Old 12-24-2009, 01:36 PM   #61
Default Re: '99 SL2 Engine Rebuild
And, if you have an automatic dishwasher you can clean the steel parts in it. Do not wash bolts though as they can rust on you.
I mean you already discovered the bathtub wash tank, might as well go for the automatic hot washer. Then there is the 180F paint curing oven.
Old 12-24-2009, 01:48 PM   #62
rentfrow1
rentfrow1 is on a distinguished road
When you say to remove all the steel parts, does that include the alignment dowel pins that are pressed in around many of the bolt holes in the block?
Add to rentfrow1's Reputation
Rate the quality of this post and help rentfrow1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rentfrow1 is offline   Reply With Quote
Old 12-24-2009, 02:49 PM   #63
No, just the bracketry and all bolted removable parts. Leave the pressed in dowels in place.
Old 12-24-2009, 02:57 PM   #64
rentfrow1
Questions not answered yet:
  • One alignment dowel broken off flywheel during resurfacing. Does it matter?
  • Oil pump: how do you measure to see if it is in spec? The lobes are a little nicked, but don't look worn down.
  • Is heating the timing cover in the oven to remove the oil pressure relief valve a good idea, or will it even work?
New questions:
  • The Loctite 518 should work well for the transmission housing, right? I had it apart to clean the magnet and weld the diff pin.
  • What fasteners need threadlocker? I think it was just the oil pump cover, right?
  • I ended up with two electrical connectors labeled CPS. What could the other one be? I have the oil pressure sensor, knock sensor, CPS, and CCPS, but I don't know what the 5th connection is for. I think it came from near the CCPS and CPS area.
  • Should I replace my PCV valve? I replaced it soon after I got the car, and never worried about it. The little weight/magnet still rattles around in it, and I have cleaned it a few times.
Old 12-24-2009, 02:58 PM   #65
rentfrow1
Yeah, the painted brackets would come out nice and silver I bet.
Old 12-24-2009, 04:30 PM   #66
rc1488
rc1488's Avatar
  • One alignment dowel broken off flywheel during resurfacing. Does it matter? Most likely not. They are just used for alignment. Be extra careful now though
  • Oil pump: how do you measure to see if it is in spec? The lobes are a little nicked, but don't look worn down. Just replace it
  • Is heating the timing cover in the oven to remove the oil pressure relief valve a good idea, or will it even work? Just use a socket and a hammer
New questions:
  • What fasteners need threadlocker? I think it was just the oil pump cover, right? Thats it. Nothing else
  • I ended up with two electrical connectors labeled CPS. What could the other one be? I have the oil pressure sensor, knock sensor, CPS, and CCPS, but I don't know what the 5th connection is for. I think it came from near the CCPS and CPS area. Power steering or alternator. All in the same area.
PCV should be fine
Add to rc1488's Reputation
Old 12-25-2009, 12:28 PM   #67
rentfrow1
Merry Christmas!
Definitely not the PS or Alternator. It came from the flywheel end of the engine, near the CCPS and CPS. It looked like there was a fuel line connection near there. Is there a fuel pressure sensor or something back there?
Old 12-25-2009, 02:19 PM   #68
Special Forces
Special Forces has a spectacular aura aboutSpecial Forces has a spectacular aura aboutSpecial Forces has a spectacular aura about
Special Forces's Avatar
2006 ION Red Line
Replace the gone dowel. You turn the flywheel over and punch them out from the back side with a drift punch. They are critical to the proper operation of the clutch cover. The bolts only hold the cover to the flywheel and the dowels prevent rotation of the cover. The dowel fits relatively tight into the mating hole in the cover. Looks like a trip to the scrap yard.
He said it on the last page.
/// Need rebuilt valve bodies? PM Me. \\\
//// Why bother with ebay when I'm right here? \\\\\
Valve bodies built to order
Please PM me about valve bodies, do not post a visitor message.
Add to Special Forces's Reputation
Rate the quality of this post and help Special Forces reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Special Forces is offline   Reply With Quote
Old 12-30-2009, 01:09 PM   #69
92SC2
92SC2 is on a distinguished road
edit: Just kidding. I forgot the chain $52. Cloyes it is.
$27 at Auto Zone
Add to 92SC2's Reputation
Rate the quality of this post and help 92SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92SC2 is offline   Reply With Quote
Old 01-01-2010, 08:30 PM   #70
rentfrow1
We got the crank in. When we were putting the pistons in, we found that one of them was cracked along the edge. Now I am waiting to get new sealed power pistons. Someday I will hopefully get my car back together.
Old 01-01-2010, 08:35 PM   #71
doublemm
doublemm is on a distinguished road
Aint it just lovely....
I just got my crank back & they effed it up. gouge on the #1 main & a big scratch on the #1 rod journal.
Add to doublemm's Reputation
Rate the quality of this post and help doublemm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
doublemm is offline   Reply With Quote
Old 01-01-2010, 10:03 PM   #72
cboss
cboss is on a distinguished road
To avoid damaging the new pistons when you install them here is how I did it:
Getting them in, even with a decent ring compressor is just plain not easy.
At first I try a light tap with a rubber mallet. NO GOOD! Doesn't work.
I finally figured out how to do it.
Its not tapping or banging it that is needed.
What is needed is simply a push. Click link for some pictures to demonstrate what I mean.
http://www.saturnfans.com/forums/sho...&postcount=234
I put an upside down plastic top from a peanut butter jar (small size) on top of the piston. I then put the head of a rubber mallet on top. I then put my whole weight into it, leaning into it, with my hand on top with my arm in an angle so my body weight is pushing on my hand pushing down on the rubber mallet. You just have to keep the ring compressor tight and flat and keep pushing. At first nothing happens and then all of a sudden "swoosh" the whole piston just slides in. You don't go from ring to ring, the whole thing slides in. Make sure you put a lot of lube on the piston and rings and the cylinder is lubed. Lube it up like a "greased pig"!
Add to cboss's Reputation
Rate the quality of this post and help cboss reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cboss is offline   Reply With Quote
Old 01-12-2010, 04:26 PM   #73
rentfrow1
The engine is completely built and ready to be put back in. I forgot to bring the camera with me though, so no pictures. We did not have any trouble putting in the pistons. I put the handle of a rubber mallet on the top of the piston and hit the other end with my hand. The pistons all slid in easily, but it was also cold in the garage, probably 30-40F with the heater on. The only real trouble was cleaning out a couple bolt holes on the head that had crud in the bottom from the hot tanking. I also bent the new axle shaft seals trying to get them into the transmission, but they are cheap. Now I am just waiting for time to mate up the transmission and drop it in. I am currently trying to figure out creative ways to get the engine warmed up before starting it. Warm oil, warm coolant, maybe bring the engine inside overnight. It may not be that big of an issue, though.
Old 01-12-2010, 06:32 PM   #74
Get it warm if you do not want to start the engine dry of oil. Be sure to pull the PCM B fuse and the plugs and then crank it on the starter until the oil light goes off. Prime the oil pump through its discharge port, that is the square hole in the side of the filter base. Also fill the oil filter full of oil. Find an old hot plate the kind that gets red hot and slide it under the engine oil pan. The radiant heat will gently warm it all up. The old 2 burner coffee pot warmers are 1500 watts. Also any of the salamanders that blow hot air will get it warm or keep it warm.
Once you get the oil light to go out as soon as you hit the key put the plugs back in and the PCM B fuse and start it up and let it sit and idle till the fan cycles on and then off. Shut it off and change the oil and filter. Not restart it and go for a gentle drive, keep the RPM below 3000. After 30 minutes or so it is all broke in and the rings are definitely seated.
Make sure that the rings will properly fit the new pistons. The top ring grove can be 1.2mm or 1.5mm. A 1.2mm ring in a 1.5mm grove is a major disaster.
Before cranking the engine to prime the oil system put a squirt of oil in each cylinder and be sure to use assembly lube on the pistons and rings.
Old 01-12-2010, 06:54 PM   #75
rc1488
rc1488's Avatar
^^^+1
And also pour some oil over the cams if you have not done so before you put the cover on.
Old 01-13-2010, 12:17 PM   #76
rentfrow1
I put assembly lube on all the cam lobes and the timing chain, and I dipped all the lifters and rockers in oil before installing them. The rings fit properly in the pistons. They are 1.2mm top rings. They were a much more precise fit in the new pistons than the old ones. I probably will not get around to putting the engine in and starting it until next weekend because of school. Unfortunately graduating is more important than getting my car back.
Any tips on putting the new axle seals into the transmission? I am going to try to find something that matches the diameter of each seal. Maybe I can rig something up to fit into the diff that will hold everything square to the bore.
On another note, I don't have to do anything with the unused transmission cooling lines to the radiator, since I am switching to a manual, do I? The bottom hose is stuck in the radiator, and I will probably just cut it off.
Old 01-13-2010, 12:25 PM   #77
rc1488
rc1488's Avatar
Yes graduating is slightly more important Otherwise you'll have a car but no job to drive it to haha
Search Axle seals. Some people have come up with nice tools for this.
Yes, the cooler lines are useless for you now.
Old 01-13-2010, 12:29 PM   #78
Go get a PVC piece of pipe or coupling so you can drive the seals into place.
Old 01-13-2010, 03:14 PM   #79
rentfrow1
Now that I think about it, I may try running a bolt all the way through the diff and pulling the seal into place by tightening the bolt against the opposite side of the housing. I will probably smear some rtv on the mating surfaces to act as installation lube and sealant, unless that is a no no.
Old 01-13-2010, 03:31 PM   #80
You can only apply force to the outer periphery of the seal or you bend it. Drawing them into place does not usually offer any benefits over a proper installation tool and a big dead blow hammer, properly applied.
'01 SL2 DOHC Engine Rebuild Questions? Mdawg2009 S-Series Tech 9 10-15-2008 05:50 PM
99 Sl2 Engine rebuild claytronix S-Series Tech 5 12-18-2007 08:38 PM
Engine Rebuild on '95 SL2 - In car or remove? iss407 S-Series Tech 5 10-10-2006 04:57 PM
95 SL2 Engine Rebuild Question jclifton S-Series General 11 05-16-2006 02:20 PM
'95 SL2 for parts or engine rebuild karty72 Classifieds 20 06-07-2005 12:07 PM
