Old 11-14-2009, 10:47 PM   #1
JGra
JGra is on a distinguished road
Default 2004 L300 Blower Motor Problem
Need some help. I have a 2004 L300. lately I have been having an issue with the blower motor. It started out at first with the blower motor just not coming on at all. Sometimes would come on after about 10-15 minutes of driving and sometimes it would work just fine. I then relized that if I slammed either of the front doors real hard the blower would start working. The problem got worse now in that when the blower is working it is blowing at a reduced rate on all speeds. The weird thing is when you make a left turn only, the blower blows at full speed on all speed settings. As soon as you return the steering back to center it starts blowing at the very reduced rate. I spent about 20 years as a Ford Tech but havent ever messed with a saturn. Seems like its got to be the switch or the resistor since the motor does blow full strength on left turns, but you never know. Where are these located on the model. Could use some advice before I get into it.
Add to JGra's Reputation
Rate the quality of this post and help JGra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JGra is offline   Reply With Quote
Old 11-14-2009, 11:34 PM   #2
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
Default Re: 2004 L300 Blower Motor Problem
Welcome to the Board.
Pull the radio and HVAC control head if you need to. Behind them there shoudl be a a connector to/from the blower. I have seen a few with overheatedmelted ground wire terminals.
Add to ssicarman's Reputation
Old 11-15-2009, 06:44 AM   #3
JGra
I have read alot of post and that connector seems to come up a lot. I will check that out today.
Old 11-24-2009, 08:26 AM   #4
KLS1P
KLS1P is on a distinguished road
2004 L-Series 3.0L Sedan
Your blower motor requires replacement. When you make a left turn, the force of the turn slides the blower shaft to one side in the motor. It just happens that little change in position lessens the friction from bad motor bearings and the motor speeds up. Once you straighten out the motor bogs down again. Directauto.com has the replacement for under a 100 bucks.
Add to KLS1P's Reputation
Rate the quality of this post and help KLS1P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KLS1P is offline   Reply With Quote
Old 12-29-2009, 06:42 AM   #5
JGra
Thanks. Where is the blower motor located on this model?
Right Hand Drive Blower Motor problem Churchland S-Series General 15 10-20-2009 05:10 PM
2004 saturn vue , ac/heat blower motor no power iamyourtech Vue Tech 3 09-08-2009 09:40 PM
Need help with blower motor archonxx S-Series Tech 2 01-23-2008 10:11 PM
help with blower motor hkusp S-Series General 3 06-11-2007 08:26 PM
HVAC Blower Motor Dying...can one fix motor? flyhop S-Series Tech 2 09-28-2006 09:08 PM
