Old 02-11-2010, 09:38 PM   #21
KJammer
KJammer is on a distinguished road
Default Re: SL2 Water Pump Replacement w/PICS
That was the best! The pictures were clear and to the point. Very, very helpful. Thanks.
Add to KJammer's Reputation
Rate the quality of this post and help KJammer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KJammer is offline   Reply With Quote
Old 02-12-2010, 01:00 PM   #22
hholbein
1997 SW2
Great pics, and I especially liked the tip about using the box to keep track of where the bolts go on replacement.
Add to hholbein's Reputation
Old 02-12-2010, 04:21 PM   #23
adventureoflink
adventureoflink's Avatar
So uhhhhh.... why isn't this in the how-to library by now
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 08-10-2010, 12:28 PM   #24
Zvolen
Zvolen is on a distinguished road
1998 SL1
Great write up, I will be attempting this weekend with hopefully good results.
1998 SL Bought in Nov 06' w/ 115K 22MPG, Currently 165k 30MPG (city)
Add to Zvolen's Reputation
Rate the quality of this post and help Zvolen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zvolen is offline   Reply With Quote
Old 09-20-2010, 12:33 AM   #25
iuam
iuam is on a distinguished road
Nice, will be doing this tomorrow. did you end up replacing the thermostat as well, you got any pics or advise?
Add to iuam's Reputation
Rate the quality of this post and help iuam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
iuam is offline   Reply With Quote
Old 01-31-2011, 04:06 PM   #26
ladude
ladude is on a distinguished road
I just did my water pump over the weekend on my '02 SL2. The symptoms were a kind of grindy-groaning sound. A couple weekends before that I changed the belt idler pulley, but that only took care of some of the noise. Now the only noise is the purr...lol
My main advice: get a damn strap wrench set, even if you have to buy one that's made in Chiner! It'll make getting that pulley off alot easier!
Add to ladude's Reputation
Rate the quality of this post and help ladude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ladude is offline   Reply With Quote
Old 02-01-2011, 01:47 PM   #27
cgheming
cgheming is on a distinguished road
1993 SL2
I wish I would have had the option of DIY before I was stuck in the MN storm and 400 miles away from home. I got ripped off and I knew it $368.
Add to cgheming's Reputation
Rate the quality of this post and help cgheming reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cgheming is offline   Reply With Quote
Old 02-04-2011, 08:13 AM   #28
mjoekingz28
mjoekingz28 is on a distinguished road
watch out for those GMB pumps from AAP. I put the first one on a while back and after 10000 miles the low level light appeared. Tore the splash shield off and found coolant (and dried coolant) right on and below the weep hole. So I replaced it.
Then after I get my third water pump on (2nd GMB) it goes 8500-10000 miles before the light once again appeared. I really dont feel like changing it again since the three pulley bolt got ate up when my water pump let its bearings go while the engine was running and the belt tension helped shear some of the threads.
I guess I can live with adding a pint every 8500 miles, but if it gets too bad I'll have to get under the car once again.
Add to mjoekingz28's Reputation
Rate the quality of this post and help mjoekingz28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjoekingz28 is offline   Reply With Quote
Old 02-06-2011, 10:47 PM   #29
litbro
litbro is on a distinguished road
Thank you for the info and great picture. I replace my water pump today and because of your post everything went smooth.
Thank you once again!
Add to litbro's Reputation
Rate the quality of this post and help litbro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
litbro is offline   Reply With Quote
Old 02-13-2011, 10:12 PM   #30
lbengr
lbengr is on a distinguished road
Happy Re: SL2 Water Pump Replacement w/PICS
Excellent article, just finished replacing a '97 SL2 Water pump. I used an Autozone water pump, it worked fine, however the sales person claimed I didn't need RTV as the gasket would be good enough --- not so much, leaked before I even started the car. Tore it all down again, RTV'd the track where the gasket lays, added the gasket, reassembled everything and no leaks. Also, the radiator drain plug (plastic) is seized, so I pulled the bottom radiator hose, then the block plug underneath the water pump. I'll need to fix that plastic drain plug someday.
Add to lbengr's Reputation
Rate the quality of this post and help lbengr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lbengr is offline   Reply With Quote
Old 02-15-2011, 06:15 AM   #31
mjoekingz28
thats crazy. The counter guy at AAP told me no need for RTV when I got my pump. I read the directions and it clearly stated that sealant was required.
Good luck on your seal, I think the orange spaghetti gasket might be best since its what Saturn originally used.
Is the orange gasket supplied and stuck to any new water pumps??? Like maybe the AC Delco unit from rockauto, or maybe only the one from getsaturnparts.com?
Old 02-22-2011, 05:03 PM   #32
Acidrain
Acidrain is on a distinguished road
I want to thank the author of this thread for a very well explained criteria for changing the water-pump, which iam doing this week. Ill update when complete over issues that i may or may not have run into. I had also look at richpin youtube videos before taking on such a task, thank you so much for showing another means of taking off the pulley wheel of the water-pump. Much appreciated.
Cheers,
Murf
Add to Acidrain's Reputation
Rate the quality of this post and help Acidrain reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Acidrain is offline   Reply With Quote
Old 04-28-2011, 04:00 AM   #33
keithreed
keithreed is on a distinguished road
My car's water pump is giving me headache. Please help!
Add to keithreed's Reputation
Rate the quality of this post and help keithreed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
keithreed is offline   Reply With Quote
Old 04-28-2011, 03:42 PM   #34
Acidrain
What is the problem you are having? Please explain in detail, i realize it might be hard to explain, but please do your best.
Cheers,
A
Old 04-30-2011, 08:49 PM   #35
boilerroom
boilerroom is on a distinguished road
1994 SC2
thanks for the detailed walk through
Add to boilerroom's Reputation
Rate the quality of this post and help boilerroom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
boilerroom is offline   Reply With Quote
Old 06-25-2011, 06:45 PM   #36
MikeD2
MikeD2 is on a distinguished road
Thank you for taking the time for the great write up & pictures. You made the job as easy as possible. If I could add 1 thing it would be a link to a Richpin video which really helped get the water pump pulley bolts off. Plus putting them back on was even easier. Thanks again.
Here is the link: you may have to copy & paste. I hope it works.
http://www.youtube.com/watch?v=pRpG1BIVRcc
Add to MikeD2's Reputation
Rate the quality of this post and help MikeD2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MikeD2 is offline   Reply With Quote
Old 06-26-2011, 11:18 AM   #37
katuah
katuah is on a distinguished road
This is a great write-up for those with the "standard" room around the pump. I, however, ran into clearance issues with removing the pulley (99 SL2, not sure why it would have been so different, but it was). If you are one of those unlucky ones, you might want to take a look at this post where OldNuc and others discussed options with me, and I describe what I eventually did to get the thing out (and get more clearance for working in general):
http://www.saturnfans.com/forums/sho...d.php?t=168796
You can do it! I am in no way an expert mechanic, just persistent. This forum is a huge resource. Thanks!
Add to katuah's Reputation
Rate the quality of this post and help katuah reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
katuah is offline   Reply With Quote
Old 08-04-2011, 03:48 PM   #38
Sevillian273
Sevillian273 is on a distinguished road
Sevillian273's Avatar
2001 SL2
(Well I'm glad this thread is still being seen after this long. I figured it would be buried by now... I'm happy so many of you have found it useful)
@katuah (yeah im a little late but..) I used a quarter inch ratchet with a 10mm shallow socket for the water pump. It is indeed tight but not impossible. I have since picked up a set of ratcheting box wrenches which are much much thinner than the ratchet/socket combo.
The ideal setup for removing the water pump pulley is a good quality strap wrench and a 6-point, 10mm ratchet wrench.
Add to Sevillian273's Reputation
Rate the quality of this post and help Sevillian273 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sevillian273 is offline   Reply With Quote
Old 10-05-2011, 10:34 PM   #39
JuanDavis
JuanDavis is on a distinguished road
This is very helpful..thanks for sharing
Add to JuanDavis's Reputation
Rate the quality of this post and help JuanDavis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JuanDavis is offline   Reply With Quote
Old 10-08-2011, 11:22 PM   #40
katuah
I just noticed Sevillan's follow-up. To be clear, what I encountered had nothing to do with removing the BOLTS from the water pump - Richpin's videos were spot-on as to how to do that quite easily. Where I had problems was with removing the pulley *itself* after the bolts were out. Good luck, everyone!
just did my timing belt/water pump with PICS! nitroussaturn Vue Tech 109 03-21-2016 11:19 AM
SL Water Pump Replacement DIY rearviewmirror S-Series Tech 18 11-21-2007 03:37 PM
Could this be my water pump leaking? (pics) ecaryn S-Series Tech 10 09-19-2007 11:01 PM
Water pump replacement for $300? Lurker1999 Miscellaneous Tech 6 11-08-2004 09:08 PM
Is my water pump bad??? pics amazinghl Miscellaneous Tech 21 01-23-2003 09:55 AM
