Old 12-07-2009, 05:36 PM   #1
SickSc1
SickSc1 is on a distinguished road
Default Heat Not Working In 96 SC1
I have a 96 saturn SC1 SOHC 5 speed with original motor and clutch (122,000 miles) and it is blowing air out of the vents but it never blows hot or warm air. My engine temp is usually past 1/4 to 3/8's of the way warm. It doesnt work if its a long or short drive, hot or cold. I would also like to know how to bring back some of that old power and maintain it with high miles. Yesterday i put the Lucas Oil 4 in 1 in. Will the DOHC spark plugs work in the SOHC? (are they gapped the same?)
Add to SickSc1's Reputation
Rate the quality of this post and help SickSc1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SickSc1 is offline   Reply With Quote
Old 12-07-2009, 08:28 PM   #2
aa4lr
aa4lr has a spectacular aura aboutaa4lr has a spectacular aura about
1995 SC1
Default Re: Heat Not Working In 96 SC1
Sounds like your heater core may be blocked. Seems like you can use a reverse flush to try to unblock it. There should be some suggestions in the forums if you search.
Spark plugs for SOHC are similar to the DOHC, but are one stop hotter. Recommended plug for DOHC is NGK BRK5ESA-11, SOCH is NGK BRK4ESA-11.
Check the condition of your plug wires, you might want to replace them. Also take off the intake snorkle and check the back-side of the throttle plate. If it is covered with black goo a throttle body cleaning is in order.
Of course, the very first thing you should do si check to see if you have a brass ECTS and replace it if not. Check the How To library at the bottom of the page.
Bill Coleman
2001 Saturn SC2 Auto (3/13-...) "Yellow"
1999 Saturn SL2 Auto (11/09-...) "White"
1995 Saturn SC1 Manual (9/08-...) "Gold"
1994 Saturn SL1 Auto (7/94-1/04) 144,000 miles "Green"
Add to aa4lr's Reputation
Rate the quality of this post and help aa4lr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aa4lr is offline   Reply With Quote
Old 12-07-2009, 09:17 PM   #3
mr18436572
mr18436572 is on a distinguished road
2000 SL2
Wrong temperature/faulty thermostat and blocked heater core will affect interior heat
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 12-07-2009, 09:42 PM   #4
Col.FUBAR
Col.FUBAR is on a distinguished road
Col.FUBAR's Avatar
1994 SC2
May also want to check if the slider that moves the temp range from hot to cold is still attached and not hung up on something behind the dash.
I'm not sure if this applies to the second gen's or not but the first gen Saturn's are known for hanging the cable to control the temperature slider up on something.
Former DD: 1994 SC2 5spd. 190K, being sold to a friend
2005 Saturn ION 2 5spd. 73K
1995 Aquamarine SL2
1.9L DOHC 5spd. ~125K Miles
Add to Col.FUBAR's Reputation
Rate the quality of this post and help Col.FUBAR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Col.FUBAR is offline   Reply With Quote
No Heat in SC1 BRIAN41920 S-Series Tech 4 11-06-2009 09:21 PM
2001 Saturn A/C Heat Blower stopped working lrslooney L-Series Tech 3 01-18-2009 06:14 PM
HELP!! Squicky Noise in stearing and heat in seats isn't working loly75ddl Vue Tech 5 12-21-2006 07:24 PM
A/C not working and get low humming noise when turning on the heat. jc123 L-Series General 2 04-12-2006 01:28 PM
2001 L300 AC/Heat Fan Not Working NoDents L-Series General 6 10-25-2005 09:04 AM
