Old 01-11-2010, 06:12 PM   #1
2006 ion2
2007 ION-2 Sedan
Default sunroof drains
where do they dump?
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 01-11-2010, 06:43 PM   #2
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
Default Re: sunroof drains
who knows?? try using a air hose and see where you feel the air comming from.
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 01-11-2010, 06:52 PM   #3
2006 ion2
2007 ION-2 Sedan
the problem is mine are plugged and dumping into my dash, and it's winter, so I need to find and clear the plug before I can run air through it.
2007 Saturn Ion 2
Old 01-11-2010, 06:56 PM   #4
06_Ion2
06_Ion2's Avatar
humm i know the dealer uses a airhose maybe its just frozen solid and needs to be unthawed.
Old 01-11-2010, 07:17 PM   #5
2006 ion2
2007 ION-2 Sedan
my local dealership refuses to even try to clear it unless I pay them to do it. $50 for them to let it sit inside for half an hour and hook up an air hose is ridiculous.
2007 Saturn Ion 2
Old 01-11-2010, 11:34 PM   #6
ttreibel
ttreibel is on a distinguished road
ttreibel's Avatar
2002 SL1
The factory shop manual shows them draining down the front pillars. They recommend using compressed air at 35psi. Looks like it is routed near the lower hinge pillar. PM me with an email address and I can email the section from the manual.
1995 SL1 oil burner school commuter looks nice...1997 SL1 Gold 5-speed with new junk yard wheels and tires just got 40.4 MPG....2002 SL1 sometimes 45 MPG on a spring highway drive
Add to ttreibel's Reputation
Rate the quality of this post and help ttreibel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ttreibel is offline   Reply With Quote
Old 01-12-2010, 12:03 AM   #7
2006 ion2
2007 ION-2 Sedan
thanks, got it. it implies they come out in the fender or under the car?
2007 Saturn Ion 2
Old 01-15-2010, 02:03 PM   #8
cambruin
cambruin is on a distinguished road
At least in the 2004 model the drain plugs are in the fender wells. Easy to access just pop out those silly plastic rivets and reach up in there. In mine the drains come to a point and clog pretty easily. If you cut a little bit of the tip off they won't clog as much, just don't then attempt to go mudding.
Add to cambruin's Reputation
Rate the quality of this post and help cambruin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cambruin is offline   Reply With Quote
Old 01-15-2010, 03:24 PM   #9
daver
daver has a spectacular aura aboutdaver has a spectacular aura about
daver's Avatar
2005 ION Red Line
where do they dump?
In New Jersey.
Add to daver's Reputation
Rate the quality of this post and help daver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daver is offline   Reply With Quote
Old 01-15-2010, 04:19 PM   #10
2006 ion2
2007 ION-2 Sedan
but I like mudding lol. thanks, I'll have to look into it this spring
Originally Posted by daver View Post
In New Jersey.
that would make sense why they plug so damn often, new jersey is full.
2007 Saturn Ion 2
Old 03-05-2010, 06:07 PM   #11
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
Dizzy Re: sunroof drains
where do they dump?
very easy to tell. pour water SLOWLY into the channels and watch under the car to see where the water comes out. I am thinking towards the back of the car. Let me know if I am right.
Silly me, should have read the whole thread.
Oh well.
Add to chilipepper1327's Reputation
Rate the quality of this post and help chilipepper1327 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chilipepper1327 is offline   Reply With Quote
Old 03-05-2010, 06:47 PM   #12
2006 ion2
2007 ION-2 Sedan
yeah, I've given up on getting the damn things cleared out. I think they're frozen solid and I have no idea how I'm going to get them clear.
2007 Saturn Ion 2
Old 03-05-2010, 07:05 PM   #13
SaturnRaycer
SaturnRaycer is on a distinguished road
SaturnRaycer's Avatar
2008 Astra XR
Even in "da UP, eh", you should be having temps above freezing by now at least for a couple hours a day. The drain tubes normally run through the C-pillar and dump near the rear wheel wells. The drain tubes are 1/4-3/8 diameter, so they're hard to miss. There's a good chance that leaves and stuff have plugged the drain tubes.
Leave the car sit out in the sun with the back of the car pointing toward the south/southwest. If possible, open the trunk so the sun shines in there too. Give it an hour or so, and you should be able to run a heavy wire up from the bottom. I've been successful with 10 or 12 ga primary wire. If you have access to fishtape, that will work well because it's flexible, but stiff enough that it won't accordion at a little obstruction.
Rex
2008 Astra XR
5 dr, 5 spd, sport package
Black Sapphire
If you're going to wave, use all your fingers.
Add to SaturnRaycer's Reputation
Rate the quality of this post and help SaturnRaycer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnRaycer is offline   Reply With Quote
Old 03-05-2010, 07:33 PM   #14
2006 ion2
2007 ION-2 Sedan
I can't get to the rear ones, but I got the front ones clear (for now). they run down the front pillar and the water leaves the car at the rear of the (factory) mud flap on the driver's side and like 8 inches back from there in the rocker panel cover on the passenger's side. I let the 45 degree day work to my advantage. I finally decided to give it another try after posting my last post. I blew it out with compressed air, ran hot (since it's above freezing, otherwise use warm) water down it, blew it out again, then repeated a couple times to make sure I got it good. I have no clue where the rear ones dump, and have no way to access the top side since the glass gets in the way, but for now I'm happy. if anyone knows where the rear ones dump, I might give those a shot tomorrow from the bottom.
2007 Saturn Ion 2
Old 09-06-2011, 12:09 PM   #15
davidrachlin
davidrachlin is on a distinguished road
2004 ION-3 Quad Coupe
I had water pooling in my trunk on my '04 Ion 3 Quad Coupe. Found the drains under the carpet, just aft of the wheel well indentation. They're an L shaped grey rubber boot that leads to the outside. The lines themselves were clear, it was the boots that were clogged, and the air gun at a gas station for inflating tires was enough to clear them out. Now I have water pooling in my passenger front footwell. Did someone say the drains for those are in the front fender? Are they accessible from the inside of the car? it's dripping into my dome/map light door open switch and turning the light on randomly. Driving me f'in crazy.
Add to davidrachlin's Reputation
Rate the quality of this post and help davidrachlin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davidrachlin is offline   Reply With Quote
Old 09-07-2011, 08:30 AM   #16
chilipepper1327
They are accessable from the inside, removing the A-pillar cover, but probably a litte bit easier from the outside by removing the fender skirt.
There is a thread with pictures showing how to do this. Once you access the tubes, just snip of the end to make the hole a bit bigger and voila! No more leaks into the cabin.
Sunroof drains? iceman_15200 S-Series General 3 12-22-2005 05:44 AM
sunroof drains john_flick S-Series Tech 0 03-24-2005 10:01 AM
Sunroof drains spider 1604 S-Series General 10 08-02-2004 01:58 AM
urgent, drains from sunroof. DOHCdude S-Series Tech 4 01-03-2003 08:27 PM
Unclogging Sunroof Drains? BASL2 S-Series Tech 3 03-15-2002 08:31 PM
