Old 11-19-2009, 06:15 PM   #1
flash1605
flash1605 is on a distinguished road
2003 L-Series 2.2L Sedan
2003 VUE 2.2L
Default 2003 L200 fuel leak from top of tank
My 2003 L200 is leaking from the top of the tank when running.....any ideas if it is leaking from a fitting or fuel pump....can I cut a hole in the floorboard under the rear seat to get access to it? Any suggestions would be appreciated.
Add to flash1605's Reputation
Rate the quality of this post and help flash1605 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flash1605 is offline   Reply With Quote
Old 11-19-2009, 07:45 PM   #2
Default Re: 2003 L200 fuel leak from top of tank
  • Does the leak continue when less than a full tank exists? Dropping the tank is probably necessary. Even if the filler neck was damaged the tank would have to be dropped for repairs.
  • Unless you're given specific dimensions on where to drill and cut in the trunk floor by anyone, you're risking puncturing the gas tank and/or lines (power and fuel).
Old 08-22-2010, 03:22 PM   #3
2002sat
2002sat is on a distinguished road
I understand this is a common Saturn problem. I'm about to drop my gas tank to see where the leak is. It happens only while the engine is running. I expect to find a bad fuel pump assy which costs $350. I believe the 90 degree hose fittings on the fuel pump are cracking.
Add to 2002sat's Reputation
Rate the quality of this post and help 2002sat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2002sat is offline   Reply With Quote
Old 11-03-2011, 07:07 PM   #4
waitingtundra
waitingtundra is on a distinguished road
Yep, happened to my moms car, should get it back tomorrow.
Add to waitingtundra's Reputation
Rate the quality of this post and help waitingtundra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
waitingtundra is offline   Reply With Quote
Old 11-30-2011, 06:15 PM   #5
Jonnyferrari
Jonnyferrari is on a distinguished road
Jonnyferrari's Avatar
2000 L-Series 3.0L Sedan
Just because this topic deals with the fuel line/tank...I am replacing my fuel filter, but I don't have a pressure gauge like the Haynes says you need when changing the filter. Can I relieve the pressure on the rail using the valve under the hood, and just collect the fuel with a rag? Or would a bunch still spray out and be excessive? I just don't see the point of a gauge for such a small preventative fix.
[Sold] 2000 Saturn LS2 premium package; 120k
Add to Jonnyferrari's Reputation
Rate the quality of this post and help Jonnyferrari reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jonnyferrari is offline   Reply With Quote
Old 10-09-2015, 08:12 PM   #6
tigapaw
tigapaw is on a distinguished road
was the fuel pump on my 2003 l200. replaced it and the 2 lines that hook to it.the pump was definitely cracked i could see the place. put new lines on because of all the effort to replace the pump. used my old sending unit. everything purring like a kitten again
Add to tigapaw's Reputation
Rate the quality of this post and help tigapaw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tigapaw is offline   Reply With Quote
L100 fuel tank leak gbroughton46 L-Series General 14 10-12-2011 10:58 PM
2003 Fuel Tank replacement aztimm Vue General 3 07-10-2008 09:50 AM
2003 L200 Leak problem aprilflower L-Series Tech 7 01-24-2008 11:50 PM
2003 L200 Fuel Pump Nightmare sanchezla3 L-Series General 0 05-05-2006 02:20 AM
Low Fuel Light 2003 L200 RustyJCNC L-Series General 7 07-31-2003 01:15 PM
