Old 11-16-2009, 08:31 PM   #1
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default Coolant leak
Plain & simple. Coolant is dripping from the passenger side of the engine (2.2L).
Can't seem to find it's source as no hoses are in that area. Seems to becoming from lower part of engine.
Could it be a leaking water pump?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 11-16-2009, 09:17 PM   #2
KLS1P
KLS1P is on a distinguished road
2004 L-Series 3.0L Sedan
Default Re: Coolant leak
Passenger side closest to firewall? Check under water pump weap hole, probably a little oil and coolant, slimey. Might be leaking from there. If so, new water pump needed. If not leaking, a littly slimey is normal.
Add to KLS1P's Reputation
Rate the quality of this post and help KLS1P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KLS1P is offline   Reply With Quote
Old 11-17-2009, 07:41 AM   #3
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
It is the side closest o the firewall. So I am guessing it is a water pump failure. More than just a weep. More like a small puddle overnight.
Generally what does it cost, and what does it entail to replace?
Also, if the pump is leaking coolant in the timing area, should my chain be replaced at this time?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 11-17-2009, 08:58 AM   #4
KLS1P
Replacing just the water pump not too bad of a job, using the water pump sprocket holding tool, which can be rented or borrowed. While your at it you will replace a couple seals on the thermostat housing, and the thermostat since your in there. The pump has a seal but that usually comes with the new pump. Rockauto has all the parts for under $100. I suggest the CARDONE SELECT Part # 5513138 water pump, it comes with the seal. The pump weep hole prevents coolent from reaching the timing case side of the bearing, so it is unlikely to get coolent in your oil from the pump. Replacing the timing chain is a lot more work, but you can just replace the pump and stop the puddle now. The chain can be done later without removing the pump, since the pump runs off the balance chain and shafts.
Old 11-17-2009, 09:35 AM   #5
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Thanx for the info.
I take it you have done this job?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 11-23-2009, 12:13 PM   #6
KickenChicken
KickenChicken is on a distinguished road
KickenChicken's Avatar
2001 L-Series 2.2L Sedan
I had a coolant leak on the passenger side and my heat core had gone bad.
Add to KickenChicken's Reputation
Rate the quality of this post and help KickenChicken reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KickenChicken is offline   Reply With Quote
Old 11-23-2009, 12:55 PM   #7
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
I'm going with the water pump. A coolant leak from the heater core would be closer to the firewall. This leak is around the front of the engine with coolant dripping on the front sway bar.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 06-30-2012, 01:24 PM   #8
rodeoclownicp
rodeoclownicp is on a distinguished road
can someone help..i hav L100...i have coolant leaking from a square hole on the passenger side...the hole is prependicular to the ground and is facing the firewall
Add to rodeoclownicp's Reputation
Rate the quality of this post and help rodeoclownicp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rodeoclownicp is offline   Reply With Quote
coolant leak SBXLI93 S-Series Tech 11 07-03-2009 07:44 PM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 11:56 AM
Coolant leak clintlight27 S-Series General 6 01-20-2007 10:24 PM
Help...Coolant leak somewhere venusfan S-Series Tech 8 03-13-2006 02:07 AM
Another !@#* coolant leak! joshjani Miscellaneous Tech 15 04-14-2002 01:17 PM
