Old 12-30-2009, 05:47 PM   #1
armcclure
armcclure is on a distinguished road
armcclure's Avatar
2000 SC2
Default Full Custom 2000 SC2 CAI
Hey there everyone. I'm new to the forum but have been working with cars for a while. I currently work at a small fab shop that makes CAI's for various cars so I thought i'd use some spare time to make a full custom intake for my SC2 that i just got a few months ago. just understand that this is NOT a kit we make where i work, just something i did on my own. If you are interested enough and for the right price....
Anyways... the only intake i saw for this car online was the AEM "tube-and-filter" which is a chunk of aluminum pipe and a engine-choking dry filter with no sheild and sits in the stock airbox location which is close to the radiator. Bad design.
For starters, i knew i had to get that battery out of the way to make room for a decend airbox, so i relocated it to the spare tire well and used 00 cable to connect it. If you chose to do this, be sure the battery is secured so you don't compound your troubles in a wreck.
Once that was out of the way, I drew up prints and welded together an aluminum airbox that used the battery tray's mounting points. The airbox also has a bracket welded onto the back to hold the computer as it was previously mounted on the battery tray.
The top of the bow closely follows the hood and will have a plexiglass cover but i am not putting that on till i have the ram air finished.
I chose to use an S&B R1267 Oil Filter which provides PLENTY of air. A bell from one of our kits is mounted to the 45 degree part of the box. From there a 3.5" hump hose connects it to a custom made aluminum adapter (3" ID) that makes a 45 degree turn both to the right and upwards. A 3.5-3 reducer hose is used to connect from the adapter to a mandrel bent 90 degree 3" aluminum elbow. A 3" hump hose is used to connect the elbow to the first 12" or so of the stock intake pipe which was cut at the connection and sanded but left a small barb so it would stay sevurely attached to the hump hose. This piece of the stock intake is actually very well designed. It smoothly tapers from 3" down to the throttle body diameter while making the necessary 90 degree turn creating a velocity stack effect.
I am not completely finished with it, i will be adding true ram air coming from the front bumper scoops.
Remember, eventually the top of the box will be sealed off with a plexiglass lid to utilize the pressure from the ram air.
I have had no problems with any SES lights. The sound is INCREDIBLE!!! It flat our SCREAMS once you hit 4000 rpm. I do not have HP or Dyno numbers, but i do have this,
with the stock intake, i placed the car in 3rd gear and did a timed run with a stopwatch from 20-80 mph, which covers pretty much the entire rpm range. My average time was about 17.25 Seconds
I repeated this with the intake installed as it is in the pictures, without the lid or ram air. As it is, the intake does draw some warm engine air. This will be eliminated when the ram air is finished. But as it is the same 20-80 3rd gear run average time was down to just over 15 seconds!!! There is DEFINITELY a felt power gain that feels like someone pushes the back of your seat when you hit 4 grand.
Questions, comments, let me know what you think!!
PICTURES
#1 left side view
#2 connection to stock tube
#3 top view
#4 tapped hole for temp sensor
#5 bumper scoop(s) where Ram-Air will be drawn from
#6 Ram-Air entry into airbox
p.s. Sorry for the pictures not being prefect quality, they were taken with my phone
Add to armcclure's Reputation
Rate the quality of this post and help armcclure reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
armcclure is offline   Reply With Quote
Old 12-30-2009, 06:41 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Full Custom 2000 SC2 CAI
nice. let me know when you dyno it.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-30-2009, 06:49 PM   #3
rc1488
rc1488's Avatar
Well done. I think thats legal for SCCA too
Add to rc1488's Reputation
Old 12-30-2009, 06:50 PM   #4
Ikiris
Ikiris is on a distinguished road
Ikiris's Avatar
Nice work man. Can't wait to see pics when its finished. Maybe take some video or pics along the way while your making the ram-air pieces.
04 Vue 3.5L V6 AWD 297000 km
00 Impala LS 3.8 V6 Loaded 262000 km SOLD
98 SC2 5speed-265000 km SOLD
Add to Ikiris's Reputation
Rate the quality of this post and help Ikiris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ikiris is offline   Reply With Quote
2000 Saturn SC2 AC won't go to full ekempey S-Series Tech 6 10-14-2008 10:47 PM
to the ppl who have full custom exhaust americanbulldog S-Series Mods 3 06-11-2006 05:22 PM
custom fab cai cuzimaluzer77 Vue General 15 10-08-2004 04:18 PM
FOR SALE! Full Custom '02 SL2 cleansl2 Classifieds 14 10-27-2003 01:05 AM
