREAT. Parked over night, now when started it sounds likes it's running on 3 cylinders. Idles rough, after 2 or 3 minutes at idle the check engine light came on.
I plugged in a new Equus 3140 Innova Diagnostic Code Scanner for OBDII Vehicles (canbus compatible) and got a p0300 dtc.
As I said, this car was running GREAT. It's been well maintained with 55k miles by saturn. I hate to tow it to the dealer. They are some distance away and the cost of the tow alone is going to exceed $100.00.
We had a problem with the fuel pump at around 30k and it wouldn't start at all - under warranty the dealer replaced the fuel pump and even picked up part of the towing.
What can I check? I pulled the plugs, one looks blacker than the rest. I don't think its a compression problem, because as I said on Sunday we were driving all over the place, then Monday morning - started rough first thing. I haven't driven it yet and it's still in the driveway.
Thanks
Add to kim_lombard's Reputation
Rate the quality of this post and help kim_lombard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kim_lombard is offline   Reply With Quote
Old 02-19-2010, 01:45 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: P0300 Random Misfire detected - What to do???
FYI, you can flat tow ions. get a good tow strap and slowly make your way to the dealership that way if you must. any SUV, minivan, or small truck should be able to pull an ion. as far as common causes, the coil pack and ICM, replace both and the plugs all at the same time if you do, one can take out the others. if you do this, but it still acts up, tow it to saturn.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 02-22-2010, 11:40 PM   #3
TravDawg618
TravDawg618 is on a distinguished road
2003 ION-2 Sedan
I thought a P0300 was caused by a clogged converter?Try it.And like 2006 above me said.Check the coil packs and change the plugs.Drive it around and then pull the one plug that was black and see if its black again.Probably losing compression.Then take it to the dealer.
Live Fast Die Fun
Add to TravDawg618's Reputation
Rate the quality of this post and help TravDawg618 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TravDawg618 is offline   Reply With Quote
Old 03-05-2010, 11:31 AM   #4
kim_lombard
Thumbs Up Re: P0300 Random Misfire detected - What to do???
So, just to follow up on this posting.
Problem SOLVED!
I removed the fuel rail. Cleaned the injectors. Replace spark plugs. Replaced the Ignition Coil Pack.
Once reassembled, it started right up. Idles smooth, just like new.
Thanks
Old 03-05-2010, 12:07 PM   #5
Ion Greatest
Ion Greatest is on a distinguished road
P0300 is a multiple misfire code. P030x where x is the specific cylinder the misfire occurred.
My first thought would be the ICM. Seems to be more often than not the misfire problem on the Ecotec's
Add to Ion Greatest's Reputation
Rate the quality of this post and help Ion Greatest reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ion Greatest is offline   Reply With Quote
Old 03-05-2010, 01:58 PM   #6
2006 ion2
2007 ION-2 Sedan
you missed the problem, man, they fixed it already. though, if you didn't replace the ICM (the silver heat sinked part married to the coil pack) you really should.
2007 Saturn Ion 2
Old 03-05-2010, 03:24 PM   #7
Ion Greatest
I know I saw that but with the collection of parts tossed on, it didn't really say which part fixed it. My bet would have been on the ICM. Been there once already!!
Old 03-05-2010, 04:39 PM   #8
2006 ion2
2007 ION-2 Sedan
yeah. the way I've seen it in person, and by what has happened on here, with GM's coil pack between the cam system (tech 4 and 03-06 2.2 ecotec) one likes to take out the other, and should be replaced as a unit.
2007 Saturn Ion 2
Old 03-05-2010, 06:15 PM   #9
Ion Greatest
My ICM went but the coil pack was fine. Had to drive almost 20 miles home on 2 cylinders. Tested a brand new coil pack from AZ and also did plugs but didn't change the way it ran. The guy at AZ was cool about it, told me to bring the pack right back if it didn't fix it. Usually electronics and electrical parts you can't return. Had to wait for the dealer to open the next day to get an ICM. At least it was easy to get to and replace. Sux that it costs $100
Old 03-05-2010, 07:35 PM   #10
2006 ion2
2007 ION-2 Sedan
you are lucky only one went bad.
2007 Saturn Ion 2
Old 07-03-2016, 02:23 PM   #11
rjj15
rjj15 is on a distinguished road
Happy Re: P0300 Random Misfire detected - What to do???
I have a 2003 Saturn ion. got p0300 code 2 days ago. Replaced air filter, sprayed off Mass air flow sensor. Sprayed some engine tune up. better but still threw codeand not much power.
I replaced spark plugs. Good to go now. I check the old plug gap which was .080 on all 4. gap on new ones are .043. Anyone else have this issue? Is .080 a huge problem?
Add to rjj15's Reputation
Rate the quality of this post and help rjj15 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rjj15 is offline   Reply With Quote
Old 07-09-2016, 07:01 AM   #12
2006 ion2
2007 ION-2 Sedan
That could do it, watch it and make sure the code doesn't return. If it does, you likely have a bad coil pack/icm
2007 Saturn Ion 2
05 ion p0300 multiple/random misfire pimp05ion Ion General 4 05-18-2009 01:24 AM
05 ion p0300 multiple/random misfire pimp05ion Ion General 0 05-15-2009 10:20 PM
P0300 - random cylindar misfire after replacing timing chain kim_lombard Ion Tech 6 07-21-2008 08:51 AM
P0303 - Cylinder #3 Misfire Detected d4rkf1ber S-Series Tech 2 11-30-2006 07:13 PM
Random misfire (P0300) under heavy load 98greenSC2 S-Series Tech 11 03-03-2005 01:06 AM
