Old 01-26-2010, 06:04 PM   #1
hein
hein is on a distinguished road
1995 SW2
1998 SW2
Default Whining Center Support Bearing - Time for replacement
Over a year ago the center support bearing in my 06 RL Vue AWD started whining. I believe that I was able to quiet it down by injecting grease into it. But it has continued to whine from time to time so I'm almost convinced there is something else going on. I've got the kit which includes the bearing and new u-joints and I am preparing to install it.
I've noticed that the clearance between the drive shaft and the bearing housing is quite small. (picture below) I've always thought maybe a pebble could get stuck in there and make the sound we hear. (Right now there is plenty of grease for a pebble to get stuck in but it has been much cleaner and still whined) It's intermittent and seems to crop up more when we drive on sand covered roads in winter. Just a thought.
I am going ahead with replacing the bearing and might fabricate a shield to go around that area of the drive shaft. It seems positioned in a place where it could catch a lot of splash & debris from the front tires. The instructions that come with the kit (#12574208) are quite limited and don't include torque specs for fasteners. It does say to mark the 2 propeller shafts to keep them in phase/balanced. New part below. Is it just me or does that look a lot like a funnel to lead crap into the bearing seal. And there are some slots in the rubber on the back side that look like a good place for a pebble to get suck.
If someone could post up more detailed information about the removing/installing the drive shaft including torques specs that would be wonderful.
Add to hein's Reputation
Rate the quality of this post and help hein reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hein is offline   Reply With Quote
Old 01-27-2010, 05:27 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Whining Center Support Bearing - Time for replacement
hein ... I have prop shaft replacement files for my 05 Vue ... I can email if you want to look them over. I have your email address from Oct 2009 - let me know if its still valid - and you want me to send.
Old 01-27-2010, 05:36 PM   #3
newbievueowner
newbievueowner will become famous soon enoughnewbievueowner will become famous soon enough
2006 VUE Red Line
I can tell you that if you live in an area where they throw a lot of salt down on the roads in the winter, the drive shaft will be a bear to get apart.
Don't grab the yoke ears with any puller as you could potentially distort/bend them. You will need a hydraulic beam press and proper support under the bearing to get the old one off.
I did mine in the fall and it was fun.
Add to newbievueowner's Reputation
Rate the quality of this post and help newbievueowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
newbievueowner is offline   Reply With Quote
Old 01-27-2010, 09:15 PM   #4
hein
1995 SW2
1998 SW2
Thanks, email has not changed.
Oregon doesn't use salt but I drove it to the South Texas Coast once. That's when it started whining. I soaked it with PB blaster. Hope it comes apart.
Old 01-27-2010, 09:38 PM   #5
vhayduk
vhayduk is on a distinguished road
2002 VUE 3.0L
I just did this job a month ago; it was a fun one.
The 10 ton press wasn't enough; I had to use the 50 ton + heat The torch caught the remainder of the rubber isolator on fire... such a lovely smell!
My problem wasn't getting the bearing out, it was getting the yoke off the splined portion of the drive shaft. Once the yoke was off, the bearing was a joke.
Vince
Add to vhayduk's Reputation
Rate the quality of this post and help vhayduk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vhayduk is offline   Reply With Quote
Old 01-28-2010, 01:47 PM   #6
Someclown
Someclown is on a distinguished road
Someclown's Avatar
2002 VUE 3.0L
Vince
Yes the yoke was the fun part to remove and the burning rubber reminded me of the race track
Hein biggest factor here, remember to scribe a line on all parts that will be separated, rear rdm yoke to prop shaft yoke, front ptu flange to ptu (power take-off unit), and prop shafts before separating and make sure the lines do not get removed while doing repairs
GooD LucK
Add to Someclown's Reputation
Rate the quality of this post and help Someclown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Someclown is offline   Reply With Quote
Old 01-28-2010, 04:13 PM   #7
hein
1995 SW2
1998 SW2
Easy part is done: Drive shaft is out, U-joint out, yoke clip out. Everything marked to maintain balance. Heated the yoke and sprayed it again with the PB. Now I'm off to my wife's workplace to use their press. She works in the office at the COOP and they have a tractor service dept.
I'm going to do the other U-joint (RDM end) also. It's due.
Old 01-28-2010, 04:22 PM   #8
Someclown
Someclown's Avatar
2002 VUE 3.0L
For the price what the hey your right there anyway if you don't do it now it will probably go not long after.Tractor service dept. should be able to press that yoke off without issues there!!
Old 01-28-2010, 06:15 PM   #9
hein
1995 SW2
1998 SW2
I've been shopping for a rear u-joint. Rock Auto shows PRECISION Part # 409 which has a grease fitting. (see picture) The OEM U-joint supplied with my support bearing kit does not have a grease fitting. So I am ordering two. My local NAPA quoted $60 ea plus freight from Sacramento. The other local parts house that carries PRECISION could not get it from their warehouse. I could go to the Chevy dealer nearby but I'd rather have the one with a grease zerk. Can someone check if ACDELCO Part # 45U0188 {#19161810} has a grease zerk? No picture of it at Rock Auto.
Old 01-28-2010, 06:28 PM   #10
newbievueowner
2006 VUE Red Line
Vince
That's what I meant. The Yoke. Getting the bearing off is not too difficult.
I actually had to CUT my bearing off with a grinder and a cut off disk. This was to gain access to the yoke.
Old 01-28-2010, 06:33 PM   #11
newbievueowner
2006 VUE Red Line
Honestly, I would not worry about the grease fitting. I have the #409 and pumped some grease in it but now am regretting that as when it's really cold out it seems to throw the drive shaft out of balance (ie: vibrates until it warms up a little). This is just a guess but it does not do this when the temps are 30*F or warmer. I'm going to change it out with another new one in the near future and see if it goes away or not.
Old 01-28-2010, 06:48 PM   #12
hein
1995 SW2
1998 SW2
They are already on the way from RockAuto. Certainly a little grease can't throw the drive shaft out of balance. Can it? -Unless it is moving the cross off center. Did you do the Center Support Bearing? Which clips did you use? Yellow or black?
Old 01-28-2010, 07:00 PM   #13
newbievueowner
2006 VUE Red Line
Yes, I had made my own center support bearing and installed it after mine failed (ie: fell apart). The OEM ones are design flawed as far as I'm concerned.
The Precision U-joints only come with 1 set of clips, so there is no choice. The u-joints are tight though.
One thing you will need to do is finish pressing in the rubber seals in the caps. You will see when you get the parts. Federal Mogul should be ashamed of themselves as far as I'm concerned!
Old 01-28-2010, 07:46 PM   #14
hein
1995 SW2
1998 SW2
Agree. The thing looks flimsy. Can you show me what you made? The u-joints won't be here until next week so I have some time to do some design/machining work.
Old 01-28-2010, 08:39 PM   #15
newbievueowner
2006 VUE Red Line
Not really, sorry, as it's on the vehicle now and it's 0*F outside.
I thought you bought the OEM mount kit already?
Old 01-28-2010, 09:57 PM   #16
hein
1995 SW2
1998 SW2
No problem. I am curious how you allowed for flex as the drive shaft swings up and down with the rear suspension. I'll probably just install the OEM bearing and hope it lasts. I didn't make it to the press yet but took some time to trim away most of the rubber so I can get a split plate around it.
Old 01-29-2010, 10:54 AM   #17
Someclown
Someclown's Avatar
2002 VUE 3.0L
I had to leave the zerk out of my u-joint as it was going to hit the joint as it rotated and flexed with the rear suspension. I installed it,
greased it, removed zerk and cleaned and put silicone in the zerk hole not much choice and hope it holds till spring when I will remove the shaft again for the summer anyway.
Those OEM supports are really cheesy I think they made them with recycled tire tubes I always wondered were those tubes went from all those blasting matts they make LOL, with my made support I can at least take out just the bearing and replace or grease it when necessary without damaging the rubber bearing mount.
Make sure to put some good never seize on the shaft before you install the bearing and yoke.
Old 01-29-2010, 11:22 AM   #18
hein
1995 SW2
1998 SW2
Interesting. Any chance a smaller zerk would help? Does your mileage improve with the prop shaft removed? I was going to drive another vehicle on a short trip I have planned for this weekend. Maybe I'll just leave the drive shaft out and see for myself.
Old 01-29-2010, 11:40 AM   #19
Someclown
Someclown's Avatar
2002 VUE 3.0L
I do all I can to keep the gas mileage up but don't keep track, I just fill the tank, I think Mrs.Clown said about 500 or 600 kms/tank but not sure which vehicle she was talking about as she drives an olds also, I will have to start keeping track.If it saves you gas its probably not much but saves some fatigue on the scrap metal they call a prop shaft and some wear and tear on the u-joints, and support bearing and I don't need AWD in the summer I have a 4x4 for that.
If you leave the shaft off just put some push plugs in any threaded bolt holes so you dont damage the threads, besides that it perfectly fine to drive like that.
Old 01-29-2010, 11:45 AM   #20
Someclown
Someclown's Avatar
2002 VUE 3.0L
I didn't have any other zerks to try at the time this is why I just siliconed the zerk hole closed
Intermediate Axle Support Bearing Bad? steelmanwy S-Series Tech 83 08-23-2016 12:06 PM
Center Support Bearing Part Unavailability Eazy340 Vue General 19 12-28-2010 10:29 AM
AWD Vue Center Support Bearing 02 Dawg Vue Tech 2 08-05-2009 09:33 PM
Intermittent Noise from front of car (possible center bearing?) Drag Limited S-Series Tech 25 12-11-2008 07:21 PM
AWD support bearing on drive shaft Ritz Vue Tech 0 10-13-2008 08:33 PM
