Old 01-16-2010, 10:30 PM   #1
off-track
off-track's Avatar
Default VIN Decode with RPO & full parts list!
Check out this site I just found!
http://www.compnine.com/vid.php
Kicks back the details of YOUR car down to the build date and options. I've never seen the like although I think it missed on my exterior paint group.. it says mine is black-rose or cranberry, I'd call it brown metalic though?? To top it off there's the full part catalog as well as the dealer retail for prices!
A sticky maybe?? Have fun!!
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 01-17-2010, 12:27 AM   #2
SLCraig
Default Re: VIN Decode with RPO & full parts list!
Cool
Everything checks out here.. All options on my car were apparently factory installed
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-17-2010, 05:27 PM   #3
saturnsctwo
here's my car:
Vehicle: Coupe (SC2)
Year: 2001
Build Date: 2000-04-26
RPO Description
UP0 RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, AUTO TONE, CLOCK, ETR. STEREO,AM/FM W/AUTO REV CASSETTE,CD,AUTO TONE(UP0)
U79 SPEAKER SYSTEM,4,DUAL FRONT COAX,DUAL EXTENDED RANGE PACKAGE SHELF 4 SPKR SYS(U79)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
33L EXTERIOR COLOR,SECONDARY (33L)
EXTERIOR COLOR,SECONDARY,BEIGE(GOLD) MET (33L)
33U EXTERIOR COLOR,PRIMARY (33U)
EXTERIOR COLOR,PRIMARY,BEIGE(GOLD) MET (33U)
6AC COMPONENT FRT LH COMPUTER SEL SUSP SUSP(6AC)
613 TRIM COMBINATION LEATHER, BISCUIT (613)
7AC COMPONENT FRT RH COMPUTER SEL SUSP SUSP(7AC)
8AE COMPONENT RR LH - COMPUTER SEL SUSP (8AE) SUSP(8AE)
9AE COMPONENT RR RH COMPUTER SEL SUSP SUSP(9AE)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
CF5 ROOF,SUN,GLASS SLIDING,ELECTRIC ELEC SUNROOF(GLASS)(CF5)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
D06 CONSOLE,FRONT COMPARTMENT FLOOR,ARM REST F/CMPT FLR A/RST CNSL(D06)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
HAA Unk.
JM4 BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON) ANTILOCK DISC/DRUM BRK(JM4)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
LHD VEHICLE DRIVE LEFTHAND DRIVE LEFT HAND DRIVE(LHD)
LL0 ENGINE,1.9L L4(SATURN ONLY)(1.9-7) L4 1.9-7(LL0)
MP7 TRANSMISSION AUTO 4 SPD, SATURN, ELECTRONIC CONV CLUTCH 4-SPD A/TRANS(MP7)
NF7 EMISSION SYSTEM FEDERAL, NLEV FEDERAL EMIS NLEV(NF7)
NW7 TRACTION CONTROL POWERTRAIN MANAGEMENT ONLY TRACTION CTL(NW7)
N30 STEERING WHEEL(DELUXE) DELUXE STRG WHL(N30)
PB2 COVER,WHEEL TRIM(ABSORBING PLASTIC) WHL TR CVR(PB2)
PG1 WHEEL,15X6(STEEL) STEEL WHL(PG1)
QSV TIRE ALL P195/60R15 BL R/PE ST TL AL3 87H TIRE(QSV)
Rarity...
Old 01-21-2010, 04:01 PM   #4
karinhesed86
karinhesed86 is on a distinguished road
karinhesed86's Avatar
Hmm I thought mine was more of a burgandy than "metallic red"....
Vehicle: Sedan (SL2)
Year: 1999
Build Date: 1998-10-27
RPO Description
UM7 RADIO,AM/FM STEREO,ETR,INCLUDES CLOCK STEREO W/CLK(UM7)
UQ0 SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL STANDARD RANGE PACKAGE SHELF/QUARTER 4 SPKR SYS(UQ0)
11D TRIM COMBINATION CLOTH, WARM GRAY, (D) (SATURN) CLOTH TRIM(11D)
75L SECONDARY COLOR EXTERIOR, RED MET (75L)
75U EXTERIOR COLOR,PRIMARY (75U)
EXTERIOR COLOR,PRIMARY,BRILLIANT RED METALLIC (75U)
EXTERIOR COLOR,PRIMARY,MARSEILLES RED II (75U)
8AB COMPONENT RR LH COMPUTER SEL SUSP (8AB) SUSP(8AB)
D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35)
HNS Unk.
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41)
MP3 TRANSMISSION MAN 5 SPD, SATURN, 70MM, 3.25 1ST, .73 5TH O/D 5-SPD M/TRANS(MP3)
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
NK5 STEERING WHEEL(STANDARD) STD WHL(NK5)
NV7 STEERING,POWER,VARIABLE EFFORT P/S(VARIABLE)(NV7)
PB1 COVER,WHEEL,15 INCH 15 INCH WHL CVR(PB1)
QSB TIRE ALL P185/65R15-86T BW R/PE ST TL AL2 TIRE(QSB)
SSH Unk.
2002 SL2 Automaic... going strong at 89,000 miles.
Add to karinhesed86's Reputation
Rate the quality of this post and help karinhesed86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
karinhesed86 is offline   Reply With Quote
Old 01-21-2010, 04:46 PM   #5
azrocketman
azrocketman is on a distinguished road
azrocketman's Avatar
1997 SL1
Their parts catalog is somewhat suspect. They show a radiator cap and conventional thermostat for my 1966 Corvairs.
Steve
Add to azrocketman's Reputation
Rate the quality of this post and help azrocketman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
azrocketman is offline   Reply With Quote
Old 04-22-2010, 05:21 PM   #6
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Thumbs Up Re: VIN Decode with RPO & full parts list!
Wow, that website is incredible!
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline   Reply With Quote
Old 04-22-2010, 06:09 PM   #7
saturnsl293
saturnsl293 is on a distinguished road
saturnsl293's Avatar
1993 SL2
Steve
well it claims to only go back to 80 so who knows. besides maybe you have the uber rare water cooled Covair
back on topic:
mine looks all correct. only thing is I could've sworn I saw somewhere where mine was originally bought in Jan of 93 but it shows it was built on April fools day of 93 unless it had been special ordered for some reason.
car bought 12/15/07
car MIA as of 7/29/09, recovered 8/5/09
Add to saturnsl293's Reputation
Rate the quality of this post and help saturnsl293 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnsl293 is offline   Reply With Quote
Old 04-22-2010, 10:10 PM   #8
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
It said the build date on my car was 1999-12-10. Does this mean Dec. 10 1999 or Oct. 12 1999? The build sticker is missing on my car so I cannot verify this.
It couldn't find the VIN to our 2007 Chevy Equinox. When I tried to lookup parts for it manually, it brought up listings & pictures for a Chevy Lumina.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 04-22-2010, 10:58 PM   #9
SaturnNJeep
SaturnNJeep is on a distinguished road
SaturnNJeep's Avatar
Here's mine:
Year: 1995
Build Date: 1995-04-27
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6)
193 TRIM COMBINATION,BLACK LEATHER (193)
55A ACCENT STRIPE,GOLD (55A)
6AB SPRING COMPTR SELECT FRT LH SUSP(6AB)
7AB SPRING COMPTR SEL FRT RH SUSP(7AB)
81L SECONDARY COLOR EXTERIOR, BRIGHT RED (95) (81L)
81U EXTERIOR COLOR,PRIMARY (81U)
EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)
AB5 LOCK,SIDE DOOR ELECTRIC(KEY ACTIVATED) KEY ACTIVATED ELEC S/D LK(AB5)
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
DC0 MIRROR,O/S,LH REMOTE CONT,RH REMOTE CONT,ELEC LH & RH REMOTE CONT O/S MIR(DC0)
D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR(D80)
HAA Unk.
HP1 Unk.
PG5 WHEEL,15X6(CAST ALUMINUM) AL WHL(PG5)
SSH Unk.
Sweet, I guess we'll be celebrating a 15th B-day in 5 days, The color name sucks, "Bright Red", thank you, Captain Obvious!! At least my wife's Jeep was painted "Inferno Red Pearl Coat",
Jerry
Add to SaturnNJeep's Reputation
Rate the quality of this post and help SaturnNJeep reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnNJeep is offline   Reply With Quote
Old 04-22-2010, 11:07 PM   #10
SaturnNJeep
Since mine was stated as 1995-04-27, I would assume yours would mean Dec. 10th '99.
Jerry
Old 04-23-2010, 12:59 PM   #11
ruley73
ruley73's Avatar
Jerry
Alright, thanks for that clarification. Again, I noticed long after I bought my car that the VIN & tire PSI & load specs stickers are missing. Obviously, I suspect it has been wrecked on the driver's side which would explain the couple other things I've noticed. The driver's door is more recessed than the front fender and there isn't much space between the 3rd door and the rear quarter panel and they sometimes rub when the 3rd door is opened depending on the weather. The latter is much worse on a hot day.
The wreck apparently wasn't too bad or wasn't reported because it wasn't on the CarFax report I ran on it before buying it.
Old 04-23-2010, 01:27 PM   #12
saturnsl293
1993 SL2
I think all that stuff is on the spare tire cover (plywood deal under trunk carpet) from the factory. I know that's where at least the tire stuff is located on mine. I'm sure the vin is around there somewhere but never really looked for it there. For whatever reason some manufactures or at least gm did that with a number of vehicles. I've seen the tire sticker on the bottom of the trunk lid of some Chevy's and/or Buick's
car bought 12/15/07
Old 04-25-2010, 04:44 PM   #13
lonewolfncubs
lonewolfncubs is on a distinguished road
lonewolfncubs's Avatar
1997 SL1
great site thank you
Add to lonewolfncubs's Reputation
Rate the quality of this post and help lonewolfncubs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lonewolfncubs is offline   Reply With Quote
Old 04-25-2010, 06:37 PM   #14
adventureoflink
adventureoflink's Avatar
That's because standard 17-digit VINs didn't start appearing until 1981.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
AMR Engineering (Parts Wish List) serenitythen S-Series Mods 10 02-13-2008 12:04 AM
FS: HUGE list of 95 SC2 parts DjAcidCypher Classifieds 20 02-11-2006 04:50 PM
WTB: Factory parts list petdmc Classifieds 0 04-30-2004 07:36 PM
Parts list ezera1979 Miscellaneous Tech 0 01-30-2004 10:21 PM
Parts list ezera1979 Miscellaneous Tech 0 01-30-2004 10:19 PM
