Old 11-16-2009, 02:37 PM   #1
tjohnny42
tjohnny42 will become famous soon enough
tjohnny42's Avatar
2004 VUE 2.2L
1999 SC1
Thumbs Down Heater fan not working
My 2004 Vue 2.2l 4 cyl hetaer fan will not work. I've read some past threads on this and it looks like it might be a relay, or a resistor or the blower itself. Fuses are intact. One thing I haven't read is that when I go back & forth between 0 speed & 1 speed (or 0 & any speed) there is a distinct click sound by the "alternator"? The motor acts sluggish too but no fan... Anyone?
Add to tjohnny42's Reputation
Rate the quality of this post and help tjohnny42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tjohnny42 is offline   Reply With Quote
Old 11-16-2009, 03:55 PM   #2
tjohnny42
tjohnny42's Avatar
2004 VUE 2.2L
1999 SC1
Default Re: Heater fan not working
The motor seems like it is being stressed when I try to turn the heater on was what I meant to say. It's trying to turn on but nothing. This happened all of a sudden too. between startups...
Old 11-16-2009, 05:52 PM   #3
far2grumpy
far2grumpy's Avatar
If you turn fan selector to highest setting all resistors are bypassed ... this is one way to see if fan is OK.
If fan does not run on highest setting, check: (1) 40 amp blower fuse in under-hood fuse panel, (2) HVAC blower relay in center instrument panel, or (3) large size orange wire between 40 amp fuse and one side of blower motor for signs of overheating (supposedly routed through a multi-contact connector in panel next to drivers left foot).
If interested - there's a blower schematic in post 4 of this thread:
http://www.saturnfans.com/forums/sho...d.php?t=144044
Old 12-28-2009, 12:30 PM   #4
tjohnny42
tjohnny42's Avatar
2004 VUE 2.2L
1999 SC1
Ended up taking it to dealorship. They found damaged wire in dash (so they said). All better now!
Old 12-29-2009, 05:41 PM   #5
1saxman
The AC compressor was coming on when the fan switch was engaged, whether the fan was working or not. This is standard for the VUE and many others with the selector in the floor register position or the defroster/combo settings.
Add to 1saxman's Reputation
Heater not working? houstonray Astra General 6 01-13-2015 12:17 PM
2004 Vue heater fan not working jerryt Vue Tech 2 12-09-2009 09:52 PM
2003 Saturn Ion Heater/AC fan not working BluePele Ion Tech 6 03-25-2008 08:51 AM
Heater not working 96'SL2 jaguaero S-Series Tech 26 01-18-2008 11:23 PM
Does your Saturn have a working a/c heater? saturnowner2001 General Saturn Discussion 17 10-20-2005 09:00 AM
