Old 11-16-2009, 04:07 PM   #1
MyGFsSaturnSc
MyGFsSaturnSc is on a distinguished road
Wrench Please help. how to replace water pump 02 saturn sc
hi everyone.
i did a search but cant seem to find a DIY on how to replace the water pump on a 2002 Saturn SC.
has anyone done this that can do a write up? or provide a write up or link?
i'd greatly appreciate it as the waterpump on my gf's saturn is leaking causing the coolant light to go off.
any help, suggestions are greatly appreciated.
Add to MyGFsSaturnSc's Reputation
Rate the quality of this post and help MyGFsSaturnSc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MyGFsSaturnSc is offline   Reply With Quote
Old 11-16-2009, 04:30 PM   #2
1994Saturn
1994Saturn's Avatar
1994 SL1
Default Re: Please help. how to replace water pump 02 saturn sc
http://www.saturnfans.com/forums/sho...ght=Water+Pump
Welcome to the forums.
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-16-2009, 05:35 PM   #3
MyGFsSaturnSc
thank you very much for the quick responce and link. and please excuse my noob post. i dont know how i couldnt find that link
thanks again. its greatly appreciated
Old 11-16-2009, 05:42 PM   #4
2NDSOUT
2NDSOUT's Avatar
1999 SL
From experience, make sure you put the water pump pulley bolts at the 6 o'clock position and use a breaker bar with a 10MM socket and pull TOWARDS YOU to get the bolts loose. Make sure to put a wedge between the pulley and the block, so that the pulley itself stays in place. There are 3 pulley bolts, then once you get the pulley off, there are 6 10MM bolts that hold the pump in place.
Drain coolant first and remove the lower splash guard only.
Make sure the water pump mating surface is cleaned, dried and clear of the old gasket before applying new gasket (I used Gray RTV), along with a Fel-Pro Water pump Gasket.
Use PB Blaster for Best results to get the bolts loose.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 11-16-2009, 05:42 PM   #5
rc1488
rc1488's Avatar
http://youtube.com/watch?v=nRbUjGLviMY
http://youtube.com/watch?v=pRpG1BIVRcc
Add to rc1488's Reputation
Old 11-24-2009, 07:49 PM   #6
MyGFsSaturnSc
you guys rock. thanks for all the help. those videos helped out tremendously. i'm going to do this tomorrow and save myself about 200 dollars of labor from a mechanic
Old 11-24-2009, 08:00 PM   #7
linuxdude
linuxdude is on a distinguished road
Default +1 on PB Blaster, great stuff (and 6 point sockets too)
When I did my water pump I shot PB Blaster on the bolts the night before, then next day went in with a 6 point socket. It was no problemo, the bolts came right out like it was some kind of training video.
PB Blaster + overnight soak + cup of coffee = a good day
Add to linuxdude's Reputation
Rate the quality of this post and help linuxdude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
linuxdude is offline   Reply With Quote
Old 11-25-2009, 11:18 AM   #8
Default Re: +1 on PB Blaster, great stuff (and 6 point sockets too)
Originally Posted by linuxdude View Post
It was no problemo, the bolts came right out like it was some kind of richpin video.
It always looks easy when richpin does it and 99% of the time it is, but I seem to run into that one stuck bolt...
+1, between PB Blaster and coffee, all is good
coolant leak at water pump! replace or repair? sc2dohc94 S-Series Tech 12 08-01-2008 07:16 PM
I'm in, do I replace water pump w/ no leak? Fritz L-Series Tech 6 05-13-2007 10:52 AM
Dealership told me to replace water pump while... swilroy L-Series General 19 06-11-2005 12:25 AM
where is the tool to replace 2000 LS water pump? jehowelljr L-Series Tech 10 01-25-2005 02:36 PM
How hard is it to replace the water pump? shackelton S-Series Tech 4 10-24-2002 08:00 PM
