what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-07-2009, 01:19 AM   #1
Saturn1998SL1
Saturn1998SL1 is on a distinguished road
1998 SL1
Default Top Motor Mount Stud Nuts Stuck
I replaced my motor mount without any problems ( I hope ).
I followed the instructions in this video ( very helpful ):
youtube.com/watch?v=zaugUfILmGE[/url]
The only difference between the video was that when I unscrewed the stud nuts they stuck. Instead all three studs unscrewed from the engine ( in the video the nuts unscrewed and the studs stayed put ). I was able to screw the studs back on without any troubles. The stud nuts are rusty but they appear to have plenty of strength in them.
Should I be concerned about this at all?
By the way, the car is very quiet now. No more vibrations. What a world of difference this makes.
Add to Saturn1998SL1's Reputation
Rate the quality of this post and help Saturn1998SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn1998SL1 is offline   Reply With Quote
Old 11-07-2009, 09:13 PM   #2
off-track
off-track is on a distinguished road
off-track's Avatar
Default Re: Top Motor Mount Stud Nuts Stuck
Yeah, mine did the same thing when I replaced the mount. If you look at the top end of the studs there are flats so that you put a wrench on and back off the nuts if they come loose. I don't exactly recall the size though.. maybe 7mm?
The FSM spec's that you clean all the rust off the studs and install the studs with locktite #242 and torque the studs to 18 lb. ft. (not much) and then install the TAM and torque the mount nuts to 37 lb. ft. I don't think I used the torque wrench on either as they are both not much more than firmly secured? Just as long as the studs were snug (or close to fully seated) in the front cover I wouldn't sweat it.
1997 - SL2, barebones, 130k, Auto
Purchased 114k 10/07, replaced Head unit, R/F LCA, ECTS, Thermostat, Starter, Alternator, Custom Frankenbumper, new TAM, tensioner and idler.
Added OEM CC
Add to off-track's Reputation
Old 11-07-2009, 10:00 PM   #3
OldNuc is just really niceOldNuc is just really niceOldNuc is just really niceOldNuc is just really niceOldNuc is just really nice
The studs may be torqued into the cover at 10 to 18ft-lb its not critical as long as they are actually at the bottom of the hole. Take the weight off the mount and torque the mounting stud nuts evenly to 37ft-lb. That means go to 15ft-lb then 28ft-lb then 37ft-lb in an alternate stud sequence. Clean the bottom of the mount and the top of the timing cover before installing the mount. If you do not clean and torque properly then you run the risk of either a cracked timing cover or snapped studs.
Follow the richpin video mount replacement video instructions for equalizing the dogbone preload.
Old 11-08-2009, 09:05 PM   #4
Saturn1998SL1
1998 SL1
The job is done right now.
Studs were removed from engine. Nuts were removed from studs with 6 mm socket on stud-end leveraged against 15 mm wrench on the nut. I cleaned the studs and the nuts with WD 40 first. Then I cleaned them again with break cleaner...recommended by auto parts store because it leaves no residue??
Next I cleaned the top of the mount and bottom of the timing cover with break cleaner.
Finally I put everything back together. 10 Foot lbs for studs into cover...locktite 242 used. Evenly torqued 37 ft lbs for mounting nuts.
1998 SL1 130 K Miles
Purchased New
Old 11-08-2009, 09:31 PM   #5
lets blaze
lets blaze is on a distinguished road
good to hear.
Add to lets blaze's Reputation
Rate the quality of this post and help lets blaze reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lets blaze is offline   Reply With Quote
Top motor mount Justice of MN S-Series General 6 09-15-2009 05:00 AM
Top Motor Mount Bob_m S-Series Tech 3 10-14-2008 06:27 AM
Tips on breaking upper motor mount nuts? mgordon1100 S-Series Tech 11 03-01-2008 08:08 AM
Top Motor Mount?? n_c_mail S-Series Mods 30 03-04-2007 02:41 PM
Saturn Upper Motor Mount (TAM) with bolts and nuts David 93 SL2m Internet Finds 0 04-03-2006 05:32 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
