Old 02-16-2010, 10:03 PM   #1
Tjflow
Tjflow is on a distinguished road
Default CLutch master cylinder/slave cylinder removal
When changing a clutch is there any way to take the slave cylinder out without damaging it and haveing to replace it? when you remove the slave cylinder from the transmission the rod comes out and you have to replace the whole $130 unit i am being told.
Add to Tjflow's Reputation
Rate the quality of this post and help Tjflow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tjflow is offline   Reply With Quote
Old 02-16-2010, 10:16 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: CLutch master cylinder/slave cylinder removal
Just put the rod back in. If it comes out it doesn't mean the hydraulic assembly is broken. If the diaphragm inside that pushes the rod breaks, then you have a problem.
Also just dont yank the slave cylinder out once you disengage it from the transmission. Pop is off then use your fingers to guide the pin out as you remove the slave cylinder.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 02-16-2010, 11:06 PM   #3
Also prop the pedal in its uppermost position to avoid accidentally activating the hydraulics, and keep the slave below the master at all times during the transition.
Add to madpogue's Reputation
Old 02-17-2010, 12:31 AM   #4
rc1488
rc1488's Avatar
I zip tie it between the fuse box and metal rail. Have had no issues with it there on any of my 123434234 tranny/engine swaps.
Add to rc1488's Reputation
Old 02-17-2010, 07:37 AM   #5
DonP
I've heard you can get a replacement plastic rod retainer from a dealer, but have not had occasion to try get one.
Add to DonP's Reputation
Old 02-17-2010, 08:48 AM   #6
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2003 VUE 2.2L
+1 above. You will have no problems removing the slave and reinstalling it after the new clutch is in. Search for some of my clutch problems in the S-series tech because I've had some interesting ones.....
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 02-17-2010, 12:19 PM   #7
In case you haven't seen these in the How To library:
ShawnV's How To: Clutch Hydraulic system with pics
mavmav's Filling the Clutch Master/Slave Cylinders without 'Bleeding'
BarnOwl's Clutch Hydraulics Diagnosis
Clutch Hydraulic System Replacement [from FSM]
Old 02-17-2010, 04:43 PM   #8
MikeNW
MikeNW's Avatar
1997 SL
what they said /\ The rod will stay in position long enough for you to install the slave, and seat the end of the rod in the clutch fork.
08 Burgman 400
Add to MikeNW's Reputation
clutch master/slave cylinder noise losttxn4evr S-Series General 3 05-16-2009 10:32 AM
Clutch master/slave cylinder replacement AJT_Leo S-Series Tech 16 09-03-2007 05:19 AM
Need help with clutch slave/master cylinder 1999 SL 2tirefire L-Series Tech 2 12-06-2006 10:42 AM
Clutch Master/Slave Cylinder blackeagle1 S-Series Tech 5 10-22-2006 07:13 PM
Should I throw away my old clutch master/slave cylinder? irish56 S-Series Tech 2 12-19-2002 12:31 PM
