Old 11-15-2009, 01:14 PM   #1
tallNewfie
tallNewfie is on a distinguished road
2009 Astra XE
Default Removing steering wheel/horn
Hey! Does anyone know how to get the horn/airbag unit (centre of steering wheel) out? I am trying to get to the wiring behind it to install steering wheel radio controls. Thanks!
Bryan
Add to tallNewfie's Reputation
Rate the quality of this post and help tallNewfie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tallNewfie is offline   Reply With Quote
Old 12-30-2009, 01:59 PM   #2
tallNewfie
2009 Astra XE
Default Re: Removing steering wheel/horn
Figured I would update this post in case anyone else was wondering about it.
Because of some great advice/direction from my local astra expert (thanks L) I have sorted it out.
To remove the horn/airbag you need to:
1.Disconnect the battery for at least 20 minutes.
2.Tun the wheel around 90 degrees in one direction until a little hole can be seen on the side.
3.Insert something flat like a robinson or torx screwdriver to depress the cap inside.
4. Pull lightly on the depressed side to release it.
5.Repeat the rotation/depression with the hole on the other side of the horn.
6.Completely pull out the horn/airbag assembly.
NOTE: There is no screw in the hole, just a button to depress. Also, make sure that the battery has been disconnected for several minutes. You can also remove the fuse for the horn as well for good measure, but shouldn't need to since the battery is not connected
Hope this helps. And if I missed anything please don't hesitate to reply. :-)
Schematic for removing steering wheel qwikz28 Vue Tech 0 07-31-2009 11:13 AM
How do I disassemble my steering wheel? My horn is stuck BEEEEEEEEEEEEEP! copyman_5 Vue General 4 08-16-2008 07:54 PM
removing steering wheel on 3rd gen S-Series dmc S-Series Tech 7 12-03-2007 04:50 PM
Can the ignition switch be removed without removing the steering wheel (93 SL2)? 93goldsl2 S-Series Tech 4 10-19-2007 10:48 AM
Cruise and Horn do not work on Steering wheel..need help dschwer S-Series General 5 03-03-2006 11:07 AM
