what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-07-2009, 06:37 AM   #1
Joefromcocomo
Joefromcocomo is on a distinguished road
Default 1995 SL2 Transmission problem
Hello,
1995 SL2 DOHC.
Automatic Trans won't shift into its last gear (5th) until car is warmed up for about ten minutes, thereafter shifts fine. Just changed trans fluid and filter - fluid was clean - this did not help.
Thanks
Add to Joefromcocomo's Reputation
Rate the quality of this post and help Joefromcocomo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Joefromcocomo is offline   Reply With Quote
Old 11-07-2009, 07:41 AM   #2
stevestar99
stevestar99 will become famous soon enoughstevestar99 will become famous soon enough
Default Re: 1995 SL2 Transmission problem
Besides being an "auto" it's an electric transmission. Start by checking the under hood fuses. Make sure the blades of the fuse are nice and shiny. The sockets are good and tight, making a solid connection. Check: TRS LP, TRS2/TCC, and TRS3/4. Check the valve body harness connector for corrosion.
Add to stevestar99's Reputation
Rate the quality of this post and help stevestar99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stevestar99 is offline   Reply With Quote
Old 11-08-2009, 10:02 AM   #3
Joefromcocomo
Thanks for the info. Installed new fuses -- old ones were slightly discolored but no real corrosion. The problem remains. The valve body harness connector (on top?) was clean inside, but the bolt holding it in was a bit loose. I'll have to wait for the car to sit a while now to see if snugging it down helped.
Searching the forums, I found a situation nearly identical to mine, except I have NO trouble codes:
"I have a 98 SL2 with ~112k miles on it. During the winter, I noticed it would not shift into overdrive unless it had warmed up (~5 miles on the hwy.) The problem was less noticeable when spring came around but even when it was warmer in the mornings, my car still wouldn't go into overdrive until I had driven at least 2 miles on the highway. Today, the service engine light came on and now it won't go into overdrive at all. Has anyone else had this problem? What kind of repair cost am I looking at?"
Can't post URL. Thread titled: "98 SL2 Overdrive Problem"
My 95 SL2 has 217,000 k on it. It ran hot once over three years ago, and since then, shifts hard from first to second but only when running temp is higher from prolonged sitting in traffic (during the summer). Otherwise, shifts smoothly.
Thanks for any help. Maybe I can solve this before it goes to the shop!
Old 11-08-2009, 09:07 PM   #4
wolfman
wolfman is a glorious beacon of lightwolfman is a glorious beacon of lightwolfman is a glorious beacon of lightwolfman is a glorious beacon of lightwolfman is a glorious beacon of light
wolfman's Avatar
1.Locking out overdrive until the transaxle reached normal operating temperature is NORMAL..'
Notice I said transaxle....
The Transaxle Fluid Temperature Sensor is located is close proximity to the filter...as a result it is somewhat easy to damage the sensor or its wiring when changing the filter if you are not careful...
Damaged sensors tend to read COLD. (Which would result in lockout) The sensor is exactly the same part as the ECTS..
Add to wolfman's Reputation
Old 11-09-2009, 07:18 AM   #5
marijuandroid
marijuandroid is on a distinguished road
marijuandroid's Avatar
i have lost overdrive as well, ive checked all fuses, checked connection, replaced 4th gear solenoid. still no 4th. mine will try to hit 4th but its just like popping into nutral it then senses thats 4ths ****ed up and goes into saftey mode not trying 4th anymore. its a beater so ive been rockin it as is. if you find a cure i would love to hear it.
mine throws a code though, i forgot the numbers but it inocorrect gear 4 ratio.
Add to marijuandroid's Reputation
Rate the quality of this post and help marijuandroid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marijuandroid is offline   Reply With Quote
Old 11-12-2009, 10:29 AM   #6
Joefromcocomo
Thanks for the info. Is it possible the Transaxle Fluid Temperature Sensor would be malfunctioning without throwing out a "check engine" code? It seems that if this is so, replacing it would be a good next step since the part is not too expensive. I'm also wondering what other problems could cause overdrive to not engage until the car is warmed up. Thanks again for any info.
1995 SL2 Manual Transmission Adjustment? nomeite S-Series Tech 4 07-22-2009 10:18 PM
1995 SL2 Automatic Transmission leaking? KingRex S-Series Tech 6 02-17-2009 03:57 PM
1995 SW1 manual transmission shift linkage problem mark rose S-Series Tech 6 11-19-2008 02:47 PM
1995 Transmission problem fpoint S-Series Tech 0 08-25-2007 12:57 PM
1995 sl2 transmission probs knothead S-Series Tech 3 06-14-2006 03:32 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
