what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-07-2009, 11:54 AM   #1
chickenhawk2
chickenhawk2 is on a distinguished road
chickenhawk2's Avatar
2000 SL2
2005 VUE 2.4L
Default 05 Vue unknown dash light
I have an 05 vue that has a dash light on. I didn't receive an owners manual becuase I bought it used. The light is on the left hand side of the dash and its the middle light. It looks like an engine but I am not sure. I have hooked up two different code readers and they both show no codes. The light go off once I reset it, but then it comes on. Can someone tell me which light it is and what might be the problem? Thank you! It's been on for a while, but I haven't noticed any performance problems.
Those things that we do...
2000 SL2 (Ice) 130k miles
2005 VUE (Ice-Block) 75k miles
Still Rollin'
Add to chickenhawk2's Reputation
Rate the quality of this post and help chickenhawk2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chickenhawk2 is offline   Reply With Quote
Old 11-07-2009, 01:47 PM   #2
XRL
XRL is on a distinguished road
XRL's Avatar
2004 VUE Red Line
Default Re: 05 Vue unknown dash light
Could be the coolant sensor.
'04 Vue Redline AWD - Silver Nickel Metallic
Mods: Tinted tails & corners - Stealth Amp and Sub system - In-Dash Navigation - Nitto INVO 245/50/18s - Custom HID Projectors
Add to XRL's Reputation
XRL is online now   Reply With Quote
Old 11-07-2009, 03:11 PM   #3
fdryer is a name known to allfdryer is a name known to allfdryer is a name known to allfdryer is a name known to allfdryer is a name known to allfdryer is a name known to all
Can you post a picture?
The CPS is the heart of the entire EFI system. No cps = dead EFI system.
There's more to a/c than just a few cans of refrigerant.............
Old 11-07-2009, 10:30 PM   #4
far2grumpy
far2grumpy will become famous soon enough
far2grumpy's Avatar
I've attached illustration for 05 Vue instrument panel ... which light is on?
far2grumpy is online now   Reply With Quote
Old 11-08-2009, 11:43 AM   #5
chickenhawk2
2000 SL2
2005 VUE 2.4L
Thanks grumpy. Well my Bad everyone. it is the lower left hand light.
Still Rollin'
Old 11-08-2009, 03:49 PM   #6
chickenhawk2
2000 SL2
2005 VUE 2.4L
can any of you all still help me I am still unsure what it is?
Still Rollin'
Old 11-08-2009, 04:12 PM   #7
That icon is the service engine soon (SES) indicator; once its lit you should be able to plug in a reader to retrieve any error code(s). Our How-to library on page 5 titled OBD II Powertrain Codes lists almost every code definition. If you cannot read the codes with your reader try Autozone for free. Don't erase the code until they're read. Write down the code for posting.
Old 11-08-2009, 04:14 PM   #8
chickenhawk2
2000 SL2
2005 VUE 2.4L
I have tried that numerous times and it states no codes and passed. I have tried to retrieve any old codes and it still shows none. Do I need to go to the dealer to have them reset it or is there some way I could.
Still Rollin'
Old 11-08-2009, 05:15 PM   #9
The SES codes can be read only when the indicator is on but if the power to the OBD II connector is blown there won't be any communications between the DLC and reader. Pin 16 is 12v power from the AUX 1 OUTLET 10A/15A fuse, pins 4 or 5 are ground.
Resetting codes can be done; pulling the battery negative cable for 5-minutes, B+/ECM/TCM 10A fuse or push button reset on most readers.
Hopefully the error is nothing more than the gas cap leak.
HELP! Dash Light?? Spl170s Vue Tech 4 09-30-2008 09:00 PM
dash light jsam Vue Tech 0 02-08-2008 11:12 PM
03 VUE Dash lights won't light Wingmn Vue Tech 8 12-04-2007 10:19 AM
unknown box under dash catmooser S-Series General 1 06-06-2005 02:04 AM
Unknown warning light cka3n L-Series Tech 5 12-01-2004 04:59 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
