what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-07-2009, 12:14 AM   #1
Scott Peterson
Scott Peterson is on a distinguished road
Scott Peterson's Avatar
Default Tranny questions and something cool
Well my father n law has been thru a couple 5 speeds in his 95 sl2.so its time for number 3 now LOL, so any ways we start checking around and a junkyard found us a 5 speed from a 93 sl2 with only 8 K original miles i guess some guy stored a 93 sl2 in his garage with only 8,ooo original miles and parted it out.So any how im not familiar with saturn 5 speeds.I had a 89 ranger with a 5 speed and you would have to get under the truck and unscrew a cap to check fluid level and it took ATF not gear lube.so is their a way to check the fluid level in these 5 speeds ?? i think their is a dip stick ??? what kinda fluid goes in it ?? whats the proper time to check it ?? hot or cold ? running or not ?? thanks !
1997 sl2, auto
I love the greaters too...you can't even tell who the *** he is greating. Both of his eyes are looking different directions. You only go to walmart for comic relief.
Add to Scott Peterson's Reputation
Rate the quality of this post and help Scott Peterson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Scott Peterson is offline   Reply With Quote
Old 11-07-2009, 12:26 AM   #2
Col.FUBAR
Col.FUBAR is on a distinguished road
Col.FUBAR's Avatar
1994 SC2
Default Re: Tranny questions and something cool
There is a red "L" handle locking dipstick on the top of the transmission underneath the brake master cylinder, it is probably covered in road grime and no longer red so it's probably hard to see.
Check when the trans is cold (Saturn says check when you are able to put your hand on top of the tranny without having to remove your hand from the heat )
Takes 2.6 Quarts of DEXRON III ATF. DO NOT put the newer Dex IV in even though it says it is backwards compatible, the viscosity is actually lower and may cause shifting issues when warm. If you cannot find regular Dex III (which will probably be the case) you can substitute Mobil 1 synthetic ATF and still be fine. There are a few members including Oldnuc who use Torque Drive transmission fluid that is designed for HD Allison transmissions, it is pretty expensive but you'll never have to change it again (plus, if it's good enough for an Allison, it should be overkill for a econocar trans. that weighs about 60lbs )
Oh and I forgot to mention, the Torque drive only comes in 5gal. increments I believe, you can use a turkey baster to remove your old power steering fluid and replace it with the Torque Drive.
Good Luck (And by any chance does he live up to the motto "If you can't find em' grind em"? )
1994 Plum Metallic SC2
1.9L DOHC 5spd. 180K Miles
Every option except fog lights, a center console, and an automatic
Add to Col.FUBAR's Reputation
Rate the quality of this post and help Col.FUBAR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Col.FUBAR is online now   Reply With Quote
Old 11-07-2009, 12:55 AM   #3
Col.FUBAR
Col.FUBAR's Avatar
1994 SC2
Double-Post but just checked to be sure, Amsoil Torque Drive comes in 1Gal. increments, I knew 5gal. didn't sound right
Old 11-07-2009, 01:54 AM   #4
Scott Peterson
HA he just revs the **** outta it. first one he put a pin thru the tranny 2nd one which is the one now just barely moves the car if your at a stop sign in first gear when you try to take off it just barely moves and slips then catches and it also pops outta 5th all the time.Now we are on number 3 going in this week, with only 8K on it, sooooo well se what hapens, but yea he's not easy on it at all. he shifts hard to, basicaly slams the shifter in every gear and revs it high, and it burns oil at high rpms also, so it looks like he's crop dusting LOL he's almost 60 years old we are haveing a hudsonville transmission install the tranny so im not sure what fluid they are putting in.
1997 sl2, auto
Old 11-07-2009, 01:56 AM   #5
Scott Peterson
I will tell him to request mobil 1 tranny fluid ! thanks !
1997 sl2, auto
Spark Plugs and Cool engine - how cool? usa4624 L-Series General 2 09-17-2006 11:26 PM
Tranny questions ohioguy98 S-Series Tech 4 09-01-2006 06:48 PM
Tranny innard questions gmelton S-Series Tech 5 09-23-2005 04:12 PM
Dex-Cool aka DEATH COOL slice60 L-Series General 11 02-17-2005 09:45 AM
Torque Questions - tranny PBV S-Series Tech 4 11-15-2002 10:09 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
