Old 01-31-2010, 03:21 PM   #1
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
Default fuel mileage and fuel injector disconnection
sort of like running on 3 cylinders
yes you have pumping losses.
perhaps rougher running sort of like a miss, but no fuel is getting used for that cylinder.
I was wondering if fuel usage would drop. And this might be a better idea for highway usage.
Cylinder deactivation is now called Active Fuel Management.
http://en.wikipedia.org/wiki/Active_Fuel_Management
Add to sdowney717's Reputation
Rate the quality of this post and help sdowney717 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdowney717 is offline   Reply With Quote
Old 01-31-2010, 03:49 PM   #2
Default Re: fuel mileage and fuel injector disconnection
Engines that have it as a feature are progrmmed for it.
Your car would see it as a problem. Misfire codes. Lean codes. The rest of the cylinders would possiblely richen up to get the exhaust up the the wanted air fuel mix that the O2 sensors expect to see.
Add to ssicarman's Reputation
Old 01-31-2010, 07:19 PM   #3
jss21382
jss21382 will become famous soon enough
1993 SL2
Yeah, The additional oxygen in the exhaust because of the pumping that's still occurring will throw the readings far to the lean side, so you'd lose any gains with the attempted correction for the lean condition.
The only way you'd be able to get it to work correctly would be to figure out how to deactivate the cylinder. Both the Honda and Chrysler systems deactivate the valve train for the deactivated cylinders, effectively making the cylinder into an air spring, which largely negates the pumping losses as well as eliminating the exhaust gas oxygen issue.
Add to jss21382's Reputation
Rate the quality of this post and help jss21382 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jss21382 is offline   Reply With Quote
Old 01-31-2010, 07:52 PM   #4
aaron95sl2
aaron95sl2 is on a distinguished road
aaron95sl2's Avatar
We need to replace camshafts with solenoids (not on Saturns, but on engines in general). Then instead of the timing chain/belt breaking and smashing valves against pistons, a solenoid would fail closed (due to spring pressure), the computer would throw a code to indicate which solenoid failed, and you'd simply pop off the valve cover to swap out a solenoid. And you could buy more expensive solenoids that would open the valves farther and faster for increased performance, instead of rebuilding your mechanical valve train.
Not to mention it would probably use less energy to operate than our chain-driven valve-trains, and the car would most likely still be temporarily drivable with a stuck solenoid, unlike a broken belt/chain.
Then when little power is needed, the engine could shut off 3/4 of it's cylinders by killing the injector and spark and closing the exhaust valve.
But it's only 2010, it's not like we can put a man on the moon or 1,000 songs on a tiny little card or browse the internet from some sort of wirelessly-connected hand-held device. And gas is dirt cheap, so it's not like we need to make engines more efficient.
1995 SL2 | Fully loaded | 165k on odometer |30k on new engine w/ KB-S pistons - not a single drop of oil lost so far!
Add to aaron95sl2's Reputation
Rate the quality of this post and help aaron95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aaron95sl2 is offline   Reply With Quote
Old 02-01-2010, 12:06 PM   #5
jss21382
1993 SL2
The technology has been here for a long long time. It's just a matter of production cost and reliability. Timing chains, for the most part last for a reasonable amount of time, provided you change the oil and design the system properly(don't look at the ecotech for that...) Camshafts, buckets(or lifter and rocker), and chains are very inexpensive to manufacture, compared to using 16 solenoids on your 4 cyl, 24 on the 6, and 32 on an 8 cylinder. Not to mention you've just added 16-32 individual electrical parts to fail in an engine.
Fuel Injector / Fuel System cleaners AJT_Leo S-Series Tech 2 07-09-2007 03:30 PM
Bad Fuel Injector lhwilliams Community Center 1 04-14-2007 08:24 PM
Fuel Injector rjnewt S-Series General 3 12-05-2006 12:47 PM
WTB Fuel Injector SL2 nmsaty Classifieds 2 04-20-2006 03:59 PM
fuel injector jaylie S-Series Tech 1 09-26-2005 12:56 PM
