what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series General
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-07-2009, 11:14 AM   #1
houstontexanfan
houstontexanfan is on a distinguished road
Default Jiffy lube/Meineke
Has anyone in here used either Jiffy lube, or Meineke to have your oil change and if so was it good, or bad service.
Add to houstontexanfan's Reputation
Rate the quality of this post and help houstontexanfan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
houstontexanfan is offline   Reply With Quote
Old 11-07-2009, 11:29 AM   #2
fetchitfido is on a distinguished road
1993 SL2
1997 SC1
Default Re: Jiffy lube/Meineke
I'm fairly sure the '95 SL2 I just picked up for $300 went for $300 because a Walmart service center guy decided that no oil on the dipstick meant he didn't have to drain out whatever's left, and just put in another 4 quarts (going by the receipt). It smoked like a bandit, apparently got the PO pulled over, and I just drained out ~2 quarts yesterday to get the oil level _down_ to the full mark.
Jiffy Lube and Meineke are roughly the same quality of service, overall.
1993 SL2m 161k
MP7 transmission swapped to MP3
8lb Fidenza flywheel and A/C+P/S delete
H&R Sport Springs
AEM CAI & '92 Header
Old 11-07-2009, 11:44 AM   #3
PurdueGuy
PurdueGuy will become famous soon enough
PurdueGuy's Avatar
1999 SC1
Any oil change place's service is going to depend almost entirely on the local management and employees. I would mostly recommend doing the work yourself so you can be sure it's done right. If you insist or for some reason have to have it done someplace, I would recommend talking to people who have experience with your specific local shops, not the chain. You can get a terrific shop in one town, an incompetent shop in another, and a dishonest shop in yet another. Those types of places are usually dependent on cheap labor, which means how good their employees are will depend on the local talent pool, as well as management's competence, not the name on the sign.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 11-07-2009, 11:50 AM   #4
geartooth94
geartooth94's Avatar
1991 SL2
i've had average luck with the Meineke in my town. i use them mostly for exhaust work and general repair. their exhaust prices are a little high, but the manager will always take me out to look at the car and what's wrong with it before i authorize any repair.
i've also learned to arrive at a certain date / time to get the inspection done. some other techs will fail me for stuff the other tech will not.
'91 SL2 silver-gray two-tone resto-mod converted to manual trans. 73K miles
'95 SC2 gas mileage: 25mpg
----------oil mileage: 1,025 mpg
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 11-07-2009, 11:53 AM   #5
Zero_DgZ
Zero_DgZ is on a distinguished road
In other words, arse.
It's a sad state of affairs, but it's looking like it's shaping up that you can't trust any chain automotive place anymore. You may get okay service, but I'm not sure it's worth the risk that you won't. Changing the oil yourself isn't expensive at all (and you can opt to use good oil rather than the bulk junk the shop will use) and quite easy on the S-Series once you get used to it.
If you don't have the time or inclination to do it yourself, it seems the best course of option is to go to a trusted local (independent) mechanic or take it to a GM dealership.
At least your local garage mechanic has his reputation and business on the line, and is likely to do a good job to earn your repeat business or at least not get sued or lose the rest of his customers. Your friendly neighborhood chain store (Wal Mart, Sears, Jiffy Lube, Midas, etc.) may just as soon put some minimum-wage pimpleface with a GED under your car and it's likely that the shop's single certified mechanic will never lay hands on -- or even look at -- your car before it goes out the door.
'02 SL2 Automatic. Custom WAI, Big Stereo, Shiny Hubcaps, and Approximately One Billion Miles.
Add to Zero_DgZ's Reputation
Rate the quality of this post and help Zero_DgZ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zero_DgZ is offline   Reply With Quote
Old 11-07-2009, 03:47 PM   #6
SATURNSLRICH
SATURNSLRICH is on a distinguished road
2002 SL
2001 SL2
OIL CHANGE shops are there for one reason and its not to change your oil,its to upsell everything they can on your car wich in most cases the car does not need
Add to SATURNSLRICH's Reputation
Rate the quality of this post and help SATURNSLRICH reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SATURNSLRICH is offline   Reply With Quote
Old 11-07-2009, 04:25 PM   #7
SLCraig
1997 SL1
Wouldn't know, never used one!
I've been changing my own oil on my cars since I had a drivers license... It's easy, is good piece of mind, and no hassle of dealing with useless people.
"The Silver Bullet"
Silver 1996 SL2 5MT. 210KMs.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLCraig is online now   Reply With Quote
Old 11-07-2009, 04:26 PM   #8
eRic 02sc2
eRic 02sc2 will become famous soon enougheRic 02sc2 will become famous soon enough
eRic 02sc2's Avatar
Location: Professional Driver on a Closed Course: Do Not Attempt.
Thumbs Down Re: Jiffy lube/Meineke
No and I never will. I have heard too many horror stories about quick lube places not refilling the oil or leaving the filter or drain plug loose. That and recommending some sort of "engine flush".
eRic 02sc2 fka eRic 96sc2
Detroit SCCA Solo 2001,2002 1st Place DSP
Waterford Hills 2007 Fun Run 1st Place
Detroit SCCA 2008 Triathalon 1st Place PF
Crutchfield Referral: pkeqe-6j8e3-d2qqe
Old 11-07-2009, 06:03 PM   #9
houstontexanfan
I pick up a 5qt of Mobil one and a Fram filter, because some of the stories I read online scare the you know what out of me, so is the oil filter easy to get to, the last time I change oil was when I was in Autoshop in HS, so many moons ago.
Old 11-08-2009, 01:08 AM   #10
Signmaster
Signmaster will become famous soon enoughSignmaster will become famous soon enough
The easiest way is to remove the inner wheel cover. You can do it with the wheel on, but personally I usually jack it up and remove the wheel. That way it's easy to clean up any oil that drips on the CV boots or anything else.
It's fairly quick regardless of which way you do it. I don't have much faith at all in the quicky change places.
Old 11-08-2009, 01:24 AM   #11
Low Saturn
Low Saturn is just really niceLow Saturn is just really niceLow Saturn is just really niceLow Saturn is just really niceLow Saturn is just really nice
Low Saturn's Avatar
1991 SL2
Originally Posted by eRic 02sc2 View Post
....or leaving the filter or drain plug loose.
Thats assuming they even remove the drain plug. A lot of places shove a plastic tube down the dip stick tube and suck out the oil. Then when the plastic tube breaks inside, they dont tell anyone and send you on your way.
The only way you can trust any of these places is to watch them to all the work yourself. never let the car leave your sight. Then you can watch them screw things up instead of finding out about it later.
That said. I always change my own oil. In fact I need to do my 94 SL2, 96 SC2 and Suburban tomorrow.
Mike
1991 Turbo SL2
11.809 @ 116.488 mph
www.differentracing.com
Scrapped - Ver. 2.0 in the planning stages
My other vehicles:
www.cardomain.com/id/lowsaturn
Old 11-08-2009, 01:03 PM   #12
2NDSOUT
2NDSOUT will become famous soon enough
2NDSOUT's Avatar
1997 SW2
Yeah, I don't use them either....especially some of the nutjobs that work there....joe schmoe's off the street with no working knowledge of cars at all. No offense to those that work at these places, but alot of them are just there for the check and nothing more.
There is an undercover video report that was done by a TV station (NBC Channel 4) out in California last year, you can find the videos on Google. The reporter and his team marked the oil filter with a #4 and it was still on AFTER the oil change done at Jiffy Lube, and then trying to contact the district managers, and corporate showed that they were just in it for the money.
Bryan
94 SL2 137K Miles
97 SW2 181K Miles
Garaged
94 SL2 HCE, "Pearl"
Rebuild
94 SC1 340,501 Miles
Original Engine/Auto Transmission
02/97-10/08
Then
92 SL1
05 VUE
91 SC
Add to 2NDSOUT's Reputation
Old 11-08-2009, 01:08 PM   #13
quantumech
quantumech is on a distinguished road
Search the web for jiffy lube, and you'll find all sorts of horrifying stories about how the engine drained itsself of oil when they left, or how the crankcase was dry, or how the change was never actually done. Personally, given the amount of oil streaks I've seen on the ground leading away from the stations, I'll never go there. I even tried to stop someone from leaving because they were leaving a streak on the ground one day. I hope they figured it out why I was yelling at them before they got on the freeway.
Sasha: 2000 SL1, Manual, 68,500 miles 8-18-2009
I learn from my experiences, if I screw up, I'm sorry.
Add to quantumech's Reputation
Rate the quality of this post and help quantumech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quantumech is offline   Reply With Quote
Old 11-08-2009, 01:12 PM   #14
Low Saturn
Low Saturn's Avatar
1991 SL2
They did a sting on a bunch of Midas shops out here too.
Mike
1991 Turbo SL2
My other vehicles:
Old 11-08-2009, 02:50 PM   #15
adventureoflink
adventureoflink is on a distinguished road
adventureoflink's Avatar
This one time, at speedway, I was given a coupon for a discounted oil change at Valvoline since I used my speedy rewards card that night.
needless to say I wadded the damn thing up and threw it away. after reading about Iffy Lube/Quick change/Valvoline/etc, I'm not putting my car through that. I might as well go up to some random guy and have him change my oil.
*******s
'97 Saturn SL2.
DOB: 3/17/97
Date Obtained: 5/30/07
Status: Alive and Well
'95 GMC Vandura 3500.
DOB: 6/95
Date obtained: 7/10/09
Engine: 6.5L Diesel
Status: Dead
Old 11-08-2009, 03:17 PM   #16
2ndSCowner
2ndSCowner is on a distinguished road
I have changed the oil in my car several times myself. The first time I did it I was nervous that I may screw something up but turned out to be quiet easy. I also like to put it on a jack and remove the wheel but that's my personal preference. If I don't have the time to do it myself I take it to one shop in town that I trust.
I went to Jiffy Lube one time and it was a mistake. Took my van in for an oil change, and the dip ***** didn't tighten the drain plug up. Got 2 blocks from there and the low oil light came on, pulled over shut it off and you could see the trail of oil on the ground.
Add to 2ndSCowner's Reputation
Rate the quality of this post and help 2ndSCowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2ndSCowner is offline   Reply With Quote
Old 11-08-2009, 10:22 PM   #17
wrenchtnr
wrenchtnr is on a distinguished road
On the other hand, I had the oil drain plug come out of a VW bug that I had done the last oil change myself. Of course this was at night, in the South Bronx, back in the bad old days, when I had less experience than I have now but enough that I should not have let that happen. Actually it turned out better than I ever expected, bless those German engineers!
But I have used "quickee lube" places since, but it never hurts to stop a block away, and pull the dipstick and tighten the plug yourself. It actually must be mind numbing the change oil all day long and it would be easy to miss a step.
PS You should also check your lug nuts after anyone else tightens them. Too loose is dangerous but usually they are too tight and if they don't warp the rotors then you can't budge them when you get a flat. Also at night in a bad location!
Add to wrenchtnr's Reputation
Rate the quality of this post and help wrenchtnr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wrenchtnr is offline   Reply With Quote
Old 11-09-2009, 10:36 AM   #18
Citation84
Citation84 will become famous soon enough
Citation84's Avatar
2005 ION-1 Sedan
2ndsout: I have used the one exposed in that report there on Ventura for years. Never had a problem, but not surprised. I think every franchise is subject to it's owner's ethics.
However my niece's car in Salt Lake City had the engine destroyed from Jiffy Lube's neglecting to put oil back in after draining it out.
This is an old story: AAMCO in the 70s,Purrfect Auto, Jiffy Lube, Firestone and Sears have all been busted for the same crap over the years.
It's rare to find someone in any business who isn't there just to put the time in for a pay check.
Add to Citation84's Reputation
Rate the quality of this post and help Citation84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Citation84 is offline   Reply With Quote
Jiffy Lube lives up to name mikthehickNC S-Series General 33 11-11-2004 10:42 PM
Oil Changes at Jiffy Lube spot101 Ion General 39 04-14-2004 10:06 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
