Old 12-04-2009, 06:23 PM   #1
onixwj
onixwj is on a distinguished road
Default 1992 SL2: spark, fuel, air, no fire (new air & fuel filter, spark plugs, wires)
1992 Saturn SL2 DOHC 275,000 miles
Car stalled while driving at about 10mph. Wouldn't start. Turned over, but no firing. Fuel gauge low, so assumed out of fuel. 12 hours later, added fuel, started without hesitation. Re-fueled and realized it had *not* been empty. After a couple miles of driving, stalled again. Towed home.
After sitting a week, started without hesitation. Didn't drive it. Fuel filter had about 75,000 miles on it, so replaced that. Replaced dirty air filter. Fired once while cranking, but didn't start. No more firing.
Observed spark between coil towers 1 & 2 (didn't look at others). One terminal corroded. Valve cover gasket is leaky, so three plugs were oily (about 2" of oil in wells). Plugs covered in carbon deposits. Replaced plugs and wires. No firing. Pressed fuel test valve and got a spray.
What next?
Add to onixwj's Reputation
Rate the quality of this post and help onixwj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
onixwj is offline   Reply With Quote
Old 12-05-2009, 12:03 AM   #2
redkees@msn.com
redkees@msn.com is on a distinguished road
redkees@msn.com's Avatar
2004 VUE 2.2L
2008 AURA XE
Default Re: 1992 SL2: spark, fuel, air, no fire (new air & fuel filter, spark plugs, wires)
Clean the corosion off the coil tower tips gently with steel wool until shiny, apply dialectic grease on the tips and re-install spark plug boots.
Take plugs out of engine clean off oil regap at .040 and reinstall. Replace ECTS-engine coolant temp sensor, probably cracked if it the original; replace with new steel tipped replacement and also replace the wire connector too.
Start the car and see if it runs. Then plan on replacing cam cover gasket to stop leaking oil on the plugs.
Previously Owned 98 SL2, Sold
98 SL, Sold
When your Saturn is well kept YOU are well kept.
Second Car: Buick LaCrosse 2006
Add to redkees@msn.com's Reputation
Rate the quality of this post and help redkees@msn.com reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
redkees@msn.com is offline   Reply With Quote
Old 12-05-2009, 09:22 AM   #3
onixwj
Thanks for the suggestions, Redkees. Responses follow inline:
I did that when installing the new wires.
The new ones came with grease applied.
I believe they were pre-gapped at .04, though in a rush and in the rain, I didn't dig up my gap gauge and verify. In the past, I always have, and have always found them to be gapped properly already. I'll double-check.
It was replaced about 75,000 miles ago. I don't know if the mechanic used the newer, preferable, design, or one that was the same as the original. I'll check it for cracking.
Would a faulty ECTS prevent the engine from firing when the starter is cranking?
That's been in the plans for quite some time, though it seems that I need to bump up the priority now.
Old 12-05-2009, 10:33 AM   #4
If the engine starts and runs and then stalls when its warmed up do the following. Right after it stalls remove the #1 and #4 plug wire from the coil and crank the engine, if no spark jumps between the 1-4 towers then the CKS, Crank Position Sensor, has failed. Replace it. It is a 14.00 part at the parts store and is conveniently located behind the starter on the back of the block. There is a richpin video on how to replace it.
Old 12-05-2009, 12:14 PM   #5
onixwj
Thanks. If I can get it to start and it stalls again after warming up, I'll be sure to check this.
For now, it won't start, and it's cold.
Old 12-05-2009, 01:00 PM   #6
Then run the spark test. They will eventually die where there is never any spark.
Old 12-06-2009, 12:01 PM   #7
onixwj
Now, after sitting for about a day and a half, it started immediately when I tried.
Old 12-06-2009, 12:06 PM   #8
That still could be a failing CKS (crankshaft position sensor). If it dies again promptly do the spark test.
Nothing ever fixes itself.
Old 12-07-2009, 01:30 PM   #9
onixwj
I didn't drive it yesterday after starting it. It sat for about 24 hours, and started immediately when I tried this morning. I stopped it, started again without trouble, and let it idle for an hour. No problem. Stopped it, started again, drove it around the block a few times, then stopped it.
Then it sat for about an hour, and when I tried to start it, it wouldn't fire. I then removed the leftmost spark plug wires (for cylinders 1 and 4) from the coil tower, cranked the engine, and found that a spark was jumping between the two terminals.
I'm stumped.
Old 12-07-2009, 04:20 PM   #10
Put the wires back on and see if it will start. When it dies what dash lights come on? Oil pressure for sure but what else if anything.
Old 12-07-2009, 04:35 PM   #11
onixwj
I did that. It didn't start.
I'll check this evening and report back.
Old 12-07-2009, 05:25 PM   #12
The trick is going to be to figure out what is shutting it down.
Old 12-11-2009, 08:07 PM   #13
onixwj
After sitting a few days, it started right up without hesitation.
Hoping to read any codes that the computer might be showing, I checked the instrument cluster bulbs, found two burned out, and swapped them to the airbag and anti-lock brakes spots, since this care doesn't have either feature.
With known-good bulbs (known by swapping them to another position and observing them lighting) the service engine, overheat, and up-shift lights do not light when turning the key to the on position. Do these three have anything in common?
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 07:29 AM
Dealer pricing on spark plug wires and spark plugs. KeithR S-Series General 25 05-19-2011 11:52 PM
2001 sl2 cranks, has fuel & spark - no start thillaj S-Series Tech 6 02-09-2009 10:35 PM
air filter and spark plugs bo. S-Series Tech 20 01-16-2008 08:17 PM
has spark, air and fuel but wont start kre8ive_kustomz S-Series Tech 28 06-23-2006 10:06 PM
