Old 12-27-2009, 02:50 PM   #1
sw2wagon
sw2wagon is on a distinguished road
Default Replacing Transmission Solenoid
This is my first post having just found this website. I have a 2000 SW2 with 82,000 miles. Awhile ago the "service engine" light came on. I took it to the local Auto Zone to have them diagnose the code. They said it was the transmission but I didn't get the code number. I then took it to the Saturn dealership for a diagnosis. The mechanic told me that the solenoid that engages the torque converter into direct drive was bad. As I recall the estimate to replace this was close to $1,000. He said it would not hurt to drive the car and that all it would effect was a slight decrease in the gas mileage. I decided to let it go for the time being and it drives fine. I have been a do it yourself-er for a long time and after watching the youtube video I'm confident I can change it myself. My questions are exactly which of the 5 solenoids needs replaced its location on the valve body? Also are there any pressure adjustments required after replacement ?
Thanks In Advance For Any Advice
Add to sw2wagon's Reputation
Rate the quality of this post and help sw2wagon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sw2wagon is offline   Reply With Quote
Old 12-27-2009, 03:24 PM   #2
kevman
kevman is on a distinguished road
kevman's Avatar
2003 VUE 2.2L
Default Re: Replacing Transmission Solenoid
i just replaced mine, but the whole valve body because anyway, like my tranny guy told me, the other ones will follow,so you just have to change the whole valve body and it s faster that way and also ,you wont have any problems again with the other ones, then your gona have to take it off again and change the middle gasket every time and 38$ also. the whole valve body cost me brand new out the box 350$ !! hope this helps !!
think big and low
today:
VUE 03 2.2 5speed
SL2 99 aut
gone but not forgotten:
SL2 99 5speed
SL1 95 5speed
SL2 92 5speed
SL2 93 5speed
SL2 94 5speed
SL2 92 aut
SL1 95 aut
LS1 01 5speed
Add to kevman's Reputation
Rate the quality of this post and help kevman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevman is offline   Reply With Quote
Old 12-27-2009, 04:06 PM   #3
Special Forces
Special Forces is on a distinguished road
Special Forces's Avatar
2006 ION Red Line
Brand new huh? I'd like to see the proof on that. If it came from Saturn, it doesn't have the Sonnax upgrades that's for sure. $350, when you can have an upgraded one from me for less than $200 when all said and done.
And it's not true the other solenoids are on the way out. Here's why: The pressure control solenoid is being actuated many many times a second to control pressure. This happens over the course of it's life day in and day out. The other solenoids are being actuated on an "as needed" basis, depending on what gear the transmission is in. So those solenoids are getting a lot less use than the pressure control solenoid. Think of the pressure control solenoid being aged in "dog years" and the others being aged in "human years". You can see it gets much more use over the course of it's life then the other 4 do.
So that would not be a correct statement to say "the others are on the way out".
As for your repair sw2wagon, if it was me I would want to know the code first hand, show me the numbers if you will. I want to know before I repair something that I know for sure what the problem is. Hearing someone else say "its the transmission" or "its the torque converter" wouldn't do it for me.
I digress.
$1,000 is something I would laugh for hours with. It's a $40 part and if you timed me I can do it in 42 minutes. Hardly a thousand dollar job. If you want to tackle it yourself there is a video by someone on here that changes out the pressure solenoid as you already are aware of and confident to go on with.
With that said the torque converter solenoid is #3 in this diagram.
Any questions just ask!
/// Need rebuilt valve bodies? PM Me. \\\
Valve bodies built to order
Please PM me about valve bodies, do not post a visitor message.
Add to Special Forces's Reputation
Rate the quality of this post and help Special Forces reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Special Forces is offline   Reply With Quote
Old 12-27-2009, 08:15 PM   #4
sw2wagon
Since my first post I went back through my records and found the report from the Saturn dealer. Listed under the category of Tech Comments was the following..."TECH PERFORMED DIAGS FINDING CODES, 740, 741, AND 789, TCC SOLENOID STUCK OFF...TECH RECMD VALVE BODY REPLMT EST COST, $1052.90 PLUS TAX". Can anyone translate these codes and tell me what is wrong and exactly what parts I need? Like I said before we have been driving the car and it runs and shifts fine with the exception of it doesn't shift into top gear. I guess that is 4th gear?
Thanks Again for Your Time
Old 12-27-2009, 10:04 PM   #5
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
Going by the dealer diagnosis, you are just not getting converter lockup. This may feel to you as not shifting to fourth gear, but you probably are. When cruising along at a steady pace, push the throttle down a bit and watch the tach. Do the rpm's climb about 500 rpm before you accellerate? Or does the car just accelerate with little tach movement? You should be able to just replace the solenoid. It should not cost more than a few hundred to replace the whole valve body!
2000 SL1 freebie
1998 SC1 still running
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
1978 Chrysler NewYorker Brougham
Add to mattelderca's Reputation
Rate the quality of this post and help mattelderca reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattelderca is offline   Reply With Quote
Old 12-27-2009, 10:19 PM   #6
sw2wagon
My reasons for repairing this are: #1 - to make it correct and maximize gas mileage and #2 - to turn off the " service engine " light. I'm hoping through these posts that I can get help diagnosing the codes and determine exactly which parts that I need to replace. Thanks
Old 12-27-2009, 10:27 PM   #7
sw2wagon
I forgot to add that I'm still a little confused. Do I need to replace just the solenoid or the entire valve body? Am I correct in thinking the solenoids insert into the valve body? If so replacing the #3 solenoid should enable the torque converter to lock into direct drive, correct?
Old 12-27-2009, 10:40 PM   #8
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
Originally Posted by sw2wagon View Post
.... ..."TECH PERFORMED DIAGS FINDING CODES, 740, 741, AND 789, TCC SOLENOID STUCK OFF...TECH RECMD VALVE BODY REPLMT EST COST, $1052.90 PLUS TAX". .....
Strictly from line interpretations from our How-to library listing almost every OBD II error code;
DTC P0740 TCC Enable Solenoid Circuit Electrical
DTC P0741 TCC System Stuck Off
DTC P0789 Shift/Timing Solenoid Intermittent
There are some great pics from members putting up pictures of their valve body repairs, replacing solenoids, if you try searching. SF has probably the best handle on your issues and it would be worth waiting for a reply from him.
*The CPS is the heart of the entire EFI system. No cps = dead EFI system*
*There's more to a/c than just a few cans of refrigerant*
*There's more to brakes than just replacing parts*
Old 12-28-2009, 08:03 AM   #9
Special Forces
2006 ION Red Line
Replace the solenoid I told you to replace and you'll be fine. The solenoid is frozen and needs to be replaced. It sounds like you already found the video on how to replace the pressure solenoid, simple replace the one I told you to instead and drive it. Total cost $50.
https://www.wittrans.com/showfilter....85&Section=128
Product # D10421AC
Pop that into the #3 spot in the valve body and lock and load!
Old 12-28-2009, 08:12 AM   #10
Tommie
Tommie is on a distinguished road
1996 SL1
2002 SL1
Hey SF! You sound like the person to ask this: Does lockup happen in second gear and up? My SL1 behaves like it does unless I have a 5 speed auto...LOL.
I digress.
Add to Tommie's Reputation
Rate the quality of this post and help Tommie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tommie is offline   Reply With Quote
Old 12-28-2009, 08:14 AM   #11
Special Forces
2006 ION Red Line
Lockup happens in every gear except first ONLY when the transmission is up to temperature, guided by the temp sensor on the transmission AND the engine temp sensor (the infamous ECTS, now you know why it's so important to transmission control).
Basically a couple miles of driving and the TC is being locked up in all gears except 1st.
Old 12-28-2009, 11:43 AM   #12
Tommie
1996 SL1
2002 SL1
Thanks!
Old 12-28-2009, 12:01 PM   #13
sw2wagon
Thanks to everyone who has posted and offered their help.
SF....I ordered the solenoid that you specified from WIT this morning. Looks like a pretty straight forward installation. Are there any "adjustments" necessary after installing the solenoid? My time and $50.00 is way better than spending $1,000.00 at the Saturn dealership. I'll post after this project is done to let you know how it turned out.
Thanks Again!!!
Old 01-03-2010, 11:24 PM   #14
sw2wagon
I replaced the TDD solenoid today. It took only 2-3 hours but I took my time and even stopped for lunch. It really couldn't have been much easier. The biggest nuisance was getting the hoses and cables out of the way to remove the valve body cover. I drove it for about 20 miles after I finished with no problems. The "Service Engine" light went out and everythings fine. Thanks to all that posted and helped me through this process!
Once again a SATURN FAN
Scott
Old 01-04-2010, 04:43 AM   #15
CND_SC1
CND_SC1 is on a distinguished road
CND_SC1's Avatar
1994 SC1
Hope it's fixed for good.
Keep us updated once you've driven it a couple of days.
Add to CND_SC1's Reputation
Rate the quality of this post and help CND_SC1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CND_SC1 is offline   Reply With Quote
Old 01-04-2010, 07:17 AM   #16
sw2wagon
Mad Re: Replacing Transmission Solenoid
You're scaring me....is there reason to believe it's not fixed?
Thanks
Old 01-04-2010, 10:19 AM   #17
alordofchaos is a jewel in the roughalordofchaos is a jewel in the roughalordofchaos is a jewel in the rough
Congratulations on saving $950
I like browsing this forum even when my car is operating fine; learn new things all the time. Plus, I'm a little better prepared for the next thing that can go wrong
Your transmission is probably fine (I say probably only because it's 10 yrs old now). Just keep the ATF and filter fresh (30k miles)
...Wait, what, I actually won that eBay auction?
Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p
And now (7/2010), a Craigslist 1997 SC2 5 spd
Old 05-12-2013, 12:24 AM   #18
SL2 Ride
SL2 Ride is on a distinguished road
2002 SC1
I digress.
Hi, i'm in a similar boat with a 2002 SC1, so i'll be dealing with the valve body soon.
Can you tell me what you mean by the "Sonnax upgrades"?
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 05-12-2013, 08:05 AM   #19
Chazberry
Chazberry is just really niceChazberry is just really niceChazberry is just really niceChazberry is just really niceChazberry is just really nice
Chazberry's Avatar
The Sonnax story here . . .
http://www.sonnax.com/system/instruc...SC-TAAT-IN.pdf
Add to Chazberry's Reputation
Old 05-13-2013, 02:21 AM   #20
ShawnV
ShawnV has a spectacular aura aboutShawnV has a spectacular aura aboutShawnV has a spectacular aura about
ShawnV's Avatar
Thanks
It's fine.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Transmission Pressure Control Solenoid replacement (’99 SL1 A/T) tspoof S-Series Tech 111 06-14-2013 12:29 PM
Transmission solenoid bad.... ToledoEngineer Sky Red Line 0 04-17-2009 12:40 PM
How much will replacing the BTSI solenoid cost? crystalmyth S-Series Tech 3 07-16-2008 12:53 PM
Transmission Pressure Control Solenoid Crowdsurfer L-Series Tech 5 03-16-2007 08:11 PM
Solenoid,alternator,electrical transmission issue? mdsaturn99sl1 S-Series Tech 3 10-24-2005 08:33 PM
