#1 | ||||
![]() Join Date: Nov 2000
1998 SL1
Hi everyone!
I've got a 98 SL1 auto with a oil -> coolant leak somewhere that I've given up trying to find (replaced the head already, did the headgasket TWICE). I've found a 95 SL1 5spd with a low kilometer engine. What would be involved in transplanting this engine? The 95 is OBD1, does that matter? 98 has returnless fuel lines, do I need to change the fuel rail? I want to keep the automatic in the 98, do I need to change just the flywheel? So many questions... Help me oh saturn geniuses! ... ---- 98 Saturn SL1 - 160k - mixer - coolant + oil 99 Nissan Altima - 290k - rusty - lots'a'spots 02 Pontiac Aztek AWD - 165k - lazy - always broken 01 Mazda Tribute AWD - 140k - To replace Aztek
#2 | ||||
![]() Join Date: Sep 2008
1993 SL1
You will need to swap intake manifolds, use the 95 manifold, and everything attached to it. Make sure you take the flex plate of your old engine and switch it with the flywheel on the new engine. DO NOT use the flywheel bolts in the flex plate! Other then that it is pretty much a drop in.
#3 | ||||
No need to swap intake manifolds. They're the same from 1995-1999. You will need to swap over your current throttlebody (vacuum port orientation is different), vacuum line assembley (95 has two lines, 98 has one) and fuel rail/injectors (98 is returnless, 95 is not and 98 uses different injectors than 95). Then swap over your current sensors if they're in know working order.
... Mike 1991 Turbo SL2 11.809 @ 116.488 mph www.differentracing.com Scrapped - Ver. 2.0 in the planning stages My other vehicles: www.cardomain.com/id/lowsaturn
| Thread Tools | |
| Display Modes | |
| Engine swap on a 97 SC | AlchemistTC | S-Series Mods | 4 | 10-02-2009 08:18 AM |
| Easier to Swap engine, or swap tranny? | Saturn #4 | S-Series General | 3 | 05-02-2009 08:41 PM |
| Engine swap 93 SL1 Engine in 97 SL2? | bilbo_dies | S-Series Tech | 1 | 03-27-2008 07:47 PM |
| Engine swap - 99 SC2 to 2000DOHC engine - Question | Anjey | S-Series Tech | 10 | 07-06-2005 11:11 AM |
| Engine Swap or trannie swap | SL-2er | Miscellaneous Tech | 1 | 04-28-2003 05:00 PM |
