Old 12-18-2009, 03:17 PM   #1
Mike H
Mike H is on a distinguished road
Default Instrument Panel Lights
Just purchased a 2000 LS1.
Some of the instrument panel lights are out.
The left side of the tachometer and the indicator needles of both the tach and speedometer.
From what I researched, the bulbs are only available at dealers. Is this true?
Also, am I looking replacing 1,2 or 3 bulbs?
Thanks
MIke
Add to Mike H's Reputation
Rate the quality of this post and help Mike H reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mike H is offline   Reply With Quote
Old 12-20-2009, 12:26 PM   #2
born again
born again is on a distinguished road
2000 L-Series 2.2L Wagon
Default Re: Instrument Panel Lights
A site called www.autolumination.com carries these bulbs. You may also try a local auto parts store. The best is to remove the instrument cluster and pull one of the bulbs out and take it to the store. I advise to change all of the bulbs at once because if three are burned out you have about 6 or 8 more about to go. Removing the cluster is rediculously easy.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-23-2009, 02:12 AM   #3
ruley73
ruley73 has a spectacular aura aboutruley73 has a spectacular aura about
ruley73's Avatar
2000 SC2
The bulbs in question can be replaced with Wagner p/n PC118. These can be found at NAPA for ~$1.50/ea.
I also agree that you might as well change them all while you have the I/P cluster out.
2000 SC2 5-spd, H&R Sport springs, KYB struts, AEM CAI, Hotshot header, Prothane engine mount inserts, 1995 Teardrop II wheels, Saturn Ion MP3 stereo, heated upstream O2 sensor...231K miles
Add to ruley73's Reputation
Old 12-27-2009, 08:58 PM   #4
macman90
macman90 is on a distinguished road
macman90's Avatar
2002 L-Series 2.2L Sedan
I highly recommend
http://superbrightleds.com. I find the best fit for my cluster was the B8.5 LEDs, and they work very well. Just navigate their site and get into the car instrument cluster bulbs, then look for the B8 series. There are several different options, I recommend B8.5.
Add to macman90's Reputation
Rate the quality of this post and help macman90 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macman90 is offline   Reply With Quote
Old 01-01-2010, 10:09 AM   #5
4madkids
4madkids is on a distinguished road
4madkids's Avatar
2001 L-Series 3.0L Wagon
I've found that sometimes changing bulbs is not the answer. Poor socket contact was mine, x2.
I changed the bulbs with new - same prob. Before you reinstall the trim, etc, turn the lights on and verify.
"I used to work at a factory where they made hydrants; but you couldn't park anywhere near the place." - Steven Wright
Add to 4madkids's Reputation
Rate the quality of this post and help 4madkids reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
4madkids is offline   Reply With Quote
99 SL2 Instrument panel lights devicenull S-Series Tech 5 11-18-2008 02:21 AM
instrument panel lights problem bradburrage S-Series Tech 5 07-28-2008 10:22 AM
Accidentally burned out instrument panel lights and reverse lights on '99 Saturn Sc1 tjohnny42 S-Series Tech 19 07-09-2008 09:40 PM
Instrument Panel Lights 2000SW S-Series General 11 10-17-2005 11:44 PM
'01 SC2 Instrument Panel lights.... gm7 S-Series General 5 02-06-2004 04:04 PM
