Old 11-15-2009, 02:52 PM   #1
ddarnell
ddarnell is on a distinguished road
Default 99 SL1 is a flood victim
My daughter has a 99 SL1 that she left in her parking lot in Virginia Beach this past week while Ida hammered the coast. She said that the water rose above the floorboards..............don't know how high, but my guess is a few inches.
The car will not turn over now. I'm a car nut, but I don't know what electronics and other critical systems are located at a level on the vehicle which may have been immersed.
I will try to determine how far the water rose and I'v instructed her to find a voltage meter to check the battery for voltage.
Unfortunately I'm on the other coast...........so I'm hoping that with help from this board I might be able to walk her or her mother through a simple diagnostic proccess. Her mother ( my wife) is currently visiting and and she's about half car guy.
Again, I understand most automoblie systems fairly well but I don't know the vehicle specifics of her Saturn.
Your help will be greatly appreciated
Thanks,
David
Add to ddarnell's Reputation
Rate the quality of this post and help ddarnell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddarnell is offline   Reply With Quote
Old 11-15-2009, 05:10 PM   #2
99Saturbo
99Saturbo is on a distinguished road
Default Re: 99 SL1 is a flood victim
If, in fact, your Saturn is an S-Series (SC, SC1, SC2, SL, SL2, SL2, SW1 or SW2), the PCM is on the drivers side. Look up under the dash to door side. You'll see a 3 wire harnesses attached. ONE phillips-head-type bolt holds in it. If its a 2000-2002, its just behind the battery.
The BCM (body control module) is near the glove box. If the car isn't starting though, it's not the BCM.
Add to 99Saturbo's Reputation
Rate the quality of this post and help 99Saturbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99Saturbo is offline   Reply With Quote
Old 11-15-2009, 05:46 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Number of wireharness connections depends on transmission type. And 1991-1995's had the PCM held in place with a phillips head fastener. 1996-1999 had a 10mm nut to be removed at the top of the PCM.
The car is a 1999. No BCM.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 11-15-2009, 07:32 PM   #4
ddarnell
Thanks for the replies. It sounds as though the water would have to be quite high to drown the PCM, if it's up under the dash. Any ideas what is down around floorboard level that could have been damaged enogh to prevent the starting system to even turn over?
David
Old 11-15-2009, 07:34 PM   #5
ddarnell
Big correction......the car is a 1991 not a 99. Someday I'll learn to type better
David
Old 11-15-2009, 07:49 PM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
David
Still no BCM.
Most of the car inside wiring harness runs along the floor. Also the fuse box is floor level.
Could be many different things depending actually how high the water got.
Mike
-2000 Saturn SC2
Old 11-15-2009, 08:38 PM   #7
ddarnell
Thanks for your help Mike. It sounds as though the fuse box is a good place to start. Are the relays in that location as well?
David
Old 11-15-2009, 09:16 PM   #8
99Saturbo
Mike,
Did the S-series not use a BCM at all? If so, then what does "GM" use to control all the functionality of the internal electronics?
Old 11-15-2009, 09:25 PM   #9
adventureoflink
adventureoflink's Avatar
Default
Mike,
BCMs IIRC were put in the 3rd gen s-series, and I believe most vehicles made in this millenium.
Also, all s-series uses a PCM if that matters..
Old 11-15-2009, 10:38 PM   #10
Low Saturn
Low Saturn's Avatar
2000 SC2
David
Yes, several of them. Even one relay pack under the passenger seat for the power locks if the car has them.
Mike,
The S-Series got BCM's in 2000.
Nothing. It all controls itself. Like every other auto manufacture in the world before cars started using body control modules.
Mike
-2000 Saturn SC2
Old 11-16-2009, 12:16 AM   #11
ddarnell
Looks like we'll start by determining what got wet. I can only imagine that a submerged fuse/relay block could cause quite a bit of havoc. Are there any online resourses such as schematics and exploded views?
Thanks again,
David
Old 11-16-2009, 12:21 AM   #12
ddarnell
Mike......I just read your signature line. That's a quick car you have there. I have a number of cars and I don't think any of them will run in the low 11s.
Good work............you must have it dialed in.
David
Old 11-16-2009, 12:22 AM   #13
ddarnell
I meant high 11s..............still fast!
Old 11-16-2009, 09:39 AM   #14
Your daughter is not alone - a couple of other recent water-flooded s-series threads:
http://www.saturnfans.com/forums/sho...=flooded+water
Old 11-16-2009, 10:39 AM   #15
If the car's not turning over, don't look at the electronics. The starter circuit is a simple electromechanical circuit - battery, ignition switch, neutral or clutch switch, starter, ground. Check all that first.
Add to madpogue's Reputation
Old 11-16-2009, 11:51 AM   #16
ddarnell
Thanks for the help. We'll start with the starter circuit.
David
Old 11-16-2009, 01:23 PM   #17
ddarnell
I got a photo of the water line. It went up to just above the relays at what appears to be the drivers side lower kick panel area. She describes the water line as the top of the pedals. Replacing blown fuses and submerged relays. Shes looking for the starter right now to determine if it took a bath.
Old 11-16-2009, 03:23 PM   #18
ddarnell
Put jumper cables on it and it started right up. I'll suggest she does a fluid change.
David
1996 SL1 5 speed in fresh water flood casterman S-Series Tech 14 07-12-2007 10:18 AM
another timing chain victim joangel L-Series General 49 08-15-2005 04:16 PM
SC2 claims a victim! SC2racerWS6 S-Series General 20 01-03-2004 05:45 PM
Victim of the Crash THX712517 General Saturn Discussion 9 11-11-2003 07:26 AM
Another victim of the coolant leak svbb L-Series General 15 05-25-2003 09:34 PM
