Old 11-25-2009, 11:07 PM   #1
spandy
spandy is on a distinguished road
Question Brake Booster Check Valve...how to inspect/replace?
95 SL2 214k
I have been trying to hunt down a few bad rattles/noises over the past couple days. Had the cat replaced yesterday as it was making a ton of noise especially in the 1900-2000rpm range....almost unbareable in the cabin.
Well the only noise I have left is a fast and kinda pitchy rattle, metal sound, only heard while driving and in the 1600-1800 rpm range, other than that it's near non existent, but it seems I'm in that rpm range frequently enough that it is starting to drive me crazy!!!
I found on a google search that there was a TSB for the 94-97 SL that the brake booster check valves go bad (black in color) causing a very annoying rattle sound in the cabin, and need to be replaced with the updated, brown check valve.
Is this the check valve that plugs directly into the face of the brake booster (firewall side behind instrument cluster) and if so how do I remove it to inspect and/or replace?
Add to spandy's Reputation
Rate the quality of this post and help spandy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spandy is offline   Reply With Quote
Brake Booster / Vacuum Booster Leak Hard Pedal 97 SW2 when car sits unused 2 days+ mrbios S-Series Tech 8 01-17-2013 05:32 AM
Help with Brake Booster please bigbfarm S-Series Tech 3 08-21-2009 01:21 PM
help me to inspect the problem about the check engine light of ASTRA jazzz Astra Tech 2 01-28-2009 09:57 AM
Brake Booster kalani S-Series Tech 3 10-21-2007 04:58 PM
Brake Booster RalliArt16 S-Series Tech 5 04-11-2005 01:00 PM
