Old 02-01-2014, 03:38 AM   #21
carfreak09
carfreak09 is on a distinguished road
1997 SL1
Default Re: Saturn oil leak
Originally Posted by sallydriver View Post
I once chased an oil leak for months, only to find I hadn't tightened the crank pulley bolt tight enough.
How much oil were you loosing from this bolt not being tight? Is there a seal behind the pulley that might need to be replaced? The lower dogbone mount is completely caked in oil. I just can't imagine that the valve cover seal is the main culprit. It might leak a little, but not enough to cause this mess.
Add to carfreak09's Reputation
Rate the quality of this post and help carfreak09 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carfreak09 is offline   Reply With Quote
Old 03-26-2014, 02:21 PM   #22
katekev04
katekev04 is on a distinguished road
Took in my husband's 1997 SL for inspection, it is leaking like a sieve, puddle when parked and drips while pulling out of the driveway for a good 20 feet, it has always burned oil, but this leaking began after the head and timing chain were replaced. It is now throwing 3 codes (don't know which) that are not registering to throw on the CES. Taking it in tomorrow afternoon to see if we can find the culprit....hopefully nothing major.....considering the above repairs that were just completed.
Add to katekev04's Reputation
Rate the quality of this post and help katekev04 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
katekev04 is offline   Reply With Quote
Old 05-10-2014, 07:43 PM   #23
jhonky
jhonky is on a distinguished road
checked my oil yesterday and i was suspiciously low(3/4 qt). checked about 2 weeks ago and it was pretty much full. put a towel under my car at work today and confirmed i do have a leak again, same area(right under where the filter screws in) the first time i thought it was because i put the filter on too tight but the last 2 oil changes i've made sure to put it on correctly. i might try the oil pan nuts thing, idk. doesn't seem like it does it all the time cause i know i've gone some times without it leaking.
i will just continue to top off i guess, i can handle 1 qt every 3k miles
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 05-10-2014, 09:31 PM   #24
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
I was losing a quart per 20 miles. It was ridiculous. It was several months after I replaced the crank pulley too. Yes there is a seal behind it. It's only about $7.
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 05-20-2014, 07:03 PM   #25
jhonky
Down about a quart in about 10 days. Big puddle under the car today after about 6 hours. Gonna take it in Friday I think
98 SL2
245,000 miles
215/45 17"
Old 11-30-2015, 05:59 PM   #26
510man
510man is a glorious beacon of light510man is a glorious beacon of light510man is a glorious beacon of light510man is a glorious beacon of light510man is a glorious beacon of light510man is a glorious beacon of light
I have this same leak. Under the filter but not the filter. I've change the filter twice and cleaned the block with a razor blade to ensure it's clean before mounting the filter.
What did you figure out?
Add to 510man's Reputation
Rate the quality of this post and help 510man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
510man is offline   Reply With Quote
Old 12-02-2015, 04:09 AM   #27
510man
I did the toiletpaper around the valve cover. It's not leaking there. It appears higher than the oil pan. There is a sending unit on the block that I'm guessing is the oil pressure sender. It's wet so it could be that. Could be the head gasket too as I see oil that high. I use to have to re-torque the head on my Alfa. Do you have to re-torque Saturn heads?
I don't think it's the crank seal since 1) the oil is higher up the block and 2) the oil is all on the firewall side of the engine. I would think the crank seal would result in some oil make it to the front side of the engine with the heaviest oil on the passenger side where the crank pulley is located. .
Old 12-05-2015, 09:11 PM   #28
Hardy
Hardy is on a distinguished road
If you still have a oil leak i had it leaking from the pcv valve hose on the back side of motor.
Add to Hardy's Reputation
Rate the quality of this post and help Hardy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hardy is offline   Reply With Quote
Old 12-08-2015, 12:14 AM   #29
510man
Thanks. I've eliminated the PCV already.
Old 02-06-2016, 07:31 PM   #30
510man
I think I may have located my oil leak. After changing the valve cover gasket, which was one leak, I cleaned off the back side of the block. 1000 or so miles later, I have a lot of oil on the back of the block again but none up by the manifold.
There is a sending unit near the alternator that I believe is the culprit. It's extremely wet and has drops of oil on it. There is very little oil on the block above that point.
Is that the oil pressure sending unit? I'm not sure what else it would be given its location. I just want to make sure I'm ordering the correct sending unit.
Thanks.
Old 02-09-2016, 12:18 PM   #31
Could be (image courtesy of off-track)
Another image of more sensors including oil
http://ww2.justanswer.com/uploads/dj...crank_0000.jpg
and photo (credit to mattelderca)
Old 02-10-2016, 09:33 PM   #32
510man
Thanks for the pic.
I believe it's #16 in your pic, which is the oil pressure sensor. I'll order one and see if it resolves my problem.
I'll also post back if it fixes the problem, which , unfortunately, the earlier poster never did. :-( I"ll have to clean up the back of the engine and run it awhile to be sure so it may be several weeks before I post back on results.
Old 05-13-2016, 01:36 AM   #33
510man
My oil leak is fixed. Was the oil light sending unit. That's pretty easy to get to but not easy to get to with a wrench. Thought it would take 5-10 minutes to replace. Took quite a bit longer due to the wrench angle.
I'm about two weeks with no leak. Car sat undriven for four days with no spots underneath so I'm pretty confident the sending unit resolved the problem.
Old 05-13-2016, 10:37 AM   #34
Nice, thanks for the follow-up. Always good to have something like that resolved.
Next oil change, I may put a wrench around mine and make sure it is tight. I think I have a very small oil leak - no oil on the garage, even sitting over the weekend, but the bottom of my oil pan is always wet with oil. Small enough that I have not chased it down.
Old 05-13-2016, 11:01 AM   #35
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
My oil pan was wet with oil and I seemed to have fixed the issue by replacing the O-ring gasket of the oil pan drain plug. Old Nuc advised that a slow seepage and rushing wind while driving could cause the pan to be covered with oil over time. It seems he was correct.
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
2001 Saturn SL1 oil pan gasket leak jcm22 S-Series Tech 6 09-12-2009 03:05 PM
Oil Leak In 2000 Saturn SL! 2000saturn820 S-Series General 8 04-21-2009 07:33 PM
1996 Saturn, Oil Leak, 1 Bad Cylinder Pake S-Series Tech 2 03-31-2008 01:10 PM
Oil Leak? Not oil pan, not valve cover, not front oil seal. klcl S-Series Tech 14 10-05-2007 12:25 PM
1994 Saturn SC2 Oil Leak shadow0064 S-Series General 4 01-23-2006 10:45 PM
