Old 01-10-2010, 10:23 PM   #1
01SC02
01SC02 is on a distinguished road
Default Elusive high idle, not your typical noob question
Hello all,
Having an elusive high idle problem constant at 1500 to 2000 rpm's. So far here is what I have done in no perticular order:
- Replaced intake manifold gasket
- Replaced EGR
- Replaced ECTS
- Tested the IACV (tapping it and restarting engine)
- Replaced MAF
Any other ideas on what to check next ?
Add to 01SC02's Reputation
Rate the quality of this post and help 01SC02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
01SC02 is offline   Reply With Quote
Old 01-10-2010, 11:48 PM   #2
Tom64
Tom64 is on a distinguished road
1993 SL2
Default Re: Elusive high idle, not your typical noob question
I had all kinds of problems, including high idle. I don't know if it will work for you, but after I changed spark plug wires, my problems went away.
Add to Tom64's Reputation
Rate the quality of this post and help Tom64 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom64 is offline   Reply With Quote
Old 01-10-2010, 11:53 PM   #3
01SC02
Thanks Tom, yep changed wires and plugs and did'nt help... Yes I did use copper plugs
Old 01-11-2010, 11:35 AM   #4
rc1488
rc1488's Avatar
Originally Posted by 01SC02 View Post
Hello all,
- Replaced EGR
- Replaced ECTS
- Replaced MAF
This does not effect the IAC. We suggest that for a fualty TPS. Remove the throttle body and clean it including the IAC. Follow Richpins videos for instructions.
Add to rc1488's Reputation
Old 01-11-2010, 02:55 PM   #5
fjmg
fjmg will become famous soon enough
My 98 sl1 had the same issue which also caused difficulty engaging 1st gear at a stop (not to mention a fair amount of pinging). I noticed that my temp gauge only moved up to about a 1/4 of the gauge even on hot days. I deduced that the coolant sensor was informing the computor that my engine is still cold resulting in an improper timing advance. I changed the coolant sensor and the car immediately has a 750 rpm idle, 1st is no problem at a stop and the pinging is pretty much eliminated.
Add to fjmg's Reputation
Rate the quality of this post and help fjmg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fjmg is offline   Reply With Quote
Old 01-11-2010, 03:13 PM   #6
OnDaGround
OnDaGround's Avatar
1993 SC2
What? You mean it was a typical "noob" question? Lol, j/k. Had to bust your chops. Follow RC's advice.
http://www.saturnfans.com/forums/sho...d.php?t=132844
Saturnless...
Old 01-11-2010, 03:47 PM   #7
RobertGary1
Spray some soapy water all around the intake manifold and see if you can make a temporary seal (the soap will temporarily seal a small leak and cause the RPM's to return to normal). You could even have a cracked manifold. I assume you probably also replaced the gasket behind the TB.
I wonder too if for some reason your IAC is sticking. Perhaps try pulling it out and seeing if its stuck in high idle?
-Robert
Hello all,
- Replaced EGR
- Replaced ECTS
- Replaced MAF
High Idle AND now High RPMs 1995 SC2 randibou S-Series Tech 3 03-20-2009 04:52 PM
High Idle Question carl S-Series General 21 10-10-2006 08:17 PM
Noob with a high idle on 93 SC2 Wizard Prang S-Series Tech 0 02-07-2006 03:58 PM
TEC - SeaFoam Question (Not typical) Red97sc2 S-Series Tech 8 02-08-2005 10:17 AM
93 SL2 Idle..... typical kentuckyfan23 S-Series Tech 4 09-04-2004 03:52 AM
