Old 12-09-2009, 07:18 PM   #1
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Default Power door lock switch failed
The power door lock switch failed on the drivers door on my VUE. The day before it failed it was raining. I was at a drive thru and noticed more water than usual leaking inside the VUE on the inner door panel. The next day the switch stopped working.
You'd figure the switch was at least water resistant. The replacement switch was made in Japan and cost around $22 with shipping. You have to remove the inner door panel, and insulation system to replace it.
I was very impressed at the amount of insulation Saturn used in the door, and the custom insulation panel. My SC had almost zero insulation.
Add to BobbyP's Reputation
Old 12-10-2009, 03:02 AM   #2
My own VUE
My own VUE is on a distinguished road
My own VUE's Avatar
Default Re: Power door lock switch failed
Interesting. Do you have a link to where you bought that door switch for future reference??
Thanks,
Ian
Add to My own VUE's Reputation
Rate the quality of this post and help My own VUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
My own VUE is offline   Reply With Quote
Old 12-10-2009, 03:44 PM   #3
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
http://www.trademotion.com/partlocat...layCatalogid=0
Saturn of Glen Burnie... aka... getsaturnparts.com
Old 12-11-2009, 11:20 PM   #4
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
When I get back to New Orleans, I'll do a post mortem on the failed switch.
I'll see if it can be resurrected with possibly some contact cleaner. If water can get into the switch, then a solvent cleaner should also.
Yesterday it was 8 degrees in Chicago, today it was 22 degrees. It felt much better...
Old 12-18-2009, 07:12 PM   #5
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
The power door lock switch is made by Alps. It uses the same construction as a computer keyboard with a pc board and a rubber plunger with a contact material.
This type of switch design does not tolerate water or liquids well.
Cleaning it did not help. All I can suggest is do your best to keep rain, or any cleaning fluids from entering the switch.
I can post pictures of the switch if anyone is intersted.
Old 12-19-2009, 08:15 AM   #6
mrtube
mrtube is on a distinguished road
Wow, they used an ALPS switch? thats an actual quality brand name. I would've expected either unmarked or delphi\delco
Add to mrtube's Reputation
Rate the quality of this post and help mrtube reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrtube is offline   Reply With Quote
Old 03-26-2010, 09:37 PM   #7
atasha
atasha is on a distinguished road
Great. I just want to know, when you remove your door lock switch. Did you remove your entire door panel or is it the other way around? Can I do the replacement by myself with manual?
Add to atasha's Reputation
Rate the quality of this post and help atasha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
atasha is offline   Reply With Quote
Old 03-27-2010, 09:01 PM   #8
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
You have to remove the whole inner door panel. The power door lock switch has an 8" wiring pigtail with a connector on the end. It takes a bit of work to get your hand inside the door and operate the tab to unplug the wiring connector.
I did it without the manual. Here's what I remember, I'm in Philadelphia...
You have to remove the door handle cover-prys off from the bottom (2 screws behind it), high frequency speaker cover-prys off from the top (1 screw behind it), and remove push pins on the side of the door; and the door panel should pull off. It's a bunch of clips holding it to the door.
Old 04-10-2017, 05:46 PM   #9
purplenova
purplenova is on a distinguished road
Tried this over the weekend and the panel would not come off. Does the panel that hold the switch and release lever come off also. Something in the center was holding it down, or so it seemed. All other bolts were removed and the edge of the panel was loose, but would not come off.
Add to purplenova's Reputation
Rate the quality of this post and help purplenova reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
purplenova is offline   Reply With Quote
Old 04-19-2017, 10:46 AM   #10
purplenova
Thought for sure someone would have answered by now
Old 04-19-2017, 12:18 PM   #11
far2grumpy
far2grumpy's Avatar
Front door side panel removal extracts are too large to post but I've attached thumbnails for removal (reverse for reinstall).
Three other files are within posting limits and are attached.
Good luck and repost or send PM if you need more info.
Old 04-20-2017, 08:04 AM   #12
purplenova
Nice - Thank you so much
I knew there was more - I missed the screw in the door handle pocket.
How to Change Power Door Lock Switch 98 sL2 rideox4 S-Series General 27 03-19-2017 05:45 PM
Removing power lock switch megaman8x S-Series Tech 1 12-07-2009 07:13 PM
98 power door lock switch (left side) RickKlages S-Series General 4 02-07-2007 04:09 PM
What's holding in the power door lock buttons in the door handle? Smokey S-Series Tech 2 09-22-2006 04:52 PM
sunroof relay and power door lock switch micronrb Classifieds 0 10-04-2005 01:22 PM
