what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-07-2009, 07:11 PM   #1
molotovman
molotovman is on a distinguished road
Default Help a Newbie out :-/
will an engine from a 2002 SL2 (DOHC) work on a 99 SL2 saturn? (with a bad DOHC)
Add to molotovman's Reputation
Rate the quality of this post and help molotovman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
molotovman is offline   Reply With Quote
Old 11-07-2009, 07:14 PM   #2
Low Saturn
Low Saturn is just really niceLow Saturn is just really niceLow Saturn is just really niceLow Saturn is just really niceLow Saturn is just really nice
Low Saturn's Avatar
1991 SL2
Default Re: Help a Newbie out :-/
Yes. Swap over your current intake manifold with the throttlebody, vacuum lines, fuel rail and injectors still attached.
Also swap your current engines sensors over if they are in known good working order.
Mike
1991 Turbo SL2
11.809 @ 116.488 mph
www.differentracing.com
Scrapped - Ver. 2.0 in the planning stages
My other vehicles:
www.cardomain.com/id/lowsaturn
Old 11-07-2009, 07:39 PM   #3
molotovman
^^^ Awesome thanks, one more thing is the engine in an LS2 the same as the SL2?
Old 11-07-2009, 07:53 PM   #4
Low Saturn
Low Saturn's Avatar
1991 SL2
No. Totally different engine.
Mike
1991 Turbo SL2
My other vehicles:
Old 11-08-2009, 01:09 AM   #5
molotovman
cool, last question i swear lol.
Can you swap out a SOHC engine for a DOHC engine? same tranny? i am assuming you will need a DOHC ECU. same block different head?
-thanks
Old 11-08-2009, 01:15 AM   #6
Low Saturn
Low Saturn's Avatar
1991 SL2
Yep. Done it a few times. But according to your first post, both are DOHC's right?
same tranny?
Nope. DOHC's use a different transmisson.
-thanks
Similar block (different pistons) and different head. You will need a new PCM.
Mike
1991 Turbo SL2
My other vehicles:
Old 11-08-2009, 01:43 AM   #7
molotovman
I was going to get a 99 and swap the engine from my 02, but the guy had sold it already, I found a 2002 with damaged driver doors with a SOHC, but since i have a DOHC parts car, now want to convert that into a dual cam motor lol
Old 11-08-2009, 03:54 AM   #8
2ndSCowner
2ndSCowner is on a distinguished road
That car looks fixable.
Add to 2ndSCowner's Reputation
Rate the quality of this post and help 2ndSCowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2ndSCowner is offline   Reply With Quote
Old 11-08-2009, 07:45 AM   #9
westwind999
westwind999 is on a distinguished road
1999 SW1
What's wrong with your SL2?
If you have everything from your car you can make it work in the SL1. The car looks pretty fixable, the rear bumper cover is cracked but looks like you could just put a bunch of new clips in to get it attached again. Doors are cheap and easy to change.
Old 11-08-2009, 04:39 PM   #10
molotovman
yeah i have a 02 SL2 parts car, I have all those parts lol
Im also parting it out if you need anything check out the link bellow
http://www.saturnfans.com/classified...p/product/3244
Newbie with newbie questions... jkon81 S-Series Tech 2 08-11-2009 11:40 PM
Newbie SC2Twister S-Series General 6 11-25-2007 09:08 PM
Hi, I'm a Newbie Luv4Saturn Introductions & Greetings 2 04-11-2005 04:49 PM
Yet another newbie DWH Introductions & Greetings 2 03-31-2005 07:02 PM
Newbie here SC2Sweet General Saturn Discussion 12 03-22-2005 07:08 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
