Old 01-31-2010, 11:43 AM   #1
yzracer14
yzracer14 will become famous soon enough
Default Thermostat Extension pipe / coolant pipe
Does anyone know where to get another one of these? My original one has a large crack on both sides of it and cannot be reinstalled.
Add to yzracer14's Reputation
Rate the quality of this post and help yzracer14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yzracer14 is offline   Reply With Quote
Old 01-31-2010, 11:47 AM   #2
Default Re: Thermostat Extension pipe / coolant pipe
Tried rockauto.com or saturnparts.net yet? There are many places to shop, maybe Autozone online even.
Old 01-31-2010, 12:07 PM   #3
yzracer14
yes, i have tried all three of those websites with no luck. All my local saturn dealerships' parts departments are closed today so I was hoping someone here on the forum knew an online source.
Old 01-31-2010, 03:19 PM   #4
yzracer14
Thanks for your help but i ended up finding one on ebay. This part is used on a bunch of other types of vehicles, some of them I've never even heard of before. But the main one it's used on is a SAAB 900 from 1994-1998. I found a website that sells them for $63.00 as well as the related o-rings. I'll post the website up later as well as the part number. I ended up finding it on ebay for $35.00 with free priority.
Old 01-31-2010, 03:42 PM   #5
Hmmm, I'll have to add "e-bay" into the list of sources.
Old 02-01-2010, 08:51 AM   #6
yzracer14
I doubt anyone will ever need this info because I'm pretty sure my incident was a freak accident, but hey, you never know. The part number for the pipe that connects the thermostat to the upper radiator hose is 90411629.
thesaabsite.com/900new/NG900coolingheating.htm
(can't post full URL yet)
There is a website I found where you can get that part along with the o-rings. The part is almost exactly half way down the page.
Old 02-01-2010, 11:40 AM   #7
Someclown
Someclown is on a distinguished road
Someclown's Avatar
2002 VUE 3.0L
A freak accident, This may be a helpful find as the lobes for the bolt which fastens the extension pipe to the block tend to break off of these pipes if you look at them the wrong way
Add to Someclown's Reputation
Rate the quality of this post and help Someclown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Someclown is offline   Reply With Quote
Old 03-25-2013, 11:12 AM   #8
m1super90
m1super90 will become famous soon enough
Yes, I broke the bolt hole tab off of mine and had to replace it. The girl at the dealership working the parts counter happens to be a wrencher and said they break them all the time in the shop.
Also, I took this part to a local welder thinking it was aluminum. He informed me it is made of ZINC! Is this thing supposed to serve as a sacrificial anode? Be better just to drop one into the overflow tank!
Add to m1super90's Reputation
Rate the quality of this post and help m1super90 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
m1super90 is offline   Reply With Quote
Old 05-26-2014, 03:51 PM   #9
rottenmiller
rottenmiller is on a distinguished road
I also broke the tab off the thermostat extension tube on my 02 Vue and it still wont come out of the themostat housing Any suggestions? Thanx
Add to rottenmiller's Reputation
Rate the quality of this post and help rottenmiller reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rottenmiller is offline   Reply With Quote
Old 05-26-2014, 07:50 PM   #10
m1super90
Put a pipe wrench on it and twist/force it out. It's scrap now that you've broken the tab of anyhow. Or, drill a hole clean through it and insert a big long screwdriver shaft to twist and force it out. Just make sure the T-stat housing is firmly bolted down first so it doesn't get damaged.
Old 05-26-2014, 11:03 PM   #11
Chazberry
Chazberry's Avatar
1995 SW2
The ACDelco 1510580 Housing comes with a T'stat.
The Ext. Pipe is GM Pt # 90411629
The O-rings are GM Pt # 9129999
Add to Chazberry's Reputation
Thermostat extension pipe bolt pupilot007 L-Series Tech 0 01-14-2008 01:29 PM
Front exhaust pipe cracked at pipe-to-engine stiffener clamp JohnHupp S-Series Tech 2 07-28-2007 11:18 AM
What size exhaust pipe for the flex pipe? turbobuick33 S-Series Tech 4 03-10-2007 04:46 PM
front exhoust pipe/down pipe, same thing? xupthree60 S-Series General 4 08-01-2006 04:54 PM
Down Pipe/Header Pipe/Flex Pipe/Front Pipe Carriere S-Series General 6 05-12-2006 08:44 PM
