Old 01-15-2010, 03:15 PM   #1
lakelady
lakelady is on a distinguished road
2008 VUE 3.6L
Default no speedometer or tach plus many idiot lights
My instruments went wacky! First a low tire pressure light came on, then a car with a wrench in it, then the air bag light, and then I had no speedo or tach. Gas guage worked! After I got off the freeway, I shut the car off and turned it back on. No change. I let it sit for over a half hour, restarted it and all was fine. Dealer said, "It didn't throw any codes! Oh well, that happens sometimes." IDEAS?
Add to lakelady's Reputation
Rate the quality of this post and help lakelady reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lakelady is offline   Reply With Quote
Old 01-17-2010, 12:30 AM   #2
aquatechie
aquatechie is on a distinguished road
Default Re: no speedometer or tach plus many idiot lights
Sounds like your Body Control Module is going bad. The first generation Vue would exhibit similar symptoms when the BCM has failed.
Add to aquatechie's Reputation
Rate the quality of this post and help aquatechie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aquatechie is offline   Reply With Quote
Old 01-18-2010, 03:27 PM   #3
Way2QWK
Way2QWK is on a distinguished road
There is a bulletin addressing that issue. #PIT4697B.There are several grounds and connections to check for tightness and also updated software for the Instrument panel cluster.
***Saturn Tech and owner of Planet Automotive in Tucson AZ. Specializing in Saturn repairs.
94 SW2- custom intake and ported throttle body
2003 Saturn Vue 3.0 v6
Add to Way2QWK's Reputation
Rate the quality of this post and help Way2QWK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Way2QWK is offline   Reply With Quote
Old 01-27-2010, 04:23 PM   #4
lakelady
2008 VUE 3.6L
THANK YOU for the info!!! Armed with the bulletin number, they can check this crazy problem out! It hasn't happened again, knock on wood!
Old 01-27-2010, 04:27 PM   #5
lakelady
2008 VUE 3.6L
I'll mention the BCM too! Thanks to all!
Speedometer and Tach needle drop and all lights come on KapsAstra Astra General 24 04-06-2015 03:00 PM
Odometer wrong - speedometer and tach peg on startup MickeyGail Vue General 9 12-02-2008 08:57 AM
'idiot lights' dont work brad6sic6 L-Series General 4 10-02-2007 10:01 PM
Flashing idiot lights turningleaf S-Series Tech 3 09-19-2006 07:10 PM
Computer IDIOT lights mark rose S-Series Tech 1 03-07-2006 08:40 PM
