Old 11-09-2009, 11:41 AM   #1
jazzman31
jazzman31 is on a distinguished road
Default Saturn Shifting Problems
First off like to say thanks for the help from this forum. Been reading it for months now just never joined.
Ok now for the goodie
I have a 1999 Saturn SL2. Great little car, 32mpg. Reliable, until recently.
I had the transmission reverse slam problems and I read this board and did the fixes. Replaced the valve body, and tightened the input output shaft nuts.
Thought I had my problem fixed. Well recently its started acting up again and its very interminte. Start out driving cold, not a shifting problem, reverse or foward. Drive it for a while shifts fine. Then it will slam and start the reverse slam. Stop let it cool 5-10 min drive it again. Problem goes away. For the first few miles. Ok now drive it on interstate 50 miles or so, Get off and it drive through city, shifts great. Then out of no where will slam into second.
Checked the fluid, and the valve body connections all is tight. Any ideas?
Dont know if this makes a difference. When driving, and turning left at highway speeds, ie a interstate curve to the left. The car will have a rubbing noise from the passenger side tire. Sounds like an out of balance tire. But when driving on gravel bumpy road slowly 5-10 miles an hour same noise hard to hear but its there. Sounds like it may be the strut.
Suggestions ideas.
Could a bad trans/engine mount cause this? Could using an autoparts store filter cause this as well. Could the saturn filter have a flapper valve to help with pressures. (I know Honda did at one time)
Thanks for the help.
Jazzy
Add to jazzman31's Reputation
Rate the quality of this post and help jazzman31 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jazzman31 is offline   Reply With Quote
Old 11-10-2009, 03:44 PM   #2
DonP
Default Re: Saturn Shifting Problems
A bad top engine mount may cause increased engine noise on turns, especially left turns that put more weight on the top mount. There are diagnostic measurements you can take to check for a collapsing mount. Also visual, look for cracked rubber in the mount. Many threads on the subject. If yo ned a new mount, get OEM from Saturn. The third party moucnts tend to fail early (like maybe in 2 years.)
I see this was your first post, have you done the ECTS replacement yet. It causes many driveability issues. Check the first few sticky threads in the How-to Library forum.
Auto parts filter (transmission or oil) should be OK if it is one tht is spec for the car and replaced routinely as recommended.
Add to DonP's Reputation
Old 11-13-2009, 01:15 PM   #3
jazzman31
Yes Ive replaced the ones in the Transmission, and the engine. I can reset the computer several times and all will work for a couple of days then start hard shifting again. Very weird.
problems shifting into second trevino1 S-Series Tech 1 03-14-2009 06:56 PM
97 SC Shifting Problems Izzie387 S-Series Tech 9 08-21-2008 09:30 AM
Shifting Problems betinaq Mods and Performance 2 02-22-2005 01:29 PM
Shifting problems Greg1 S-Series Tech 2 02-23-2003 07:45 PM
Saturn L: Manual Problems Shifting from 3rd to 4th socketz L-Series Tech 4 11-22-2002 09:09 AM
