Old 01-10-2010, 02:08 PM   #1
bicycleboy7
bicycleboy7 is on a distinguished road
Default Hard to change gears
i have a 1996 SL1, when ever i change gears, i have to really force the gear leaver into place. any ideas why? it has 147000 miles on it. thanks
Add to bicycleboy7's Reputation
Rate the quality of this post and help bicycleboy7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bicycleboy7 is offline   Reply With Quote
Old 01-10-2010, 02:23 PM   #2
2NDSOUT
2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough
2NDSOUT's Avatar
1999 SL
Default Re: Hard to change gears
Is this a Manual or Automatic?
Manual: Change the Trans fluid. You only need 2.5 Qrts of fluid and YES..you CAN use ATF in your Manual Transmission. Check your shifter bushing underneath the center console, along with the cable ends. These can get worn out and can eventually break. The shifter bushing is a $32 replacement off of ebay and works great. Also, what is the condition of your clutch, etc. ?
Automatic: Change the ATF fluid and filter. This should be done RELIGIOUSLY every 30K miles on an automatic transmission. If it hasn't been done in a while or you can't remember the last time it was done, it may be a good time to do it now.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 01-10-2010, 04:09 PM   #3
hholbein
1997 SW2
If yours in a Manual Transmission, you might want to also check the linkage on the transmission side of the cables (accessible from above or better still from the side after removing the wheel and driver's side inner splash shield).
These often get crudded up with gritty sand/dirt/old ATF etc. and causes the gear selector to get hung up or balky. Clean & degrease the transmission linkage with some Simple Green and an old toothbrush and see if that helps.
If not, I'd dig into the interior shift console and see if there's an issue with the bushing.
Swapping out my 12 y/o Dexron III ATF for Transynd ATF has also made shifts a bit smoother, but unless your ATF looks and smells awful, I'd make that 3rd on my list of to-dos.
Let us know what you find....
Add to hholbein's Reputation
Old 01-11-2010, 02:54 AM   #4
Dime333
Dime333 is on a distinguished road
Dime333's Avatar
1994 SL1
Damn the same is hapenning to my 94 sl1 146,000 i had changed the ATF fluid in december but i dont think i got it all out cuz its the new stuff is kinda dark. the old stuff was really dark like almost like the color of this face haha
Saturn Infinitum.
We Are Saturn and We Love our Cars.
Add to Dime333's Reputation
Rate the quality of this post and help Dime333 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dime333 is offline   Reply With Quote
Old 01-11-2010, 11:50 AM   #5
look for the writeup by barnowl in The How To Library for testing the clutch hydraulic system.
I've been slowly changing out my clutch hydraulic fluid using a turkey baster (following richpin's video) and last time I must not have put enough brake fluid in. Noticed substantially harder shifting, esp to 1st gear.
Added more (I think just under 1/4 from the top), place a rag around the master reservoir to catch spills, and put the cap back on. Much improved shifting.
Old 01-11-2010, 01:51 PM   #6
RobertGary1
First thing I would check is the clutch. When sitting idle, with the clutch depressed shift into first gear and look for any drop in RPM. If you see an RPM drop you have a problem with your clutch (most likely external (master or slave cylinders).
-Robert
Old 01-12-2010, 01:05 AM   #7
Dime333
Dime333's Avatar
1994 SL1
-Robert
Wouldnt that just kill the engine?
Saturn Infinitum.
Old 01-12-2010, 03:30 AM   #8
mjoekingz28
mjoekingz28 is on a distinguished road
I thought it was all in my head when I suctioned out some clutch fluid then added some and I might have put in just a little too much since the rubber seal needs to be expanded when reinstalling, But afterwards the clutch pedal seemed to be a bit stiffer.
Dime, he never said he engaged the clutch.
A few months back I swapped out the 5yr old dexIII for redline d4 atf and got improved (smoorher) shifting in all but first gear,especially when coming from reverse. It really bugs me, so I bought some MTL and it feels pretty much the same. Besides having to continually stab first after backing up and sometimes having to press and release the clutch pedal a few times ( a technique often used in motorcycles to get the gears lined up at a stop) and it takes a few moments usually when shifting to second sometimes. Besides that, shifting is quite fluid and very nice.
I hear lubing the shift cables with powdered mica will help, but have yet to try this myself.
Add to mjoekingz28's Reputation
Rate the quality of this post and help mjoekingz28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjoekingz28 is offline   Reply With Quote
Old 01-12-2010, 07:23 AM   #9
norkahinz
norkahinz is on a distinguished road
What i did I work for me real good not saying that you have to but i had the same issue on a 5 speed. i change the fluid but I mix 50% ATF and 50% 10-30 engine oil. I must say it shifted like butter reall smooth, and I had it for very long time.
Add to norkahinz's Reputation
Rate the quality of this post and help norkahinz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
norkahinz is offline   Reply With Quote
Old 01-12-2010, 09:10 AM   #10
DonP
Clutch hydraulics problem is one possible issue that will results in difficulty shifting into 1st and 2nd gear when the engine is running, easy shifting when the engine is off. This can be a result of problem with the hydraulics system resulting in loss of fluid, or bad seals.
There is a diagnostic test for clutch fork travel that can help diagnose if this is your problem. A search should find it.
Add to DonP's Reputation
Old 01-12-2010, 02:20 PM   #11
RobertGary1
No because you have the clutch down the entire time. If it kills the engine you know you have a serious clutch problem.
Sometimes hard to shift gears... jk3006 S-Series Tech 10 02-04-2009 10:54 AM
hard shifting through all gears. HELP stayfly40 S-Series Tech 3 10-06-2007 10:54 PM
95sl2 shifting hard into gears 95sl2urbo S-Series Tech 11 02-01-2007 05:10 PM
Hard to get in gears!! CMSchops S-Series Tech 1 11-01-2006 11:27 AM
1993 SL1 5speed transmission hard to change gears FissionMan S-Series Tech 9 02-16-2003 02:49 PM
