Old 12-10-2009, 06:46 PM   #1
adam2887
adam2887 is on a distinguished road
adam2887's Avatar
1996 SL
Default where to buy "blend door actuator" ?
had a clicking noise, turns out it was the blend door actuator sticking and trying to move.
I have been to my local auto parts stores to buy a new one, and they have nothing. i have looked online and they dont seem to have anything either. Anyone have any ideas? i suppose a junkyard is my next step if i cant find it.
Add to adam2887's Reputation
Rate the quality of this post and help adam2887 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adam2887 is offline   Reply With Quote
Old 12-10-2009, 07:23 PM   #2
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2003 VUE 2.2L
Default Re: where to buy "blend door actuator" ?
Go make some friends at your local JY!
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 12-10-2009, 08:01 PM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Is this the door check?
http://saturnseries.net/DIY%20Guides...or%20Check.htm
If it is, there's a very good chance that the popping isn't a problem with the door check, it's just that the metal on the door flexing & popping back to shape as the check reaches each stopping point. I removed the door check on my wife's car it got so bad.
*edit* on second thought, I'm guessing this is an HVAC part. Very good chance that junkyard or dealership are your options.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 12-10-2009, 08:50 PM   #4
adam2887
adam2887's Avatar
1996 SL
blower assembly behind glove box
looks like this
Old 12-10-2009, 09:42 PM   #5
Part number 16124567. Get it from a junker car as 91-99 are all the same or buy a new one here: http://www.trademotion.com/splash/in...?siteid=214643 Its a 34.00 part so I would be on the way to the J/Y and the dealer will want much more.
Old 06-08-2013, 08:35 AM   #6
PCBYTC
PCBYTC is on a distinguished road
Thumbs Up Re: where to buy "blend door actuator" ?
Old post, felt it needed an update. This part is available at Autozone/any of the generic auto parts places now and (more importantly) I figured out the easiest way to replace it on a 2003-2007 ION! It is WAAAAAY up the top right corner of the dash, the easy way to replace it is to remove the top plate on the dash, then remove the 1 visible 10mm bolt on the right side, then make 2 cuts (I used a utility knife, but it was HARD) to 2 small joints near the bolt so you can remove that section of the plastic covering the far right top corner.
It's right there, just under the windshield, just pop it out (no screws hold it) and pop in the replacement. Then put the plastic back that you cut out, it will be held in-place by the 10 mm bolt. Reassemble the dash top. enjoy.
I'll post some pics later.
Add to PCBYTC's Reputation
Rate the quality of this post and help PCBYTC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PCBYTC is offline   Reply With Quote
Old 06-08-2013, 09:05 AM   #7
Madness10
Madness10 will become famous soon enough
Madness10's Avatar
You are posting on a S series forum about an Ion. You need to post this in the Ion section.
Add to Madness10's Reputation
Rate the quality of this post and help Madness10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Madness10 is offline   Reply With Quote
Old 12-17-2013, 07:54 PM   #8
dick555
dick555 is on a distinguished road
1993 SW2
Do you know if this part will work in a 1993 saturn sw2?Part number 16124567.
Add to dick555's Reputation
Rate the quality of this post and help dick555 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dick555 is offline   Reply With Quote
Old 12-17-2013, 08:33 PM   #9
Madness10
Madness10's Avatar
Refer to post 5. Yes it will work.
Old 12-18-2013, 09:40 PM   #10
dick555
1993 SW2
Thank You for your help with this problem. I will buy the part and look to have it replaced around here. I am not a mechanic and do not have any tools at this time. Thanks again.
Old 07-11-2014, 04:53 PM   #11
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
I now have replacement gears available as a more durable alternative to the dealer replacements!
See this thread:
http://www.saturnfans.com/forums/sho...68#post2078468
Mechanical Engineer - I make parts, like blend door actuator gears.
2005 Volvo S40 T5 AWD - 62k
1998 SL2 - 240k
1993 Geo Tracker 4x4 - 134k
1996 Geo Tracker 4x4 - 106k
1987 Mercedes 300D - 154k
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 07-11-2014, 07:30 PM   #12
RobertGary1
Very nice gears. I went ahead and about a new actuator from the dealer. The gears are prone to failure and the j/y's I looked at seemed to be marginal as well. $50 but now the recirc button always works.
-Robert
Old 07-11-2014, 08:27 PM   #13
wingsauce7
wingsauce7 has a spectacular aura aboutwingsauce7 has a spectacular aura about
how do you get into the actuator housing without dicking it up?
5 Speed
390,000 miles!
Add to wingsauce7's Reputation
Rate the quality of this post and help wingsauce7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wingsauce7 is offline   Reply With Quote
Old 07-11-2014, 08:36 PM   #14
colonelhogan44
Check this video (also just posted in the other thread):
https://www.youtube.com/watch?v=fER3...ature=youtu.be
1998 SL2 - 240k
TTAC: Chinese "Brilliance" Automaker May Buy Saturn Brand irish56 General Saturn Discussion 3 11-24-2009 03:59 PM
Where to buy "shock absorber" type engine mount for 91 SL2? snooop1e S-Series General 2 04-05-2007 08:32 PM
Where to buy "Total Seal" piston rings? meseville S-Series Tech 1 03-13-2007 05:21 AM
Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door???? Token S-Series General 21 09-08-2005 09:14 PM
Opinions wanted: Buy new car or "hot rod" my current ride DVader General Saturn Discussion 13 02-27-2003 07:56 PM
