Old 01-06-2010, 07:07 PM   #1
rjs860
rjs860 is on a distinguished road
Default Saturn sl1 P0340 (How to fix)
My 2001 Saturn SL1 used to stall at stop signs and the service engine soon light came on. I received error code p0340 on my scanner (camshaft position sensor). I was told there is no camshaft position sensor for an sl1. After days of research I fixed the car by doing the following:
1. Replaced spark plugs
2. Replaced spark plug wires
3. Replaced both coil packs (that's where the spark plug wires lead to)
4. Replaced ignition module (that's the plate that the coil packs attach to)
Problem solved for under $270. The car now runs smooth with no stalling or engine lights or error codes. You can clean the parts above if you want to do it cheaper but I prefer to replace things that need cleaning since I am not a mechanic. *** Make sure to sand or wire brush away all corrosion between the ignition module and the engine block where it mounts since that can cause the ground to short out.
Add to rjs860's Reputation
Rate the quality of this post and help rjs860 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rjs860 is offline   Reply With Quote
Old 01-06-2010, 07:43 PM   #2
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Default Re: Saturn sl1 P0340 (How to fix)
Welcome to the forums!
NGK plugs usually solve this pending code.
99 Sl1..p0340,p0341,p0302 Stillwater S-Series Tech 19 09-20-2008 05:36 PM
96 sl1 po 171 cant seem to fix mrfixit S-Series Tech 2 06-04-2008 10:38 PM
97 Saturn SL2 P0133 & P0340 error codes msmelsy S-Series Tech 1 03-11-2008 07:27 PM
2002 SL1 Trans Fix Rich Gregereson S-Series Tech 1 09-02-2007 11:54 PM
temporary ETCS fix, 95 SL1 Al Scott S-Series Tech 1 05-09-2007 07:07 PM
