Old 12-27-2009, 07:58 PM   #1
brandj1
brandj1 is on a distinguished road
Default Manual Transmission Shifter Cable modification from stock
I have a 2005 Vue with a manual transmission. Recently the shifter cable quickly became so stiff that I broke the clip (Dec. 21, 2009) that connects the cable to the shift lever. This rendered my car totally inoperable and I freaked since it's my only mode of transportation. I was able to fix the connection to the shifter so that I could get the cable to operate, however stiff.
I called the dealer (these are dealer only items) and ordered a new set ($211.00) and they are on back-order for over a month (Jan. 20, 2009). I've searched salvage yards with no luck. Now I fear that the stiff cables that I do have will eventually break and I'll be renting a car until they come in.
So, here's my idea. I've gone to Autozone and purchased two different univeral cables, one with both ends threaded, the other with a threaded end and eyelet end. I bought the two different cables thinking that one would be better for my application and I would return the other. I want to modify my Vue to accept these cables so that I won't ever be in this situation again!!
I thought the cable with the eyelet end would be better on the transmission end of the cable and the threaded end would feed into the shifter console possibly using the existing connections to the shift lever? Or, maybe the cable with both ends that are threaded will be better? I don't know at this point and I'll have to wait to see when it's all in front of me.
Does anyone have any experience with this sort of thing? The universal cables will be in next week (Dec. 31) and that's when I was planning on trying to put a kit together to adopt these univeral cables.
Any help or advice would be appreciated. I would prefer to nurse my stock cable until the OEM cables come in but I fear breakage. However, if I modify the VUE for the universal cables, which are much cheaper, I will be better off on parts and availability.
Thanks in advance for any help or advice.
Jim
Add to brandj1's Reputation
Rate the quality of this post and help brandj1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brandj1 is offline   Reply With Quote
Old 01-01-2010, 07:19 PM   #2
brandj1
Default Re: Manual Transmission Shifter Cable modification from stock
Update:
The cables came in from Autozone and I returned them as soon as I opened the box. I picked up a set from a local salvage yard that have the car working like new.
Old 01-18-2010, 05:52 PM   #3
PortugalFocus
PortugalFocus's Avatar
Did the AZ cables not match up? Were they close? I have the same issue on my 05 and I really didn't want to go buy a new set of cables, but mine are starting to freeze up a bit.
Add to PortugalFocus's Reputation
Rate the quality of this post and help PortugalFocus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-04-2011, 04:23 PM   #4
brandj1
If I were you I would check the salvage yards for a manual transmission Vue. That's where I ended up getting my cables that cost me $100.
Old 03-06-2011, 09:33 AM   #5
PortugalFocus
They are only about $130 new @ the dealer.
Shifter cable link - manual tranny bestharry Vue Tech 5 05-07-2014 09:07 PM
Shifter cable link - manual tranny bestharry Vue Tech 1 09-08-2009 01:24 PM
1998 Saturn SL2 Manual Transmission Cable broke for my wife S-Series Tech 5 02-02-2008 11:04 AM
S-Series Shift Cable Solution (Manual Transmission) cazzylee S-Series Tech 15 06-23-2007 03:33 PM
FS. S-series manual shifter (stock) mtlmutt Classifieds 0 04-28-2005 12:48 AM
