Old 12-27-2009, 09:33 PM   #1
hydromech
hydromech is on a distinguished road
hydromech's Avatar
Default Starter won’t crank the engine
My starter won’t crank the engine again – single loud clunk and no crank. Headlights ON and not dimming…
Yesterday I got this problem but after 5 attempts I was able to crank and start the car... After test drive I killed it and started again - OK… Today – no way…
I run a wire from Battery+ to starter solenoid (purple) wire… Same thing: single loud clunk, arching and NO cranking - dead…
I pulled the starter and took it to NAPA for testing. The starter is spinning at their bench !!! The also tested my battery – OK..
Please help. What else should I check ???
Maybe it is my starter (intermittent) ?
2000 Saturn SL1, SOHC, Automatic, 182K
Add to hydromech's Reputation
Rate the quality of this post and help hydromech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hydromech is offline   Reply With Quote
Old 12-27-2009, 10:07 PM   #2
saturn69
saturn69 is on a distinguished road
2008 VUE 2.4L
Default Re: Starter won’t crank the engine
have you check the stater/postive cable running from the battery to the starter?
Add to saturn69's Reputation
Rate the quality of this post and help saturn69 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn69 is offline   Reply With Quote
Old 12-27-2009, 10:18 PM   #3
hydromech
hydromech's Avatar
I did ckeck voltage on that "always hot" terminal. It was 12 Vdc...
Old 12-27-2009, 10:29 PM   #4
saturn69
2008 VUE 2.4L
i meant did you physical check the battery cables condition and make sure the grounds are good and tight.
Old 12-27-2009, 10:33 PM   #5
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
The starter has different sections for starting a vehicle, meaning that very often it is intermittent. Next time your car won't start, if it's a manual, put it in fourth, try to push it, then try to start it. If this method ever works, it's the starter.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 12-27-2009, 10:34 PM   #6
hydromech
hydromech's Avatar
At starter end I visually inspected the terminals - look OK and I checked voltage at "always hot" starter terminal - OK too... No visible damage to thick cables...
How do I check for good ground ?
Should I use ohm-meter ?
Do you think my problem is wiring ? not starter itself ?
Old 12-27-2009, 10:50 PM   #7
Um, you can't check for any good ground for the starter, its already grounded - the starter's body is ground and the physical mounting of the starter to the engine grounds the starter properly. Checking for 12v at the starter terminal, putting 12v on the small terminal and seeing/hearing a loud click despite bench testing and seeing the starter spinning in place is all the information you need. Replace the starter. Isn't this the original one in the car? If its is and its been used for 140k miles, its done its job and needs a rebuild or replacement.
Bench testing without loading the starter (with a flywheel/engine set-up to reproduce similar loads) doesn't mean squat. Bang the starter with a piece of 2x4 against the body once or twice and see if the starter comes to life; either it will run or not. You're looking at a worn out starter.
Old 12-27-2009, 10:56 PM   #8
hydromech
hydromech's Avatar
Thanks a lot, fdryer !
Something tells me that my 10 year old strarter is bad... The only thing is why it TURNS at the bench ?
Maybe it is because that is "no-load test" ???
Yesterday I did start my Saturn (after 5 atempts)
Old 12-27-2009, 11:02 PM   #9
You only have to experience this once to remember it later with other cars as you'll see the same issue time and time again. Worn out starters don't announce themselves.
Old 12-27-2009, 11:17 PM   #10
hydromech
hydromech's Avatar
Yea... I simply could not just put that old starter back after they tested it OK at NAPA... Sorry I didn't buy a new one... will have to walk there tomorrow
I suspected that bench test is not 100% proof... Thanks again for confurming that, fdryer
Old 12-27-2009, 11:24 PM   #11
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
Watch this video,
http://www.youtube.com/watch?v=LjZ1VqThlq0
The guy is a bit of a character but he is a decent mechanic. He explains exactly what your problem is and why it happens.
He has some very good DIY videos, if you can get around some of his other stuff.
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
Add to mattelderca's Reputation
Rate the quality of this post and help mattelderca reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattelderca is offline   Reply With Quote
Old 12-27-2009, 11:44 PM   #12
hydromech
hydromech's Avatar
mattelderca, any idea - how you call those copper things ? Is it possible to buy similar for Saturn SL1 starter ?
Old 12-28-2009, 12:14 AM   #13
mattelderca
1998 SC1
1996 SL
Yes, you can buy them, most likely at your local rebuilders shop. I made them once for a Toyota I had. Made them from flattened copper pipe!
BUT, if one component has failed another is close behind! Buy a good rebuilt or new starter. You don't want to be stuck somewhere do you?
Old 12-28-2009, 05:55 PM   #14
hydromech
hydromech's Avatar
The problem was as simple as bad battery - it would not hold the charge...
The starter was OK - as tested by NAPA and AutoZone...
I just installed a brand new battery and put the old starter back... Car started no prob...
I'd like to share my bad troubleshooting experience to help other Saturn owners to avoid my mistake...
Old 12-28-2009, 06:55 PM   #15
Originally Posted by hydromech View Post
... The starter is spinning at their bench !!! They also tested my battery – OK....
So, it looks like NAPA goofed from the beginning....................
Old 12-28-2009, 07:32 PM   #16
adventureoflink
adventureoflink's Avatar
Originally Posted by mattelderca View Post
Buy a good new starter.
Fixed. Do NOT EVER EVER EVER EVER buy a rebuilt starter, UNLESS you plan on rebuilding your current starter to last long enough till you get a NEW one. Same goes for alternators.
Either way, glad to hear you got everything going again, and just another reason to go from cheapest to most expensive repairs..
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 12-28-2009, 08:11 PM   #17
RobertGary1
What a crappy test. At Kragen at least they put a load on the starter. I wonder what the value of them using up precious time in life putting power on a starter that doesn't have a load on it is.
-Robert
Old 12-28-2009, 08:18 PM   #18
Cheyne
Cheyne will become famous soon enough
2000 SL2
It's not only the starter. Like the OP, I had a battery test twice as good that eventually turned out to be bad.
Add to Cheyne's Reputation
Old 12-29-2009, 09:10 AM   #19
mattelderca
1998 SC1
1996 SL
We have several local shops that rebuild starters, alternators, etc. etc., and I can guarantee the quality is better than new! Don't make blanket statements without KNOWING exactly what you are talking about! Experience is a lovely thing, I'd buy a rebuilt starter from these shops before I'd shell out for a new unit of unknown quality. How many rebuilt units have you bought? I've bought literally hundreds and NEVER had one fail. Read my original post on it, it says buy a GOOD rebuilt unit. I am sure there are many local rebuilders in your area as well, go to their shop and have a look around. Look at the components they use and how they serve their customers, then judge if you want to deal with them or not. But don't slam things in general, it does no one any good and adds nothing to the knowledge base.
Old 12-29-2009, 10:00 AM   #20
hydromech
hydromech's Avatar
mattelderca, please advise WHAT brands/stors are better to get decent quality auto parts (rebuild/replacement)
I recently got just bad experiences with PepBoys and AdvanceAuto...
You have experience, please help
Starter slow crank intermittently Echobradley Ion Tech 7 12-26-2009 02:22 PM
Engine won't crank when hot - Starter Relay? blayer21 S-Series Tech 8 04-10-2008 06:10 PM
Starter doesn't crank jamman S-Series Tech 3 03-09-2007 06:54 PM
starter 1, crank pulley zero eljefino S-Series Tech 4 07-06-2006 04:31 PM
Replaced Clutch, Now Starter Won't Crank makmo L-Series General 1 04-22-2006 03:54 PM
