what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series General
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-07-2009, 08:16 PM   #1
gaeducator
gaeducator is on a distinguished road
Default Valve Body???
Where can I get a valve body for a 2002 Saturn S series? I need one with a warranty. I have already tried Special Forces on this board. Need it ASAP. Thanks for your help. Seen several on ebay.
Add to gaeducator's Reputation
Rate the quality of this post and help gaeducator reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gaeducator is offline   Reply With Quote
Old 11-07-2009, 08:31 PM   #2
Low Saturn
Low Saturn is just really niceLow Saturn is just really niceLow Saturn is just really niceLow Saturn is just really niceLow Saturn is just really nice
Low Saturn's Avatar
1991 SL2
Default Re: Valve Body???
If you want one with a warrenty, then call your local Saturn parts department before they go out of business. I think they run about $600 or more. But then you'll be getting a valvebody with the same parts as your failed one. And when it does fail, because it will, it'll be out of warrenty anyway.
Or you could go with Special Forces rebuilt units using better than OE parts and have it outlast the car.
Mike
1991 Turbo SL2
11.809 @ 116.488 mph
www.differentracing.com
Scrapped - Ver. 2.0 in the planning stages
My other vehicles:
www.cardomain.com/id/lowsaturn
Low Saturn is online now   Reply With Quote
Old 11-07-2009, 08:38 PM   #3
TvSteve
TvSteve is on a distinguished road
TvSteve's Avatar
1999 SW2
1997 SW2
Many of us here have used bodies from Special Forces with excellent results. He ships fast and backs up his work. ASAP would be from a Saturn dealer but be prepared to bend over. You could try your local pick and pull yard. Just find a car thats been in a crash, good chance it's good.
Add to TvSteve's Reputation
Rate the quality of this post and help TvSteve reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TvSteve is offline   Reply With Quote
Old 11-07-2009, 08:47 PM   #4
Low Saturn
Low Saturn's Avatar
1991 SL2
Most S-Series with bad valvebodies will still drive. Only reason I'd get one from a junkyard is if I was planning on rebuilding it before installing it.
Mike
1991 Turbo SL2
My other vehicles:
Old 11-08-2009, 09:40 AM   #5
gaeducator
Geeting one from Special Forces. Thanks and disregard above post.
Old 11-10-2009, 01:25 PM   #6
choctawcwp1
choctawcwp1 is on a distinguished road
Are included!!
All valves and springs are checked and or replaced
so to provide you with a value valve body!
"all reverse banging and problems with 2-3shift
are eliminated!! 3yr warranty
the sonnax upgrade is overkill and not necessary
so save money!!!!!!
Dyno-tested and guaranteed from the
supplier with a 3year warranty
an excellent cheap fix to get your s-series sl1/sl2
back on the road!!
For all questions call 813-325-3910
ask about overnite delivery
we ship world wide!!
Add to choctawcwp1's Reputation
Rate the quality of this post and help choctawcwp1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
choctawcwp1 is offline   Reply With Quote
Old 11-10-2009, 01:34 PM   #7
Low Saturn
Low Saturn's Avatar
1991 SL2
Huh????
Mike
1991 Turbo SL2
My other vehicles:
Valve Body Manual Valve Interchange Question acman S-Series Tech 2 11-05-2009 09:40 PM
I think my valve body is on its way out woonyboi02895 S-Series General 4 03-03-2009 05:36 PM
Help With a Valve Body darkwing S-Series Tech 4 09-30-2008 11:45 PM
valve body dreamliner77 S-Series General 8 02-03-2007 02:02 AM
Valve Body Henry S-Series General 11 09-10-2003 08:33 AM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
