what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-07-2009, 09:06 AM   #1
jimpennjr
jimpennjr will become famous soon enough
1996 SL1
1997 SL1
Default 96 SL1 flex pipe rusted out-HELP Please!
I'm in CT and I need a place that won't rob me blind to cut out the old flex and weld in a new section. I have called 2 places and both want over $200 bucks to cut out and weld in. I have trouble with that when a section of flex is $20, a header to flex before cat is $55, and header including cat is $180. Anyone close who knows a shop or can do this themselves. Thanks in advance, Jim
PS- If this a normal price to cut and weld tell me so.
jimpennjr
'96 SL1 5-speed
Bomz Air Intake
Sony X-plod Head
KenwoodAmp
10" Alpine Bass Sub
Add to jimpennjr's Reputation
Rate the quality of this post and help jimpennjr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimpennjr is offline   Reply With Quote
Old 11-07-2009, 12:40 PM   #2
jamie930
jamie930 is on a distinguished road
Default Re: 96 SL1 flex pipe rusted out-HELP Please!
OEM pipes are bolted together.
Manifold bolts to flex pipe, flex pipe bolts to cat, cat bolts to exhaust pipe. Then the muffler to exhaust pipe has a slip over joint with a clamp.
No welding required
Add to jamie930's Reputation
Rate the quality of this post and help jamie930 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jamie930 is offline   Reply With Quote
Old 11-07-2009, 01:54 PM   #3
.kevin.
.kevin. is on a distinguished road
.kevin.'s Avatar
1997 SL1
I paid I think 70 for labor and the pipe at this muffler shop. I do think their prices are lower than average though. They did my muffler for 55 and it was more for a muffler at advanced auto parts with the hanger.
Add to .kevin.'s Reputation
Rate the quality of this post and help .kevin. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
.kevin. is offline   Reply With Quote
Old 11-07-2009, 09:45 PM   #4
off-track
off-track is on a distinguished road
off-track's Avatar
No welding required
Umm, no, I don't think so? The flex connection to the cat is welded.
Hmm, kind of disturbing though.. I just just hit RA and Santurnparts and those items are no longer listed! It used to be around $160 IIRC? AZ is off-line and OR wants $202 for the assembly. (EDIT: nm, just found it on RA for $166 under the SL2, just not under SOHC. Are they different exhausts?)
FWIW, I went to Meineke here when My son's exhaust cracked at the flex and they welded in a new one for ~$150 (plus the missing hangers that cause it to crack in the first place).
1997 - SL2, barebones, 130k, Auto
Purchased 114k 10/07, replaced Head unit, R/F LCA, ECTS, Thermostat, Starter, Alternator, Custom Frankenbumper, new TAM, tensioner and idler.
Added OEM CC
Add to off-track's Reputation
Exhaust leak at flex-pipe:93 SL1 johnholl S-Series Tech 1 09-29-2007 11:24 AM
What size exhaust pipe for the flex pipe? turbobuick33 S-Series Tech 4 03-10-2007 03:46 PM
Down Pipe/Header Pipe/Flex Pipe/Front Pipe Carriere S-Series General 6 05-12-2006 08:44 PM
Replacing Front Flex Exhaust Pipe on SL1 Help Pls. ?!?!? tgparker S-Series General 3 01-18-2006 12:20 PM
Flex pipe... Rob1998SL2 Mods and Performance 10 10-08-2003 05:33 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
