Old 11-11-2009, 08:34 AM   #1
markcrocker
markcrocker is on a distinguished road
Default Snow tires
Hey there, I have an 05 saturn l300, and I need to get snow tires for it. It has p215/55r16. I was wondering can I go a different size to save money? This time of year is tight, and I am wondering if I can get a different size for cheaper tires.
Add to markcrocker's Reputation
Rate the quality of this post and help markcrocker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
markcrocker is offline   Reply With Quote
Old 11-11-2009, 09:42 AM   #2
Robman
Robman will become famous soon enoughRobman will become famous soon enough
Robman's Avatar
2001 L-Series 2.2L Sedan
Default Re: Snow tires
you can get narrower tires but that would make driving in the snow worse. keep the original size so you get the traction you need.
Rob
2001 Turbo L200
1997 F150 XLT
1985 Range Rover Classic
1999 Yamaha Blaster YFS200
Do It Yourself
Add to Robman's Reputation
Rate the quality of this post and help Robman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Robman is offline   Reply With Quote
Old 11-11-2009, 11:28 AM   #3
Starduster_Sat
Starduster_Sat is on a distinguished road
Starduster_Sat's Avatar
Within each tire model's range of available sizes, the price goes up from smaller to larger- difference in raw materials used.
You need to stay with the OE size to start. Anything LESS is a huge safety risk. If you need to economize, research and shop carefully. I am not the first to recommend tirerack.com, but they are a great research tool, even if you choose to buy elsewhere. It is possible to find what you need from an off-brand tire without compromising your safety.
Happy hunting!
Add to Starduster_Sat's Reputation
Rate the quality of this post and help Starduster_Sat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Starduster_Sat is offline   Reply With Quote
Old 11-12-2009, 05:38 PM   #4
01L300V6
01L300V6 is on a distinguished road
01L300V6's Avatar
2001 L-Series 3.0L Sedan
I'm sorry, but how does going narrower make it worse for driving in the snow and make it a huge safety risk? As far as safety goes, if you go much more narrow than the rim allows (stretch tires) then I can see the problem, but if you go just slightly narrower, I don't see the issue.
As far as making it worse in the snow, a narrower tire is going to perform better than a wider tire (that is if we ignore the tread compound and design entirely). Now obviously there's a point where that stops becoming true.
2001 Saturn L300
2002 Mercedes-Benz ML320 (sold)
2003 Dodge Grand Caravan SE
2003 Yamaha V-Star 650 Classic
2008 Toyota Camry Hybrid
Add to 01L300V6's Reputation
Rate the quality of this post and help 01L300V6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
01L300V6 is offline   Reply With Quote
Old 11-12-2009, 05:55 PM   #5
Robman
Robman's Avatar
surface area of the tire.
Rob
2001 Turbo L200
1997 F150 XLT
Do It Yourself
Old 11-12-2009, 06:19 PM   #6
01L300V6
01L300V6's Avatar
"A wide, low profile or large tire has to "plow" a wide path through snow which causes more resistance. The narrower the tire, the easier you can get through snow."
http://www.tirerack.com/winter/tech/...urrentpage=168
2001 Saturn L300
Old 11-12-2009, 09:00 PM   #7
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
What he said.
Whatever matters in the summer goes out the window in the winter.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 11-12-2009, 11:50 PM   #8
beensmoked
beensmoked will become famous soon enough
2002 L-Series 2.2L Sedan
where are you locatd? I went to school for 4 years in Vermont with good all seasonal tires and did perfectly fine. It's all on the treat design and materials used not the size. Just stick with OEM size if ur going with snow tires.
Add to beensmoked's Reputation
Rate the quality of this post and help beensmoked reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
beensmoked is offline   Reply With Quote
Old 11-14-2009, 10:53 AM   #9
rnelson
rnelson is on a distinguished road
2002 L-Series 3.0L Wagon
There are always options. If you want to use a 15" tire then 195/65-15 is OEM, if you want to go 16" then 205/60-16 is very close in size. It's better to have a narrower snow tire as the increased pressure on the tread will cut through the snow, a wider tread will tend to float on top. I have to deal with over 15' of snow over the winter so I take off my alloys and use 15" steel rims with 195/65-15 snow tires - all seasons just don't work.
Add to rnelson's Reputation
Rate the quality of this post and help rnelson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rnelson is offline   Reply With Quote
Old 11-14-2009, 05:00 PM   #10
markcrocker
thanks for the input guys.
I live in newfoundland, canada, so I definitely need snow tires, can't stay with the all seasons.
Snow tires! irish56 S-Series General 42 02-12-2010 12:29 AM
Snow Tires sparelink S-Series General 4 10-24-2008 10:08 PM
Snow tires... Mary's Vue Vue General 6 10-24-2007 02:24 PM
what snow tires should I get? mac-saturn Ion General 3 10-25-2005 08:49 PM
Snow tires are on!!!! xraddoc Vue General 1 11-14-2004 02:04 PM
