Old 11-26-2009, 12:20 AM   #1
vhayduk
vhayduk is on a distinguished road
2002 VUE 3.0L
Default Code Help -> P1779/1780/1781
I've got 3 codes in a row
I've got these three codes on my project vue (02 V6). Bought it with problems and slowly fixing them. One of the major things I did was replace the ECM. That got rid of a lot of codes, the reduced power light etc. I can actually drive it now. Replacing the ECM was recommended by the dealer where the PO had it checked out; the PO didn't like the price and sold it to me. I found a used PCM and that is where we are today.
It runs fairly decent, but does hesitate and I can tell that it isn't totally "happy". There is an odd "clacking" noise occasionally when getting on the throttle from idle as well. And no, it's not the intake runner flaps closing. There is also a strange shift I've noticed: on the 3-4 shift the RPM drops by a few hundred, then recovers and then everything is good. I'm thinking that it may be related to this P1780 code.
Any guru's have the full definition for these codes (with troubleshooting info)? P1780 seems to be a torque reduction code posted on here before; can't find a (Saturn/GM) definition for P1780/P1781.
FYI: These codes (along with many more) were also present with the old ECM.
Thanks!
Vince
Add to vhayduk's Reputation
Rate the quality of this post and help vhayduk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vhayduk is offline   Reply With Quote
Old 11-26-2009, 11:01 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Code Help -> P1779/1780/1781
Vince,
See attached trouble code explanations ...
I've got zero practical experience with this engine / transmission so can't offer any assistance other than service manual extracts.
Good luck to you.
Old 11-26-2009, 12:45 PM   #3
Those three error codes seem to run around in circles and ending with ecm replacement. Since you replaced the ecm with returning symptoms...............
A shot in the dark; remove the maf sensor completely, disassemble the small circuit subassembly from its housing tube and use a can of CRC MAF Sensor cleaner to spray the sensor clean. If theft deterrent screws are used, figure it out, just have access to the maf sensor for cleaning. Reassemble everything and cross your fingers.
Old 11-26-2009, 06:47 PM   #4
vhayduk
2002 VUE 3.0L
Thanks for the replies.
Funny that they all lead to replace ecm I do have another (third) ECM, so might pop that in just on the off chance that the used ECM I put in had issues before I got it.
Thanks for the tip on the MAF sensor. I'll be doing the 100k service right away just to rule out a bunch of things (spark plugs, timing belt jumped a tooth); while I'm doing that, I'm going to clean the MAF and TB and make sure the connections on the TB are good. Maybe I'll get lucky and find something.
Vince
Old 11-26-2009, 07:12 PM   #5
1saxman
The Aisin 5-speed auto will exhibit strange shifting under some conditions, and it is sensitive to the correct fluid (T-IV rated) and fluid level. I have been using Valvoline Max Life Dex-Merc with good success on my annual drain/fill. Checking the fluid is hazardous, as the dipstick is way down by the engine oil pan on the driver's side. Checking routine is typical - fully warmed after driving or putting the selector in all positions momentarily and with engine at idle. Take it out twice to be sure of the reading - do not overfill or run it low. If you drain/fill, make sure of correct level first, adjusting as needed. About 4.5 qts will drain - put 4.5 qts back in through the dipstick tube. There may be a fill plug on top of the trans housing but I've never looked for it. This gets about half the fluid, so do it at least three times over maybe a year to get some use out of the new fluid, which isn't cheap. Each time you drain it, you're draining recent fluid along with the old.
Add to 1saxman's Reputation
Old 03-15-2015, 10:50 PM   #6
Ruben63
Ruben63 is on a distinguished road
Wrench Re: Code Help -> P1779/1780/1781
How do you test from the ECM to the Spark Plug to make sure its making connection?
Add to Ruben63's Reputation
Rate the quality of this post and help Ruben63 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ruben63 is offline   Reply With Quote
Old 03-15-2015, 11:25 PM   #7
^ Are you aware of posting to a 5yr old thread? Some here never reply about results, positive or negative so the thread dies. While not mentioned anywhere, it would be good forum etiquette for anyone posting problems to follow up with results whether good or bad so anyone following along can benefit. It may be better to start a new thread with symptoms along with a brief history of maintenance, mileage, parts replaced.
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 05:17 PM
P2176 and P1779 Z13VUE Vue Tech 6 04-26-2008 10:46 AM
Codes p1779, p1791, and p0700 found LBL300 L-Series Tech 7 03-12-2008 10:27 PM
95 SL2, SES Code 32 and Coolant Code 84? gkainz S-Series Tech 15 04-04-2005 09:43 PM
vin egine code to original code how to check? silver97sl General Saturn Discussion 1 01-12-2004 04:17 PM
