Old 12-05-2009, 12:07 PM   #1
sprinj76
sprinj76 is on a distinguished road
sprinj76's Avatar
2006 ION Red Line
Default grinding/rubbing sound when I turn to the left. . .
So I've been chasing this issue for about 2 months now.
I've done a lot of searching and reading the old forum posts. This problem arose after replacing my front wheel bearings and hubs. All the press work was done by a shop. The only time I have a rubbing/grinding noise is when I turn tight to the left the noise is coming from the passenger wheel well, and it seems like i'm getting some feedback in the wheel.
First I thought it was my brake pads hitting a rusted area on my rotors, due to them sitting slightly different on the new hubs. After replacing both the pads and rotors (they weren't even warped ) The noise has not changed, but braking has improved with the better pads .
Next after reading I thought it was a brake line they may have gotten looped the incorrect way while installing my calipers. Checked the brake lines, and they are both looped toward the rear of the car.
I have turned my wheels full to the left and checked under the car, along the tires, brake lines, calipers, steering knuckle and nothing is rubbing.
The two things left that may be the calprits are possibly my strut or something suspension related making noise ( I did have a little squeak which came from my strut after my car sitting on jack stands for two days, this noise eventually went away after about two weeks of driving) or maybe something to do with the steering system.
What I could use from you fine people is ideas, procedures to check a specific component, or anything else you might think it could be.
Recently replace parts: front wheel bearings, hubs, lower control arms, driver outer tie rod end, pads, and rotors. I do all my own work on the car. A four wheel alignment was done after the wheel bearing replacement.
Black Onyx '06 Ion Redline w/ comp package
Red '97 SC2 5-speed --sold
Add to sprinj76's Reputation
Rate the quality of this post and help sprinj76 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sprinj76 is offline   Reply With Quote
Old 12-05-2009, 03:34 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: grinding/rubbing sound when I turn to the left. . .
the noise may be the front upper strut mount bearings.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-07-2009, 09:00 AM   #3
DonP
If you cannot find anything in the suspension and this may not be your issue.
FWIW: a groaning sort of sound when making a left turn was one of the early symptoms of my failing top engine mount.
Add to DonP's Reputation
Old 12-07-2009, 09:23 AM   #4
signal7
signal7 is on a distinguished road
1998 SL
1999 SL
I would try and isolate individual components and reproduce the problem. In the suggestions given here, you should also have a friend sit in the driver's seat because some sounds can only be heard from inside the car.
Try bouncing the front end suspension while stopped and see if that reproduces the noise. Do the same for the rear because the body of the car can transmit sound and give a false impression of where it's coming from. Besides that, it's an easy test.
Is the sound only heard when turning the steering wheel? ie: if you turn left in a parking lot and hold the steering wheel at a constant position while the car is in motion, does the sound go away? If so, jack the front end up, insert the key, turn to ACC, and turn off (disables steering lock). Go to the front passenger tire, get a good grip at 3 and 9 o clock, and push the steering right and left manually using the tire only. Since you'll be physically nearer to the source of the sound, it should be easier to figure out where it's coming from. This would just tell you if a steering component is causing it, but it wouldn't tell you much else.
If it makes the sound constantly while turning left in the parking lot, then you can eliminate most of the suspension components and the steering components. However, based on your description of what's been replaced, I'm not sure what it would be in that case. You might have to start inspecting the inside passenger's side of the engine compartment for sources of the noise.
Is the tire rubbing against something?
Add to signal7's Reputation
Rate the quality of this post and help signal7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
signal7 is offline   Reply With Quote
'99 SL has grinding/rubbing noise puckalicious S-Series General 20 04-16-2009 10:12 PM
Rubbing/Grinding Noise Up Front in Very Sharp Turn Old Crow S-Series Tech 14 12-15-2007 03:37 AM
SC2 Grinding/ rubbing noise when turning?? Litzer S-Series Tech 10 09-19-2007 09:46 AM
rythmic metalic squealing on left-hand turns on accel; tire noise on normal left turn rtfm17 S-Series Tech 4 08-25-2003 08:37 AM
Squeeking/Rubbing/Grinding Noise MrSector9 Miscellaneous Tech 4 07-07-2001 07:02 PM
