Old 02-01-2010, 09:37 PM   #1
saturnsduke
saturnsduke is on a distinguished road
Dizzy Saturn fuel shut-off, security system?
I have a 2001 Saturn sedan that cranks but won't start, it seems to me the fuel is shut-off by the security system maybe. My kid moved my car and can't get it started since he was in there.
So now, how do I reset the thing to get the fuel back on? Please help, very frustrated. susanjduke yahoo com
Add to saturnsduke's Reputation
Rate the quality of this post and help saturnsduke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnsduke is offline   Reply With Quote
Old 02-01-2010, 09:38 PM   #2
Mgg4591
Mgg4591 is on a distinguished road
Mgg4591's Avatar
Default Re: Saturn fuel shut-off, security system?
Did you check the fuel pump fuse?
Add to Mgg4591's Reputation
Rate the quality of this post and help Mgg4591 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mgg4591 is offline   Reply With Quote
Old 02-01-2010, 09:46 PM   #3
saturnsduke
Nope, where is it. I do not have the owner's manual for this car. Also, I'm new here. Can somebody tell me the link to the how-to tips library on here?
Old 02-01-2010, 10:19 PM   #4
Mgg4591
Mgg4591's Avatar
What model is it? On the s-series the fuel pump fuse is located in the car on bottom right side of the center console. You have to pop off the plastic access panel. See the pic below. Its the little red one under the gray relay. Its circled.
Old 02-01-2010, 11:50 PM   #5
saturnsduke
You are awesome! Thank you, I will check that fuse.
Old 02-01-2010, 11:55 PM   #6
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Is the security light on?
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 02-02-2010, 12:05 AM   #7
saturnsduke
Yes it is on at times. But sometimes it goes off. Car cranks fine, just no fuel.
Old 02-02-2010, 12:27 AM   #8
hoseppi
hoseppi's Avatar
2002 SL1
2008 Astra XE
Can you hear the fuel pump running when you first turn the key on? Normally, if it's a security issue, the engine will start and run for a second or so, but the fuel pump will still run. Security issues don't shut off the fuel pump but it will shut down the injectors after detecting a problem. Which model are we talking about?
Old 02-02-2010, 11:13 AM   #9
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Was the car doing anything else strange before (Like alarm going off for no reason, gages not working for a few seconds).? If so your BCM could have failed and done so when the alarm was on.
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline   Reply With Quote
Old 02-03-2010, 06:50 PM   #10
spork
spork is on a distinguished road
spork's Avatar
Get your key replaced. That pretty much took care of that issue for me. You will still have to go through the reset procedure though.
If the security light is on continuously, you can try to do a passlock relearn. What you will need to do is momentarily turn the key to the start position and release it. Leave the key in the on position for 10 minutes, the security light should go out at this time. Then turn the key off for 10 seconds. Repeat this 2 more times for a total of 3 times. If there are no other passlock problems, the vehicle should crank and run.
Read more: http://www.justanswer.com/questions/...#ixzz0eWIihA51
"Don't blame me, I voted for Kodos"
Add to spork's Reputation
Rate the quality of this post and help spork reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spork is offline   Reply With Quote
Old 02-03-2010, 09:53 PM   #11
hummrH2o
hummrH2o is on a distinguished road
2002 L-Series 3.0L Sedan
2002 SL
Any more on this would be great I am having the exact same problem with my 2002 l300. It will turn over but it will not start. I was thinking fuel pump. Checked the fuses, that didnt help. Also Im thinking maybe the crankshaft position sensor. Any more help would be great!
Add to hummrH2o's Reputation
Rate the quality of this post and help hummrH2o reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hummrH2o is offline   Reply With Quote
Old 02-27-2010, 12:13 PM   #12
Siestabob
Siestabob is on a distinguished road
This seems to be a standard problem. I have a 2000 Saturn l series and I have to do the 10 min wait while I leave the key in the run position and the security light is on. Usually starts after 10 mins. There has to be a solution. There is no reason why it happens that I can find. It's random.
Add to Siestabob's Reputation
Rate the quality of this post and help Siestabob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Siestabob is offline   Reply With Quote
Old 02-27-2010, 12:30 PM   #13
Siestabob, are there any aftermarket alarm systems or remote start? Tried the spare key?
Your Passlock anti-theft sensor unit is part of the ignition switch assembly that detects theft attempts. Sometimes a worn key may trigger a false security alarm.
Old 03-04-2010, 10:03 PM   #14
IONicSaturn
IONicSaturn is on a distinguished road
IONicSaturn's Avatar
2001 L-Series 3.0L Wagon
This sounds like the exact same thing that had been happening to my 2005 L300 a few months back. The engine would crank, but wouldn't turn over. I took it to my local dealer and they first diagnosed it as a bad ignition switch, replaced that and it continued to crank but not start. Brought it back in the same day and they said it was the Body Control Module. Got the car back two days later and it STILL would crank but not start, this time they said it was a Powertrain Control Module. I declined that repair and one evening over that weekend I tried starting the car and it wouldn't even crank. After the third attempt, the dash lights and ignition chimes started going on and off furiously while I tried starting the car. I disconnected and reconnected the battery and the car started up fine. I brought it to another dealer, one that I have a LOT more confidence in, and they said to use another key because the key I was using was so worn that it wasn't making enough contact in the ignition and it was triggering a "theft code." Sure enough, ever since then (knock on wood), it's been fine.
Mike
2012 Nissan Maxima SV Sport
2005 Saturn L300
1999 Dodge Durango SLT
Add to IONicSaturn's Reputation
Rate the quality of this post and help IONicSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IONicSaturn is offline   Reply With Quote
Old 07-22-2011, 08:23 AM   #15
kari1232
kari1232 is on a distinguished road
It was the key!!!
Thank you to the person that posted they had everything changed and come to find out it was the key. I had 3 machanics look at my car (1 from the dealership) and one I asked about the key (not the dealership) and he said the key did not look warn but I could try getting a new key using the vin number at the dealership. If you are having this trouble start with the key!!
Add to kari1232's Reputation
Rate the quality of this post and help kari1232 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kari1232 is offline   Reply With Quote
Old 07-05-2015, 08:52 AM   #16
Susan1123
Susan1123 is on a distinguished road
[QUOTE=spork;1578989]Get your key replaced. That pretty much took care of that issue for me. You will still have to go through the reset procedure though.[/QUOTE
WHERE CAN ONE GET A NEW KEY FOR A 2002 SATURN L100 2.2L, The car starts and can drive, but all the needles on the dash go crazy, don't know what to do. Thank you!
Add to Susan1123's Reputation
Rate the quality of this post and help Susan1123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Susan1123 is offline   Reply With Quote
Old 07-05-2015, 08:56 AM   #17
Susan1123
Where can I get a NEW KEY FOR A SATURN 2002 L100 2.2L the car starts and will drive with the security light on, and then all the needles on the dash go crazy, PLEASE HELP, DON'T KNOW WHAT TO DO, CAN YOU DRIVE THE CAR LIKE THIS OR WILL IT STOP WHILE DRIVING! THANK YOU!
Old 07-05-2015, 10:32 AM   #18
pierrot
pierrot's Avatar
Any GM dealership should be able to cut a new key for you. You may also be able to utilize any other shop which can cut keys, an auto parts store or hardware store.
As to whether or not, or how long one can continue to drive a car with the dash console behaving erratically is anyone's guess and many times this relates to a failing BCM (Body Control Module). This is a secondary computer which communicates with the PCM (Powertrain Control Module - manages all engine and transmissions functions) and monitors all other non-engine related functions, i.e., information to the dash console, security system, door locks, interior lighting when the car is locked or unlocked.
For BCM problems search the threads in these L Series Forums, there are plenty to be found. Perhaps a new key will correct this problem, but if not, then at least you will know that it's not the source of it.
279,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 07-05-2015, 10:47 AM   #19
Susan1123, you may have two separate problems; a worn ignition key and possible faulty body control module. It's suggested to have new keys made from a GM dealer using your car's VIN to avoid copying a worn key. This may not correct a faulty BCM issue causing the needles in the instrument panel to go crazy. Other than controlling security, the bcm won't prevent the engine from running. A hard failure of the bcm would be enabling Passlock, GM's security system disabling the engine from running; Passlock disables injector operation to prevent stealing a car.
The security system is keeping my 2001 Saturn from starting mister saturn S-Series Tech 16 04-29-2016 10:40 AM
OEM Security System TXSaturn02 S-Series Tech 5 11-24-2009 10:30 PM
Security System and Fuel Cut Out kiowa59 S-Series Tech 5 03-03-2007 07:41 PM
Security System MtnVUEShadow Vue General 8 05-10-2004 07:14 PM
Saturn Security System edwilson13185 General Saturn Discussion 7 03-20-2001 07:16 AM
